Question about BenQ (200NSH-LAMP) Projector Lamp for PB6100, PB620
Sears Easi-Load R-43 Slide Projector
I am a Senior Move Manager. I have a client who's late husband left thousands of travel slides all in round slide trays, boxed and indexed of their travels through all 50 states, Africa, Hawaii and Europe which she was going to throw out. I thought we could find a good home for them at one of the universities. In the meantime, I wanted to view them to see what kind of quality they are and I cannot figure out how to attach the round tray to this projector. Can someone tell me? I couldn't locate a manual for this brand on line.
Thank you.
Suzan
2 Suggested Answers
Partstore
  • 34 Answers
SOURCE: 2400 RF Slide Projector
The projector lamp is BenQ part number 60J8618CG1. You can download the manual at http://safemanuals.com/user-guide-instructions-owner-manual/BENQ/PB6200-_F
Posted on Jul 30, 2009
Lift gate tray
No. The slide tray should rotate when the forward or reverse buttons are pushed. Slides are not required for correct actuation of the tray. Before attempting any adjustment, try a few different trays (it may be a tray issue!). A 140-slide tray will be much tougher to get correct movement from than with a 80-slide tray on an older slide projector.... The 140 tray pushes the interface specification between a tray & a projector to the max.
Oct 13, 2013 | Kodak Carousel 4400 Slide Projector
Slides jam in the projector
Chances are if you move your slides into an 80 slide tray your slide jamming will go away. Slides warp and bow due to the affects of humidity on the paper mount and the transparency itself when they are stored. The compartment dimensions in a 140-slide tray do not allow for ANY slide warpage, When the slide warps, it hangs up in the tray (or hits the bottom of the tray ejecting) and the projector will jam. I hope this helps. Good luck !!
Jul 28, 2011 | Kodak Carousel 5600 Slide Projector
My Kodak Carousel 650H has a stuck slide and the tray won't move. The stuck slide is lined up with the "gate index." I tried releasing the tray but only one side of the tray releases. The...
Two steps.
1) Look down into the center of the carousel. There should be a round, flat silver knob with an elongated notch in it. Take a coin (US 5-cent piece or similar) and use it to turn the knob. This releases the catch on the metal plate under the projector. You should then be able to lift the carousel off. Be careful: some slides will fall out as the slot is not aligned with the carousel body properly once you do this.
2) Make sure the locking ring on top of the carousel is in place (or else take out all your slides. Turn the carousel over and gently rotate the metal plate covering the bottom of the carousel into position. You will hear/feel a "click" when it's in place.
The projector may have jammed because there are two slides stuck in the viewing slot--check for this before you put the carousel back on the projector. If it jams a lot the metal plate under the carousel may be bent.
Jul 17, 2011 | Kodak Carousel 4600 Slide Projector
I have a sears easi-load circular tray 9985 for a slide projector. I don't know what brand projector it will fit in. Thanks.
I have a number of these. The printing on the box is as follows:
For use with Sears 9833, 9843, 9853, 9854, 9883, 9884, 98833, Sawyers, GAF and Anscomatic tray-loading projectors.
Apr 30, 2011 | Cameras
I bought a used kodak 650 carousel slide projector and i can't get the slide tray to load. Is it because it came with a 140 slide tray instead of an 80 slide tray?
The KODAK Carousel 650 was manufactured approximately between 1964 and 1971.
Try removing the tray and pressing the cycle button(s) on the side of the projector. Watch the levers in the cut-out on the top of the projector. The lever closest to the rear of the projector should move back & forth (as you actuate the cycle buttons). The lever toward the front of the projector should extend and push forward (front of the projector) when you push the "forward" button, & extend and push toward the rear in reverse. If you are not seeing these levers move as described, then the chances of your projector needing a repair are likely. The good news: parts are still available. The bad news: You will have to find a factory-trained repair dealer to make the repairs for you.
Aug 10, 2010 | Office Equipment & Supplies
Model 760 H projector-- Carrousel advances, but slides do not
My guess is that your slides are in a 140-slide tray.
Over time, with repeated cycles of humidity & drying, slides warp slightly. The compartment width in a 140-slide tray is quite narrow, and it takes very little warping to make slides stick in their individual compartments. If you move the slides to a KODAK 80 Slide Tray you should be in much better shape.
Feb 24, 2010 | Kodak Office Equipment & Supplies
I just purchased an older Kodak slide projector with a carousel on top. Everything works fine but the carousel won't advance. When you click the next button, the plastic arm that should advance the...
By the sounds of your description, your projector needs an adjustment to the slide change mechanism. This is best done by a factory-trained dealer, who has the service manual. Sorry I can't be of more help. Happy New Year!
Nov 14, 2009 | Kodak Carousel 5600 Slide Projector
I'm testing my 4400. With slide tray loaded (no slides in tray) when I advance the carousel the light from the lamp does not shine through. Does the carousel have to have slides drop down in order for the...
Yes!! The projector is equipped with a "dark shutter", which means light is only allowed to exit the projector when a slide is in the gate. That eliminates the "white screen strain" on your eyes when no slide is present. Happy New Year!
Sep 16, 2009 | Kodak Carousel 4400 Slide Projector
BenQ (200NSH-LAMP) Projector Lamp for PB6100, PB620 Logo
173 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Electro Med Services...
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
