Question about Whirlpool RBS245PDS Electric Single Oven
Oven model RBS245pd86
After doing a "Self-clean" the oven bake temperature reading can not be raised higher than 350 degrees. Thied resetting, opened braker at braker box and reset but no change. The broil temperature appears to be working normal. I suspect the theromstat but I'm not one for troubleshooting by removing and replacing parts. Any ideas? Thanks!
  • 2 more comments
  • LADYFLOWER24 Nov 15, 2008
    This has happened to me too! I cleaned my oven. Oven seemed to be fine when I went to increase temp it goes down not up! Timer does not work and I cannot change the time on the clock. Help!
  • mindykbosu Dec 10, 2008
    I have the EXACT same issue!
  • pjgbweber Dec 17, 2008
    I have the same problem
  • kenhewa Mar 05, 2009
    kenhewa@gmail.com
    Dedicated:
    Visited the website for 20 consecutive days.
  • Whirlpool Expert
  • 84 Answers
If the Whirlpool oven bakes great at 350 degrees, then the problem your having is with the membrane circuitry = The touchpad/keypad on your oven is faulty. The button itself is bad.
You can read more about this issue here -- http://blog.fixyourboard.com/2015/08/18/whirlpool-oven-wont-increase-temperature-up-arrow-decreases-temperature-e1-f2-error/
Replacement touchpads are available for your unit through FixYourBoard.com
Whirlpool Models that normally experience this issue below -- GBS277PDB0, GBS277PDB1, GBS277PDQ0, GBS277PDQ1, GBS277PDS1, GBS307PDB0, GBS307PDB1, GBS307PDQ0, GBS307PDQ1, GBS307PDS1, GBS307PDT1, RBS245PDB1, RBS245PDB2, RBS245PDB4, RBS245PDB6, RBS245PDQ1, RBS245PDQ2, RBS245PDQ4, RBS245PDQ6, RBS248PDB4, RBS248PDQ4, RBS275PDB1, RBS275PDB2, RBS275PDB4, RBS275PDB6, RBS275PDQ1, RBS275PDQ2, RBS275PDQ4, RBS275PDQ6, RBS277PDB1, RBS277PDB2, RBS277PDB4, RBS277PDQ1, RBS277PDQ2, RBS277PDQ4, RBS305PDB1, RBS305PDB2, RBS305PDB4, RBS305PDB6, RBS305PDQ1, RBS305PDQ2, RBS305PDQ4, RBS305PDQ6, RBS305PDZ1, RBS305PDZ2, RBS305PDZ4, RBS305PDZ6, RBS307PDB1, RBS307PDB2, RBS307PDB4, RBS307PDQ1, RBS307PDQ2, RBS307PDQ4, RS675PXEB0, RS675PXEB2, RS675PXEQ0, RS675PXEQ2, RS675PXEZ0, RS675PXEZ2, RS675PXGB0, RS675PXGQ0, RS675PXGZ0, RS676PXEQ0, RS676PXEZ0, RS696PXEB0, RS696PXEB2, RS696PXEQ0, RS696PXEQ2, RS696PXGB0, RS696PXGB2, RS696PXGQ0, RS696PXGQ2 Whirlpool Oven Wont Increase Temperature Stuck at 350
Posted on May 05, 2017
After cleaning the oven the bake temp would not go any higher than 350. when you press the temp button to go lower or higher it only go down. could you tell me what is wrong or what to do.
Posted on Sep 30, 2008
  • Stuart Moon
    Stuart Moon Nov 05, 2013
    I have the same issue
Need manual for self cleaning, please?
Hello Mary;
You can get a user manual at the following website.
Locate your oven model number. It is located on a label either on the face of the oven when you open the door or on the side of the door. Put he model number into the website and you will get diagrams, component part numbers and manuals.
http://www.searspastsdirect.com/
I suspect the user manual is not going to help you. Tell me the model number and what is going on.
Manufacturers offer the self cleaning feature on ovens because customers like this feature and the ovens sell. Yet, the manufacturers engineers have not been able to provide a design that will protect all of the components from self cleaning temperature of 900-1,000 degree F.
When you go into the self cleaning model, the door will lock when you reach 500-550 Degree F. The oven temperature will raise to 900-1,000 degrees F. The oven door will not open until the oven temperature drops to 500 degree F after the self cleaning cycle is completed.
Now, You have a high temperature limit switch in your oven. If this switch fails, you will loose power to your control board and you will not be able to open the oven door.
If you have never used your self cleaning feature, the high temperature limit switch may have failed.
Do to the problems involved with the self cleaning feature, knocking out the control board from heat, additional heating element failure, and other components; It is in my professional recommendation as well as my fellow technicians not to use the self cleaning feature. If you do, do not run it for more than 1 hour instead for the manual 4 hours.
