Question about Electrolux UltraLux 2000 Bagged Canister Vacuum
Electrolux 2100 new bag placed full bag indicator appears
Electrolux 2100 new bag placed, full bag indicator appears. I understand this may be a faulty sensor. can anyone give me instructions how to disable sensor and how to repair it. additionally does any one know how to open this vaccum to get to the sensor?
or perhaps its another issue? I already checked the hose its clear i dropped a penny it came out easly.
  • 1 more comment
  • Langston2 Aug 03, 2008
    The bag full indicatior light comes on and my vacuum shuts off. I only use Electrolux bags and I have tried putting an unused bag in a few times--no luck! I took the hose off of the cannister and turned the vacuum on. The motor ran fine.No problem--but, when I put my hand over the place where the hose fits into the cannister, the machine shuts off and the bag full indicator light comes on. I repeated this a few times and always got the same results. I read somewhere that there is a sensor somewhere near where the bag fits inside the cannister. Does anyone know how to fix this? Thanks! Red
  • luva2win Sep 29, 2008
    same thing i changed the bag 5 times and the light stays on...grrrr
    what do i do ?
  • nsxtech Dec 08, 2008
    bag full indicator on... machine has new bag and will not stay on with any type of flow restriction including the hose on it.
    Scholar:
  • 44 Answers
It appears you have a bad control valve. My suggestion is to take it to your nearest Aerus dealer and have them replace it for you. You can find them by going to aerusonline.com and use their dealer locater. It shouldn't cost much to replace. You can disable it, but I don't suggest it. It is in place to protect you motor, and assuming you bought this machine new, you are aware of how much they cost. If you can't find a dealer locally, call the closest one and they may ship you the part. If you have to do it yourself, here is how. Open the front of the canister and remove the bag. As you are looking at the front of the unit, there are two vinyl covered strips that run the length of the unit. Pull forward on these strips and then pull out so that the vinyl separates from the plastic underneath. Now grab the plastic strip with a pair of needle nose pliers and pull towards the front of the canister. These can be tough if the machine has never been opened up before, but pull as hard as you need to, to slide the strip out. Once both strips are out, turn the machine over, pull out on the sides of the bottom of the unit, and lift up. The bottom should come off relatively easily, and everything will be exposed. The control valve rests under the bag housing, since the machine is now upside down. Pull the bag housing out, and the control valve will be right there. It's circular with vacuum lines connected to it. Just pull it out and move the vacuum lines to the new one, but be sure you get them in the right position!. It won't work if you don't. I hope this helps. Good Luck!!
Posted on Jan 04, 2009
How do you take apart electrolux canister vacuum #2100?
ok, you need to bypass the auto shut of. Put the vac on it's side and pull off the sliders on both sides.Carefully pull machine apart.lift the front of the piece that hold you bag.Underneathe there is a clear tube plugged in to a round thing on switch area.Simply pull the tube out of the rouind trhing.This will allow you to fillthe bag without shut dow.Just make sure your bag doesn't get too full....Chris
Jul 14, 2014 | Electrolux Canister Vacuum Cleaner Motor,...
Electrolux 2100 vacuum
Electrolux has had this issue across all tank machines for years and it has to do with the orientation of the bag. The bags are model specific and must be installed properly. Consult your manual for the proper filter bags and how to install them. The door on the bag will pop open and shut down the machine if the bags are not the proper ones and don't fit precisely. It is supposed to be a safety feature but it annoys the devil out of people and has for years. Their machines are very powerful and well made, but if the bag does not seal properly around the hose inlet or the gasket around the door and bag chamber leak, then you will have this happen.
Nov 20, 2017 | Vacuums
Electrolux 2100 vac dies when you attach hose even with new bag.
If the bag full light keeps coming on, you can first try adjusting the dial on top of the vacuum cleaner. If that does not work, then you need to change the control valve. This is an internal component of the canister and is directly below the dial. You will need to follow the instructions on a previous post to open the Electrolux plastic canister vacuum, and remove the bage cage. Once you remove the bage cage you can change the control valve, and this will solve your problem with the bag full indicator.
Mar 31, 2010 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux Model 2100 vacuum won't work
hi from uk may i suggest you remove cover and the new dust collection bag then if you look in the bag compartment there is a gauze filter fitted usually grey in colour ? at opposite end of compartment where bag connects this gauze filter is the outlet from bag compartment that the air exhales when vac is operating ie as vac **** up dust into bag the bag has microscopic holes that allow sucked up air and dust to collect but keeps dust from passing into bag chamber but allows air to escape thro holes and so enter bag chamber then escapes via the gauze filter to outside of vac hope you follow this ?? now if this filter is blocked/never been cleaned/changed ? then the symptoms of indicator bag full light will come on you can remove and wash filter if it is gauze typ? dry and refit then try vacuuming ? or replace filter they are not expensive usually in pack of 3 in uk DO NOT RUN VAC WITHOUT THIS FILTER FITTED ! or you will have some dust in the room ? hope this helps?
Feb 27, 2010 | Electrolux UltraLux 2000 Bagged Canister...
My electrolux 2100 does not turn on. the light bag full comes on even with a new bag
The bag might not be seated properly or you are using the wrong type bag.Try reseating the bag.
Jan 20, 2010 | Electrolux UltraLux 2000 Bagged Canister...
I have an older Electrolux canister vacuum - model #2100 and the temperature sensor shuts down the motor. How to I take apart and clean?
Check to be certain the thermo lite is on and not the bag full indicator. The thermo detector is very reliable, but the bag fill valve often fails. If it is the thermo, check your hose and wand for blockage by dropping a coin through them,before opening the vac itself.Otherwise you may have a bad set of motor bearings causing the motor to overheat due to its age.
The 2100 and all its canister cousins made since 1982 seem to be prone to failure of the dial valve on top cracking internally. The causes the bag full indicator to come on and the vac to shut down.
To open the vac you will need to slide the locking keys and bumpers forward with the bag door open. Do this with a set of pliers. Once done the vac will open from front to back like a **** shell. Be careful to look at the underside hinge are of the bag door before separating and mark and locate the wiring harness . This vac only goes back together one way, perfectly assembled it pops together with ease. If any piece is out of line it`s like a RUBIKS Cube. Take your time . OEM parts are only available through an AERUS Elctrolux dealer or repair shop
Dec 14, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux canister vaccum 2100
The filter for your Electrolux 2100 is located on the rear top of the machine. It is covered by a plastic grill. You simply place your finger in the rear of the plastic grill, push the tab in slightly and lift the grill up to expose the filter. The filter is approximately 4" by 6". It is NOT washable. Most Vac Shops sell replacement filters in addition to them being available at the local Electrolux distributor.
Jul 06, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Repair my Electrolux 2100 cannister vacuum cleaner
On my 6500, I just disconnected the air line from the switch and now the vaccuum won't sense the bag pressure; I just have to check the bag myself now.
Jun 19, 2008 | Electrolux Epic 6500 Vacuum
Electrolux UltraLux 2000 Bagged Canister Vacuum Logo
1,137 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
