Question about Gateway Computers & Internet
I bought from Gateway to double my ram ( 512 to 1024 ) and now my ram has gone back to 512. How can I find out which chips or whatever they are called have gone dead, the original or the newer Gateway?
  • westonk Jul 30, 2008
    Funny thing. I did what you suggested and both cards indicated they were ok so I put them back in and now I am back to normal. Could be one of the cards was loose. Kelly
  • 2,794 Answers
Turn the power off. Swap out the memory cards putting one bank of memory in at a time. If the computer doesn't boot up after the swap, chances are that is the bad memory card.
Posted on Jul 27, 2008
I have a gateway laptop model MT6821 how do i identify the type of ram installed so i can upgrade
go to control panel , computer , properties and the details of the chip , motherboard and ram is listed there
as the ram is itself a circuit board that is put into a slot, the only upgrade that may be possible is to insert a second board of the same make and capacity to double the ram
talk it over with a computer repair shop as to the possibility of what you want to do
Jun 22, 2016 | Gateway Computers & Internet
How do I open a Gateway ZX4270 to add a 4GB chip of RAM
You will likely just have to open the case of the unit (removing the back cover) and there should be a ram din in plain sight.
Sep 16, 2014 | Gateway ZX4270-UR30 19.5-Inch All-in-One...
What is the max ram I can install on my Gateway MX8734
This model Gateway can support 4Gb of RAM.
The RAM you installed may not be compatible with each other.
Use RAM of the same make and speed.
Dec 31, 2012 | Gateway MX8734 Notebook
Has pc100 128mb and tried to go to Pc133 and wouldn't accept, what is the max memory i can put on this board
the details of that board are sorta sketchy, it could be an intel 810 series or 815 series. theres really no way to tell except by opening it up and looking for the largest exposed ic chip with intel stamped on it, and look for an 810 or 815 designation on that chip.
if its an 810, it may not support pc133 ram, depending on the exact 810 model. if its an 810, it also will not support more than 256 total ram.
if its an 815, it will accept 512 total ram, if not more; however, you will have to go with no more than 4 ram sides- meaning, if you have 2 double-sided ram sticks, you will not be able to add anymore. if you have 2 single sided sticks, and a 3rd ram slot open, you may be able to add a double sided stick in the empty slot for 1+1+2=4 ram sides.
Sep 29, 2010 | Gateway PGA370 E139761 DIMM Motherboard...
The gateway light lights up on the front but nothing will come up on the screen
If the computer turns on then it's usually the video thats gone bad. If it's onbaord video then the you need to install a video card.
If that doesn't work then try swapping out the RAM. One of the chips may have gone bad.
Do you hear any beeps when the machine turns on?
Jun 16, 2010 | Gateway ONE GZ7108 All-in-One Desktop PC
Problem booting
Any beep code from pheonix starting with two beeps relates to ram issues. If you have treid swapping the ram and it only gives the first 2 beeps then most likely the RAM controller on the north bridge or the data channels themselves are damaged on the motherboard.
You can try running a single chip of ram in each slot at seperate attempts. If it is a data channel damaged this will bypass the problem although it will cripple the laptops performance. Either way, the only permanent and proper fix would be to replace the oBo which I doubt would be cost effective on this unit.
Chris
Jun 02, 2009 | Gateway Solo 9500 Notebook
Can't upgrade to 2GB RAM
I just installed 2 1gb chips in my mt3705 and it works perfect  so it might be a problem with your hardware.
Aug 16, 2008 | Gateway MT3705 Notebook
Gateway M-6823 Notebook memory
The only reason for this is your laptop only support up to 1 GIG of RAM or 2 pieces of 512 RAM you can check this link for that specs of this laptop http://support.gateway.com/s/Mobile/2007/Tempest/1014768R/1014768Rsp4.shtml
Hope that helps............
Aug 08, 2008 | Gateway Computers & Internet
Installed new ram and now processor speed is 1/2 of what is was?
Hello Brian -
Is the new RAM you installed the same as what you took out? Are they both PC2700?
Is your laptop running on battery when you're testing to make sure you CPU speed is accurate? The laptop usually ramps down the CPU speed if it is being run off of just battery. Plug it in if this was the case.
Also, the Gateway and eMachines laptops I have encountered have all been notorious for displaying the incorrect CPU speed at times.
I would suggest putting your new RAM in, make sure the laptop is plugged in, and boot it up. This time, let it idle for about 10 minutes and then check your CPU speed to see if it has updated correctly.
Nov 24, 2007 | Gateway MX6438 Notebook
Memory Problems for a Gateway Mx3215 Laptop
There are two different memory modules for that series.You can determine which you need by the chipset for you machine.If you have a Via VN800 Chipset You need the 1024MB-DDR333, 333MHz, PC2700, 200p SODIMM, 2.5v. If you have the NVIDIA nForce 410 Chipset The you need the 1024MB-533MHz DDR2-533 PC2-4200, 200p SODIMM, 1.8v Hope this clears up your problem
Sep 29, 2007 | Gateway MX3215 Notebook
Computers & Internet Logo
49 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
