Question about Motorola Mobility RAZR V3m Cellular Phone
Won't charge or turn on
When i went to charge my razr this morning, it wouldn't register that it was charging. the display will intermittently go white and then dark; the same with the keypad. it won't say "charging battery" or anything. i tried two different chargers at several outlets. i also tried popping out the battery and putting it back in. nothing seems to work. the phone worked fine last night; the battery died overnight. i haven't done anything to it -- it hasn't been dropped, gotten moisture in it, or anything. please help!
    Master:
  • 763 Answers
Maybe the problem was your battery, i just think that youve overcharged it. try to replace another battery. hope that helps!
CHARCOIS
dont forget to rate my post thanks!
Posted on Jul 27, 2008
2 Suggested Answers
SOURCE: Razr V3 keypad disfunction
I found free assistancer and fixed the phone from different chat rooms. You're just another site that's trying to make money rather than help people out; I won't use your site again and I won't refer anyone.
Thank you
Posted on Oct 11, 2008
My Motorola electrify won't turn on or charge. It
maybe your battery or your phone os .... try a new battery if nothing happens... try re flash your phone
Jun 02, 2013 | Cell Phones
I put my Droid Razr on charger but battery symbol comes on with ? mark. Won't charge or turn on.
1. Turn off your phone when it's not in use. If you're not using your Verizon Wireless Razr, then shut it off. Your battery will last much longer if you regularly do this.
2. Charge your phone less. If you charge your Razr nightly, then your cell phone battery won't last long. Try to charge your phone only a few times a week to extend the battery life.
3. Keep your Bluetooth turned off when you're not using it. Applications, like Bluetooth, are notorious for sucking the power from a cell phone battery.
4. Protect your Razr from extreme temperatures. Your cell phone battery lasts longer if kept at room temperature.
5. Discharge the Razr fully. Before you charge your phone, let it completely die. You can extend the life of the battery by regularly discharging and then fully charging it.
6. Leave the battery in the phone. Keep the Razr battery dry and free of dirt to prolong its life.
Aug 20, 2012 | Motorola Mobility Motorla MOTXT912 DROID...
Fully charged but will not switch on?
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Aug 08, 2012 | Motorola Mobility RAZR V3
I just purchase Pandigital multimedia novel 7"
It sounds like your in sleep mode. Hold the power button till the display says power off and tap the power off on the display, the charging light will come on and the charging light will change color when it is fully charged. Here is the link to the pdf quick start guide:
http://www.pandigital.net/userfiles/file/Downloads/QSG_%20PRD07T-1_v2.2_09-08-10.pdf
Hope this helps thanks for using FixYa
May 13, 2011 | PANDIGITAL Digital Book 843967071153...
Charged, wont turn off/on
Try switching off the phone leave it off for some time and then switch it off...
If this doesnt remove the battery and put it back on... and then switch on the cell phone...
This must do the trick...
A small piece of advice mate... Never charge your phone for a whole night... Just put the cell phone for charge for some 2 - 3 hrs or till the batteries are fully charged... Your cell phone's battery would become weak if you charge for a considerably longer duration than required... And i am pretty sure that the problem you got now is joust because of that...
Hope this helped...
Dont forget to vote!!!
Fixya!!!
Oct 18, 2008 | Motorola Mobility RAZR V3
Dead battery won't recharge
if it still new and you've still got the warranty then you should ask for replacement of the whole unit.
seems that the problem of your phone is the unit itself, the charging circuit migth have disorders/malfuntioning.
ever tried checking for the specifications and directions for charging the unit.
i greatly suggest that if you got the warranty still, have it replaced.
good day!!!
Feb 28, 2008 | Motorola Mobility RAZR V3
Phone wont turn on!
i have noticed that the mini plug for the charger and usb connection on RAZR V3 is sometimes sloppy. when the phone is charging it will definitely say battery charging on the external display and also flash the battery icon. i also noticed that the plug for the wall outlet is touchy.
make sure the plug is secure in the wall outlet
make sure the mini plug is secure in the phone
gently wiggle these connections if you have to till you get the battery charging message
if there are any connection problems there will be a unable to charge message instead.
Nov 10, 2007 | Motorola Mobility RAZR V3
My display outside and inside isnt working for my motorola razr v3
bring it to a technician, and let him know what the new battery and charger did to your normally fine phone. They should be responsible for repairing your phone. No easy fix as described above. Let me know how it works.
Cynthia Charczenko
Nov 04, 2007 | Motorola Mobility RAZR V3
Motorzor
you simply fried your battery by overcharging it. Just get a new one, let it fully charge and fully die twice before you start normal charging. Then you will want to only charge it for about 2 to 3 hours or find a charger that has a smart chip that tells it when to stop charging once the battery is full.
May 13, 2007 | Motorola Mobility RAZR V3
Motorols Razr Display
maybe when u charge it try having the phone on. see if that works
Oct 16, 2006 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3m Cellular Phone Logo
69 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
