Question about Toys
Original Leapster The screen has lines going down it. The games work fine and the sound is fine. Can the lines be fixed?
  • 1 more comment
  • hhjmom Aug 10, 2008
    I can hear the games...all 20 of them....when I push the buttons everything works...It just won't show up on the screen properly.....There are lines....It was working fine a minute ago??? what is up??
  • som4 Nov 23, 2008
    I have the same problem with the lines, however it wasn't dropped. It was however left in a hot car...can temps impact the game too?
  • beanbloss Dec 19, 2008
    My children's leapster has two yellow spots on the screen. They are fairly large and in the middle of the screen. It can make it inconvienent to play some games. Any idea how to get rid of them?
  • 38 Answers
Probably not. those lines are probably from dropping the game on the ground or water/alkaline fluid in the screen. the only way to no longer have the lines is by buying a new screen and those can cost quite a bit
Posted on Jul 31, 2008
Leapster restarts select cartridge game
Try this
Ensure that a cartridge is not inserted
Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER menu appears.When the LEAPSTER menu screen appears, press the A button.Touch each of the crosshairs that appear with the stylus, Restart unit
Aug 13, 2014 | LeapFrog Leapster 2 Learning System
Leapster2 is 2 1/2 years old. Placed brand new batteries in Leapster2. Try to power it on, screen comes up like it is going to turn on, and it turns off.
Welcome to FixYa!
Ensure NO GAME is in unit
Power Unit off
While turning Leapster 2 on, hold down HINT KEY. (Key in middle with question mark on left hand side)
Once unit switches to other menu, Hit A to begin calibrating.
Follow prompts with Sylas pen to reprogram Stylus pen.
Once you are done it will return to original Calibrating Menu.
Power Unit off Turn unit on with game inserted. Stylus pen should respond.
1) Ensure that a cartridge is not inserted
2) Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER menu appears. 3) When the LEAPSTER menu screen appears, press the A button 4) Touch each of the crosshairs that appear with the stylus 5) Restart unit
Do comment if it helped or not in any manner ill know.
Apr 15, 2011 | Leapster 2 Handheld Game
When we inserted a new game cartridge (Pet Pals made for Leapster & Leapster 2) we get a question mark on the screen. We've changed the batteries and the old game cartridges are working fine. Please...
its not recognizing the game, contact is probably dirty. take an eraser and rub the contacts of the cartridge and get them super clean, blow out ALL the debris and that should fix it.
good luck!
Jan 29, 2011 | Leapster Learning System
My daughter has a Leapster 2 that is only about 2 months old and the touch screen does not work
Answer
I had the same problem and here is the answer I found at leapfrog.com which fixed my daughter’s disney princess leapster 2’s problem. Good luck!
If your Leapster2 does not respond to the stylus pen, it needs to be calibrated. Calibrating the Leapster2 is easy:
5) Restart unit
Jan 30, 2010 | LeapFrog Leapster Learning Game System
Leapster 2 wont work
You need to calibrate the touch screen - hold down the ? button and a menu will come up, go to 'touch/calibrate'-red dots will appear on the screen in the corners then in the middle and you have to touch the centre of them with the pen to line up the screen again - turn off and again and it should be fine - hope this helps xx
Jan 04, 2010 | LeapFrog Leapster 2 Learning System
Screen is totally blacked out but the sound works.
leapster initially worked but now will not work, batteries are fine
Dec 25, 2009 | LeapFrog Leapster Learning Game System
Leapfrog Leapster
I've tried the Home and A button several places... and it seems to work for others but not me :( I was about to give up then I found another way to reset the screen - Hope it works for you!
1. Unit must be OFF and NO cartridge
2. Hold down the HINT (?) button while turning the unit on
3. When Leapster menu screen appears, press the A button
4. Touch each of the cross hairs that appear with the stylus
5. Restart unit
Dec 01, 2008 | LeapFrog LeapSter L-Max Console
Leapster not recognizing the pen??
Press the ? button and hold it while turning unit on.
Press the "a" button to select touch calibration
Press each + with the stylus
Restart machine
Nov 25, 2008 | LeapFrog Leapster Electronic Book:...
Leapster screen not working
Apparantly, the Leapster screen issue is a common problem. While this suggestion is not ethical and since my game was near perfect condition, I went to Wal-Mart and bought a new one of the same color and then returned the broken one.
Jun 12, 2008 | LeapFrog Leapster Educational Game: Disney...
Leapfrog Leapster touch screen
Got my son's to work. Used these instructions.
Question Why doesn;t my Leapster2 respond to the stylus pen? trnsp.gif Answer If your Leapster2 does not respond to the stylus pen, it needs to be calibrated. Calibrating the Leapster2 is easy:
1) Ensure that a cartridge is not inserted 2) Hold down the Hint button while turning the unit on 3) When the LEAPSTER menu screen appears, press the A button 4) Touch each of the crosshairs that appear with the stylus 5) Restart unit
Feb 11, 2008 | Nintendo Game Boy Advance Console
Toys Logo
858 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
