Question about Samsung HP-R4252 42 in. Plasma HDTV
Bottom half of screen goes blank
Rlamkin, thanks for suggestion. Is the Y-board for top half of the screen or the bottom half? Also, for checking the loose cable connection, do I have to remove the back cover? Thanks in advance
Take it to a repair facility, don't be a cheaps ***.
Posted on Jul 29, 2008
One half of the t.v screen goes blank
Sounds like a back-light fault. Check its back-light inverter. To get more details, http://electronicshelponline.blogspot.com/Pull up older posts.
Nov 30, 2013 | Panasonic TH-42PX75U 42 in. Plasma HDTV
LG60PC1D Flat Screen
You need a lower Y-buffer board
Jun 18, 2013 | Televison & Video
Lg plasma DT50py10. When turning on bottom half of screen is snowy and has lots of white lines for approx 20 min then it goes away. Top half of screen is normal
sounds like your bottom buffer board is on its way out .
Will also need to check the y sus board as this some times causes the buffers boards to fail.
May 24, 2011 | LG DU-50PX10 50 in. Plasma HDTV
We have a widescreen plasma (Panasonic TY ST05-K). The picture all of the sudden shrunk to about 3/4 of the screen. Fortunately, the picture is not cut-off, so you can see the whole picture. The...
Hi there! If picture is smaller top to bottom with blank section on top and bottom then check your aspect ratio settings. If blank at the bottom only the Bottom Y-Drive board may be faulty. If blank at the top The Top Y-Drive may be faulty. If blank on the Left (TOP TO Bottom) then the Right X-Drive Board and on the Right, the Left X-Drive Board. May also be bad connections on the cables or flexible ribbon cables. Best Wishes and Good Luck, JUS004
Aug 23, 2009 | Televison & Video
Top half of screen goes blank.
Replace Y drive and Y sustain boards or check for loose cable connections on the LEFT side of the panel when viewed from the back - delicate job.
May 27, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Vertical blanking
CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.
Dec 06, 2007 | Mitsubishi VS-60705 60" Rear Projection...
1/2 screen blank
Sounds like a bad connection on or in the vertical output circuit, or the drive circuit. Could also be the vertical output IC or the surrounding componets going bad. Good Luck
Jul 21, 2007 | Samsung TXJ2754 27" TV
Half screen activated only
When only a half screen is produced, it is usually a upper or lower buffer board, if the top half is blank then it is the upper buffer, and of course if it's the bottom half then it's the bottom buffer board
Sep 15, 2006 | Panasonic TH-42XVS30U 42 in. Plasma HDTV
Samsung HP-R4252 42 in. Plasma HDTV Logo
Henry  Thomas
Henry Thomas
