Question about Peavey CH1 Speaker
Peavey impulse 1015 horn cuts in and out
Hi guys, i have 2 peavey impulse 1015 (older models 350watts) im having trouble in one of the horns, cuts in and out, crossover is very hot, no signs of loose solder connections anywhere (had that prob B4), other cabinet is fine, if i blew the HFdriver (which i probably did, checks 0 ohms) why didnt both HFdrivers blow?? they are the older 22xt's, im running right at the program watts about 320watts, speakers are rated at 350watts program. HELP??!! POED SOUNDMAN
    Problem Solver:
  • 17 Answers
If the horn cuts out after some usage ...then its probably the limiter lamp that is gone .... the limiter lamp is switched into circuit once the " polyswitch " gets hot .... so at first the horn works ...then when the limiter lamp is switched in ...nothing !
its just a standard 12volt car tail light lamp ...let me know if this helps
Posted on Feb 04, 2009
On my sp2x with 22xt high freq driver, actually rated bout 60 watts for the compression driver,crossover has to soak up / dissipate power over and above what is safe 4 comp driver,that said,I just blew both 15" woofers trying bi-amping,running 120wpc 8 ohm amp bout 3/4 power to horns-ok.500wpc 8 ohm to woofer,smelly burnt voice coils.That was an xpensive arvo.
Posted on Aug 30, 2008
Horns wont play in peavey 215
broken crossover or bad diaphram or wire off in the high circuit.
Mar 13, 2014 | Peavey PV-215 Dual 15 2-Way Speaker...
Is there a fuse in a peavey sp2 for horns
there are 2 of them in the new ones....but ya probably the blew diaphrams...unless they are old one...then it could still be in the crossover..need to know the exact SP2 model you have, as they have changed the speaker again and again over the years.
Jan 15, 2014 | Peavey SP2 PA Passive Speaker
Impulse-12d low end not working? fuse issue?
No..probably blew the 12 or the amp, could be a loose wire to speaker but.....
Nov 09, 2012 | Peavey Impulse-12d 1200 Watt Powered 12"...
Peavey xt22 horn not working
Across the diaphram you should be reading about 8 ohms. it sounds to me like it's blown.However,if you think it'ds thre crossove, take it out and send it to Peavey. They do good , fastwork.............................................................
Mar 23, 2017 | Music
Peavey SP3 (older model) Can not get any sound thru horn.
They have a "soundgard" protection network that uses a polyfuse and an automotive lamp. Open the unit and check the circuitry. Both the polyfuse and he lamp may be blown. Do ohmmeter check of these, otherwise the horn is blown.
Aug 08, 2011 | Peavey New Peavey Sp3 15" 3 Way PA Speaker
Peavey Horn Drivers (compression drivers)
Did you sort your problem? I need 2 also, but seems quite easy to get 4ohm but 8 ohm a little harder. The woofer in the cab is 4ohm, cabinet is rated 4ohm so wondering wether to replace th 8ohm horn with a 4ohm diaphram.
Any thoughts?
Thanks.
Nov 26, 2009 | Peavey Audio Players & Recorders
I have a pair of peavey impulse 200`s one of the horns just crack`s up and I have to keep it lower than the other to stop it popping.Has it gone or is it fixable cheers.
hey, just picked up a pair of used peavey impulse 200p speakers .. one of the speakers is giving out this very loud high pictched hum (obviously not working). can anyone help or advice, thanks
Mar 01, 2009 | Peavey CH1 Speaker
I have a set of peavey scorpion sp5xt's one works fine but if i plug into the other one ,in full range, only the horn works,
Horn and speaker combo cabinets have an electronic component called a "crossover". The horn and speaker both work off different electrical signal frequencies. If you can take off the back, or get inside by pulling the speaker, check for a small circuit board mounted inside the box or on the speaker or horn. Check for a broken wire or loose connection of the crimp connectors.
A common problem with speakers, often the cone, or paper part of the speaker will come un-glued or separated from the magnet "voice coil". This happens when played too loud, when it's commected to the wrong impedance, or if the signal was shorted and "overdriven" (usually sounds like an awful buzz that's really loud).
Always make sure your output impedance matches the impedance of the speaker. Most auto stereos are 4 Ohms. Older home stereos are typically 8 Ohms. Musical PA gear varies between 4, 8, and 16 Ohms. Peavey gear is typicall 4 Ohms, but some older models are different. The Ohm rating is the amount of the resistance in the circuit. If your speaker is 4 Ohms and you plug it into an 8 Ohm circuit, you can destroy the speaker and sometimes the crossover circuit board.
Good Luck.
Jim
jimmydsmith@cox.net
Phoenix, Az
Jan 09, 2009 | Music
Peavey KB 300
Yes a horn can get blown. This should be 2 pieces, the horn itself and a circular driver on the rear. The driver itself will have what is called a diaphragm that can be removed and replaced. That is the part you want. Open up the speaker and get the part number off of the back of the horn and order the diaphragm from Peavey.
Dan
Aug 27, 2008 | Audio Players & Recorders
Hi, I need to replace the baskets on my peavey impulse 200 speakers. The baskets currently in them are 1268MR BW... (12 inch black widow) I am wondering if I can use differant baskets, due to the fact I'm...
Hi dieselbob25
Whats happening to the 1268? Oh and I couldnt find that model in the standard range available to the public at the peavey sites I checked here and Peavey
They may be a special edition for the Impulse boxes. Can you tell me what is happening to the speakers? Are they burning voice coils or what. May indicate another area of concern that is making them fail.
regards
Graeme
Apr 14, 2008 | Audio Players & Recorders
Peavey CH1 Speaker Logo
765 people viewed this question
Top Peavey Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Michial Gueffroy
Are you a Peavey Audio Player and Recorder Expert? Answer questions, earn points and help others
