Camping, Backpacking & Hiking Logo
Posted on Feb 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Unit not charging; new battery installed; bulb tested with another battery...working fine. No light when charging; flickers with movement??????
Anonymous
Level 2:
New Friend:
  • Expert 95 Answers
  • Posted on Feb 22, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
95
Questions
Helped
17385
Points
303
Check the alternator for proper voltage lead.
sammyc47
I have a 2014 dodge dart sxt 2.4L. I had problems a few months ago where my car would start fine..drive 1 place and turn car off then would not start. Installed new battery and alternator after running...
Seems you have a dead battery. Could be anything related to the charging system (alternator, control, wiring) or the battery itself. It takes a methodic process of testing to determine the cause(s).
Start by having battery tested and charged. If the battery checks ok and holds a charge then "likely" the problem is with the charging system, but it's a multistep process of elimination and very few parts store do a complete full load battery test.
If the battery test fails then you'll need to replace the battery and then promptly have the charging system tested to verify its working or you'll have another dead battery.
Once the battery and charging system has been verified functional you need to have a parasitic current test done. Excessive parasitic draw can ruin a new battery in a few months depending on your driving habits. Is this a daily driver or every other week or longer?
tip
Brake Lights Dull or Flickering - All Cars
Dull or Dim Brake Light Repair: If your car has a dull or dim brake light it is dangerous to you and other drivers. A dim brake light is a mystery to most people because the bulb is working, just not correctly. First confirm a new and correct brake light bulb has been installed. Next, turn the ignition key to the "on" position and have a helper depress the brake pedal. With the bulb installed touch a grounded test light to the outer bulb holder ring. If the bulb brightness changes the bulb socket ground has high resistance and needs to be repaired or replaced.
Flickering Brake Light Bulb Repair: A flickering brake light bulb can be very distracting and annoying. A brake light flickers because the power or ground is being obstructed momentarily. The most common cause for this condition is a loose fitting bulb socket. To check for this condition remove the brake light bulb in question, while a helper hold their foot on the brake pedal move the bulb around slightly in the socket. If the bulb flickers replace or repair the bulb socket as needed to regain proper brake light bulb operation. If the brake light bulb socket tests ok wiggle the brake light fuse and wiring at the brake light bulb socket, brake light switch and turn signal switch (American cars). If the brake light bulb flickers repair the component or wiring as needed.
Preferred Procedure: Always replace brake light bulbs with manufacturers recommend replacement bulbs. If you cannot find the correct replacement bulb part number consult an auto parts store for additional manufacturer information.
Common Problems
When brake light bulbs are replaced with the incorrect bulb causing no or dim brake light operation
If the brake lights stay on continuously it could mean the brake light switch has failed or an adjustment is needed.
Bought a new alternator due my old one FAILED the test. But, I still have the problem with my head lights flickering & stereo going off then on when I accelerate to go.
Diagnosing Common Automotive Charging System Problems
www.onallcylinders.com/.../diagnosing-some-common-charging-system-...
Sep 18, 2013 - Flickering gauges. ... Problem: The charge indicator light flickers while driving. .... My alternator has been replaced for the third time in 5 months. ... I bought a new regulator but it is still doing the same thing... .... my headlights wont turn on, car runs fine when jumped, battery last for maybe 3 hours, any ideas ...
All lights Flickering/Pulsating only when motor is running ...
www.cadillacforums.com/forums/cadillac-forum/t-221843.html
Feb 11, 2011 - So i have noticed for a while now that all my interior lighting (radio, tach, even ... Installed the battery and have not had issues starting since then. ... So now ipurchased a new alternator "just in case" figuring i would eliminate the .... Interior lights and headlights still seem to pulse/flicker while idling the most, ...
Lights Flickered. Replaced Alternator. Now more flicker? - Camaro ...
www.camarozone.com/.../lights-flickered-replaced-alternator-now-more-...
Apr 22, 2013 - 20 posts - ‎4 authors
Dashlights and radio flicker and battery light come on
It could be a couple things. Take it to a shop or a place like auto zone and have them test the alternator and the battery, its free :) If they both are testing as good, the next thing would be to check the battery terminals and connections. It simply is not getting the enough charge back to the battery for one reason or another.
1helpful
New Battery and alternator. The Battery light comes on and flickers when car is running.
It`s not uncommon to have a faulty unit, try voltage test on battery with engine running and all the electric`s you can switch on it should be putting out 13-15 volts at the battery also check belt tension...
1helpful
Battery light flickers. new battery light still flickers. tested and alternator not charging battery. i do i determine if its the alternator or the fuse link?
Usually it is not a fuse link, but use a test light and check that you have current at the main terminal on the alternator. If you do the fuse links are fine, so next check your belt tension this is something that is overlooked often and is the cause of flickering alternator lights. Also check and make sure your cable ends are clean and tight. If all is fine that alternator or the voltage regulator in the alternator is going bad.
When trying to charge battery green light flickers for hours
1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable.
10helpful
5answers
New Leviton 'lighted, decorative' switch flickers when off
You cannot use standard electronic dimmer switches with CFL bulbs, only incandesant bulbs! That is why you are getting the flickering.
With CFL's bulbs installed in a light fixture that has a non-flouresant rated dimmer switch on that circuit, you will cause the standard dimmer to fail.
You have to look at the dimmer package (sometimes printed on the back of the dimmer itself too) to see if it can be used with CFL bulbs,as many are not rated for use with anything other than standard incandesant bulbs.
Hope you found this very helpful and best regards!
3helpful
My internal battery will not charge
90% of the time the battery is bad. No quick fix, other than test the battery or replace.
please rate
I would have the charging system tested. If the battery test bad check your warranty, many major brands have a free replacement period. The red battery light coming on when the engine is running often means the alternator is not putting out enough volts.
Top Streamlight Camping, Backpacking & Hiking Experts
ADMIN Andrew
ADMIN Andrew
Stan Ford
Are you a Streamlight Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