Mar 14, 2016 | Ovens
General Electric oven how to reset thermostat
First of all, most oven thermometers move very slowly compared to the electronic sensors and controls on the oven. To make sure you are getting an accurate reading, the thermometer should be in the center of the oven, the oven should be preheated, then wait another 20 minutes after the preheat beep. If the temperature is less than 35 degrees higher or lower at this point, it can be adjusted via the controls. Usually on GE ovens you press and hold bake and broil at the same time until SF comes up in the display. Then press bake, then use the arrow keys to raise or lower the temperature setting. If the temperature is more than 35 degrees off, you may have a bad sensor, bad control board, or other problem.
Aug 08, 2014 | GE Profile JTP18 Electric Single Oven
Can not raise temperature above 350
500 degrees farenheit is 260 degrees celcius (metric)
any chance the display is set for metric ?
Jun 28, 2012 | Whirlpool RBS305PDS Electric Single Oven
My 30" wall oven oven won't heat up. the clock works and it allows me to put in bake, 350 degrees, but the elements don't heat up. we had a storm and the power flickered on and off several times. is there...
There is a safety thermostat (thermal fuse) on the back wall of the oven that interrupts power from L1 to the Bake and Broil elements. This fails open on an over-temperature or over-current condition. The oven needs to come out of the wall to replace it - best left to a tech unless you are experienced in such things.
Best Regards,
Bruce
www.fixyourboard.com
Jun 21, 2010 | Frigidaire 30 in. Electric Gallery Series...
When set to bake eg: 350 degrees the audio alarm will indicate it's reached temp but the oven is 50- 75 degrees lower. Must wait another 15 min for it to reach the proper temp. Have tried to adjust the off...
If you are monitoring the oven temperature with an analog style thermometer you may actually be ok, but seeing the thermometers slow reaction time.
Some newer ovens actually do pre-heat beep prior to reaching temp in an effort to conserve eelectricity.
A good home test is to try your oven at several different temps to see if there is any variation in internal temperature. Try it one day on 300, the next at 375 and another day at 450. Give your analog style thermometer time to catch up (usually just about 15 min) and leave it on for a half an hour to see if the temp maintains.
Also Beware of aluminum foil AND THE NEW OVEN LINER MATS as they can alter oven performance bay absorbing and blocking the ovens natural heat radiation and convection air flow currents that happen in all ovens, not just convection models.
Another interesting fact is that older ovens used a thermostat in them that operated much like your thermometer and was very slow to react making the oven typically about 100 degrees hotter than where the customer set it. This was just a fact of life before the advent of electronic temperature management and became noticeable when people began trying to bake older "hand me down" recipes in the newer ovens with less than stellar results.
You can mimic the older oven performance by preheating the oven about a hundred degrees higher than called for and after it reaches temp, re-set it to the correct temperature and put the items in right away.
If you find your temperatures fluctuating ask your servicer to replace first the temp sensor and as a last resort the control board as this part is usually pretty expensive.
Good Luck with this!
Jun 14, 2010 | Ovens
When baking my oven door is not locked is it supposed to be?and if so how do we lock it.
The locking of the oven door is a safety feature used only during automatic self cleaning cycle, this is because temperatures during the self clean cycle can reach upwards of 600+ degrees creating a dangerous situation if the door was opened, it will remain locked after the self cleaning cycle is complete until the oven interior temperature is below 100 degrees. So no the door is not normally locked during the bake cycle. Good luck !
Nov 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Temperature in oven is way off
Jim,
A couple of questions... What makes you think the oven is off that far? If you have a set on the shelf dial type thermometer, throw it away. They are never accurate and generally read 50+ degree too low. I recommend the "biscuit test". Which is simply a cheap can of "hit on the edge of a counter top to open" biscuits and see how they bake with the instructions on the can. Make sure you allow the oven to preheat for 20-30 minutes (always but especially for this test).
To change the oven setting press BAKE, then run the temp up to 550 then immediately press and hold the bake pad for 10-20 seconds. The display should read 0 (zero) you can then use the up down arrow pads to adjust, hit bake pad again and then "clear" when done to lock it in but, you can only go up or down 35 degrees. If it is truly off by more than that you would need to change the main oven control board and oven sensor.
Dec 18, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Whirlpool Electric Wall Oven RBS275PDQ6
had same problem, had computer checked out by profesisonal. Was ok. But it seems it is the control pad that clean cycle screws up. Try this (thanks to my wife and her experimental prowess). 1. turn oven on to custom broil. 2. push down temp button to 375. 3. press bake button. 4. You should now have up or down temp. We think you have to get past pre heat cycle in order for this to work. But work it does.
May 07, 2008 | Whirlpool GBD307PDS Electric Double Oven
F2 Oven overheats
jaz3133, it's probably the temp sensor that has gone bad. You should be able to get it from the front. It's the probe that comes out from the back wall of the oven. You can have someone ohm it out. Should read approx 1100 ohms at room temp. Part number for the temp sensor is WB20K5040. Make sure power is off befor removing the sensor. Catriver..post back.
Mar 04, 2007 | GE JTP15 Electric Single Oven
Whirlpool RBS245PDS Electric Single Oven Logo
391 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
