Question about Microsoft Office Professional 2007 Full Version for PC
No spooler my hp printer dies not print and gives a response as no spooler.have contacted the hp helpline and they say that something wrong with the computer.would like to know regarding the problem. thanks
  • mung Jul 28, 2008
    my computer running on xp 2.
    thanks
  • Tim Babcock
    Tim Babcock May 11, 2010
    Is your printer running on a Vista computer?
My computer running on xp 2
Posted on Jul 28, 2008
My HP LaserJet says: Error Memory Full, and does not write. What to do Per Olof Olsson Sweden
Customers may report MS Excel print jobs hanging in the print queue, and print spooler memory growth. Cycling the print spooler clears condition, but only temporarily (returns within days). Solution Universal Print Driver version 5.2 resolves this issue. The issue occurred because previous versions of UPD sends EMF print data from MS Excel. UPD 5.2, and later, corrects this issue by sending RAW print data. For more information http://h20338.www2.hp.com/hpsub/cache/343033-0-0-225-121.html?jumpid=ex_r2845_go/upd
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 21, 2011 | HP LaserJet 1320 Printer
Something is wrong with the spool or spooler. Won't move to print.
the spooler needs to be blown out papper bult around spooler blow out with air in can.
Feb 17, 2011 | HP Office Equipment & Supplies
I have an HP 1020 printer. I cannot undertake any operation as the words " printer spooler not running " continues to appear on the screen. I tried to delete the printer and reinstall , without...
Print spooler not running is not the printer error, it happens when the print spooler service starts working in windows, For making it enable you dont have to reinstall the drivers for the printer, as print spooler service is for every printer, even if you put another printer the result will be the same
To Enable Print Spooler Open Control Panel
Go to administrative Tools>Services (For Windows XP Users)
Control Panel\System and Security\Administrative Tools( for windows 7 users)
Open Services Find Print Spooler in the list
Right click the service and make it stop, if its already stop set it to Start and then again give prints
Double click on the service and set "Startup type to AUTOMATIC". You should now be able to get prints from your printer
Now restart your desktop/laptop and check if the service is still working by giving any test print.
Hope it will solve your issue
If you require more assistance, regarding this topic feel free to reply
Regards, BA
Jan 14, 2011 | HP LaserJet 1020 Printer
The print spooler service is not running
Restarting the Print Spooler
  • Before completely resetting the print spooler, you should first attempt to restart the print spooler service to see if it fixes your printing issues. To do so in Windows, open the Start menu and click on the "Control Panel" icon. Then open the "Administrative Tools" folder and double-click on the "Services" icon. Scroll down to the "Print Spooler" entry and click on it. If the service is not currently running, click the "Start" link on the left side of the window. If the print spooler is running, hit the "Restart" link. After the service has started again, try adding a new printer or printing another document to see if the issue has been resolved. if not do the following:
  • Reset the Print Spooler Files
  • After successfully booting your computer into safe mode, you can remove and reset the system's print spooler files. Open the Start menu and click on the "My Computer" icon. Go into the C: drive and navigate to the "Windows\System32\Spool" directory. Open the "Printers" and "Drivers" folders and delete all of the contents in them. Once the files have been deleted, restart your computer again and boot in standard mode. The print spooler files will be reset and the errors should no longer appear.
  • If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
    Thanks, Joe
    Nov 17, 2010 | HP Officejet 4315v All-In-One InkJet...
    Hi, my HP OfficeJet 6110 doesn't print when something is listed in the queque. It also takes forever to delete things in the line. I've also had issues where the cartridge has to be aligned, and every time...
