MagLite 4 Cell C Flashlight Black Logo
Posted on Feb 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Put new batteries in it,turned it on and still wont work,you think it might be the bulb
Anonymous
Level 2:
New Friend:
  • Expert 95 Answers
  • Posted on Feb 22, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
95
Questions
Helped
17356
Points
303
Before replace the bulb, check for rust or dirt inside the electrical contacts. clean it. if still wont work, replace the bulb.
sammyc47
  • Lee New
    Lee New Apr 17, 2014
    I have looked everywhere for an H4 bulb and cannot find one. Everyone has attempted to remove the old bulb and have not been able to open the end-piece.
Front right turn signal light does not blink but will turn on replaced bulb still only one side of duel fillement bulb lights up i think there is a ground issue but not sure if only this turn bulb gro
If you have a loose piece of wire,run it from the battery negative to the light housing, to check your ground. I put seperate grounds directly from battery negative to all light housings because they are so very fickle.
My right front turn signal wont work, the dash board light came on telling me i need a new bulb i put one in and it still does'nt work . I checkd all fuses and they are good , me right rear turn l
are you sure that you put the right bulb in? Some of these bulbs look very similar, (like a 3057 and 3157 or 3156) but they are different. A customer came in with this problem and the problem was that they put a bulb with a single filament in when it was supposed to have a dual filament. the bulbs looked the same and they just grabbed them off the shelf instead of asking the parts guy what their vehicle called for.
Boat trailer lights wont turn on, power is being ran through new wires, up to were the bulb is, up untell the bulb is put into place. Used battery straight to trailer, and bulb turned on and when the truck...
Use the white wire also,the ground on the trailer is not getting ground from the vehicle,so use the white wire to ground to the truck,and the white wire to the ground on the trailer,if this was helpful,at all,please rate,thank you.
Psp wont work
Before you put the battery,first put the memory card,then hold the L trigger and then put the battery still holding the L trigger i think it may work.
Tried to change bulb but now wont work
Insure the batteries are working correct and in the proper direction. Also double check the bulb to isure it was not damaged and put in correctly. If it was working before new bulb inst. try a new bulb
1helpful
Have Cooper lighting outdoor motion detected flood
Sounds like the relay in motion sensor. Change the bulb. Rechargeable batteries are no good after 3-4 years also.
1helpful
2answers
Turn signals dont flash on 95 firebird formula
There are dual elements bulb and single element bulb.
You need to see is there two contacts inside the socket.
If you accidentally put a single contact bulb into dual contact socket......it will cause this problem.
Check it out.
Deleting music
WELL I DID NOT FIX THE PROBLEM YOUR MP3 JUST WONT TURN ON AS SOON AS I PUT ANOTHER BATTERY IN IT WOULDN'T PLAY I ONLY GOT IT ON CHRISTMAS AND NOW IT WONT TURN ON
Phone wont turn on
try a new battery if that does not work then take the phone and have th phone fully service and check.
Jun 08, 2008 • Cell Phones
My Sonic Impact 5070 MP3 wont turn on
The Ilo mp3 player wont accept the battery power
Top MagLite Camping, Backpacking & Hiking Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you a MagLite Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