    There are several ways to resolve printer spooler error, probably because there are many variations of this error. The error caused by faulty software can be resolved by deleting all the information found in the directory. Thereafter, navigate to the Control Panel, click on Administrative Tools and then services icon. Find the service labeled Print Spooler, highlight it and restart the process. If that doesn't work, the program might be corrupted. Click on start, then Run. Search for the document labeled services.msc, and this will trigger the opening of another window. On this window, scroll down and click "Print Spooler". Check its setting and turn on automatic mode. Click Okay, and restart the machine. If you're lucky, this might be all you have to do. Still doesn't work? Navigate to the Add/Remove Programs screen of the Control Panel. Find the all the software responsible for making the printer run including the drivers, and uninstall them. Be sure to be thorough about it, or the problem may not be solved. Download the latest copy of your printer's software from the manufacturer and reinstall it.
    Nov 11, 2010 | HP OfficeJet 6110 All-In-One InkJet...
    What is a printer spooler
    A software program responsible for managing all print jobs currently being sent to the computer printer or print server. The print spooler program may allow a user to delete a print job being processed or otherwise manage the print jobs currently waiting to be printed.
    May 22, 2010 | HP LaserJet 2840 Printer
    I do not seem to be able to print any documents even after uninstalling old drivers and installing new ones what is wrong
    Print spooler is no less than the chief boss of printing action. Print spooler is a linking part between your PC and printing hardware. Print spooler is the only master of print department of your PC office. Print spooler is a master of all printing procedurees and it’s that what is responsible for the redress printing queue and serial printing of your documents. Any messages like “Spooler subsystem app has encountered” and “Spooler subsystem app stopped working” are a unfavourable sign that you have met printer problems and need facilitate. Spooler virus is not so wide spread but it can be a reason of printer spooler service keeps stopping. If printer spooler keeps stopping our tool is a best thing to sort it out.
    Fortunately I know the program which can help you to eliminate print spooler virus without extra efforts. I see Print Spooler Fix Wizard as an optimal medicine for print spoolerWhen the whole province stopped because of corrupted print spooler function it’s significant to discover an trouble as soon as possible. Don’t wait a wonder from your printer – it’s nothing without its print spooler. It’s not required to find another place to copy any documents because you can cure your own printer with the assist of Printer Spooler Fix Wizard for five minutes.
    Printer problems: is it an boring chance or a reason of why the whole department interrupts its earn money? When you end your earn money sending a paper into your printing waiting line print spooler only begins its earn money. Are you really sure that high-effectively your print spooler will ever hold out against print spooler virus? You needn’t activate to buy a up-to-date printer if you have Printer Spooler Fix Wizard. So fast and effectual treatment as Spooler Fix Wizard may become a salvation of your province printing capabilities. Just as you need your printer earn moneys now and printing tasks can’t be call off we suggest you Printer Spooler Fix Wizard.
    You have a choice: try perennially to cure your print spooler by yourself or get Print Spooler Fix Wizard last and all the time. Doesn’t an hour of your work cost less than Print Spooler Fix Wizard? It’s better to get high effective solution for several minutes than try to cope with printer problems manually. When you choose Print Spooler Fix Wizard you decide successful help.
    All the best Pineworks
    Apr 24, 2010 | Lexmark X1270 All-In-One InkJet Printer
    I cannot print, the service spooler is not running
    In run window type services.msc and the go to print spooler option just stop and restart the service.
    Hope this helps. Please rate my response.
    Thanks.
    Have a good day.
    Feb 22, 2010 | HP LaserJet 1022 Printer
    HP D1460 only prints when computer is restated on XP
    click on start click on run in open box type
    net stop spooler. then hit enter.
    then type net start spooler. and hit enter repeat above steps 3 4 times. net stop spooler then net start spooler. at the end make sure spooler shud be started. then restart computer.
    Dec 16, 2009 | HP Office Equipment & Supplies
    HP laser jet 3390 printing problem
    Could you please try reinstalling your printer drive software, i think it might solve your problem.
    Jan 05, 2009 | Office Equipment & Supplies
    Microsoft Office Professional 2007 Full Version for PC Logo
    24 people viewed this question
    Top Microsoft Computers & Internet Experts
    micky dee
    Piyal Perera
    Piyal Perera
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
