Keyboard has changed
I have had to reinstall XP as I could not remove a isp's security services when I changed from one isp to another, all has worked well and I now have a nice clean hard drive and xp, the problem I have is the keyboard will not now show the @ sign it just goes from ' to " and the hash key now shows \ and goes to | I cannot find any more faults, what has gone wrong please.
Thanks
Tony Jones
  • ToJo39 Jul 29, 2008
    Sorry this does not help as I have purchased a new keyboard and I have the same problem.
  • ToJo39 Jul 30, 2008
    Thanks for the help, its ok now, when I installed XP I forgot to delete the us keyboard in setup and it had gone to that.
    Thanks again.
    Genius:
  • Computers & ... Master
  • 1,056 Answers
Sounds like the shift key is broken on the keyboard.
Try plugging in a different keyboard into the PC and see if it does the same thing.
If it works like it is supposed to just replace the keyboard.
Posted on Jul 27, 2008
  • Coss Jul 29, 2008
    Was the computer off when you swapped out the keyboard?
New keyboard does not work
To connect or to disconnect the keyboard to a PS/2 port, follow these steps:
Shut down the computer.
Plug your device into the correct port. Make sure that the plug is pushed securely into the connector on the computer.
Restart the computer. Microsoft Windows detects the change, and then installs the drivers on the new port automatically.
If the issue continues to occur, try connecting the keyboard to a different computer. If the keyboard functions correctly on a different computer, the port to which the keyboard was connected on the original computer may be damaged. If this is the case, contact your computer manufacturer to inquire about how to repair or replace the damaged port.
If the keyboard does not function correctly on another computer, the keyboard may be defective. If this is the case, and the warranty on the keyboard is still valid, you can exchange the defective keyboard for a new keyboard.
If the keyboard works on another computer, go to Step 2.
Step 2: Download and install the latest keyboard software
Step 3: Manually reinstall the drivers
To remove and then reinstall the drivers, follow these steps:
Disconnect the device from the computer.
Turn off the power for the device, if the device has a separate power supply.
Open Device Manager. To do this, use one of the following methods:
In Windows Vista or Windows 7, click Start, type device in the Start Search box, and then click Device Manager in the Programs list. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
In Windows XP, click Start, click Run, type devmgmt.msc, and then click OK.
Double-click Keyboard, right-click the keyboard that you use, and then click Uninstall.
If your device is not listed, this means that the device was removed automatically when you disconnected the device. Go to the next step.
First, turn on the device, if you have to, and then plug the device into the computer. Your computer detects the device and then reinstalls the drivers for the device.
Jun 04, 2012 | Acer Computers & Internet
I do not believe my mouse is connected to the device. I turn on my desktop and the mouse and keyboard do not work, so I cannot even enter my password to log onto the desktop.
you might have to uninstall the mouse then restart your computer then reinstall the mouse and its drivers
make sure the lead from the mouse has a secure seating and the lead is not bad/faulty
((if applicable))
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware make sure you have the correct mouse selected also under hardware you can troubleshoot also you can select properties under driver you will have options to update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
Click start control panel keyboard you can change your settings there
or you might have uninstall the keyboard then reinstall it and its drivers
control panel keyboard hardware then properties you hould see driver details,update driver,roll back driver,uninstall
make sure you have the driver for the keyboard before uninstalling the driver
diconnect the keyboard then reconnect it then reinstall the driver
make sure the lead has a secure seating if applicable or the usb device
hope this helps
hope this helps
Feb 01, 2011 | Microsoft Standard Wireless Optical Mouse
Windows XP loads up but when prompted to click user, mouse will not work, I have tried 2 different mice confirmed to work on another PC, keyboard then locks up when press any key, tried to repair with xp...
try blowing out all of the dust from your laptop keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines.
dust causes static which causes lots of problems with a computer and its parts
or if this does not fix the problem
click start control panel keyboard you can change your settings there
or you might have uninstall the keyboard restart your computer then reinstall it and its drivers
click start control panel keyboard hardware then properties you should see driver details,you will have options to update driver,roll back driver,uninstall
make sure the lead is good and has a secure connection diconnect the keyboard then reconnect it then reinstall the driver
as for the mouse
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options also hardware under hardware you can troubleshoot or
select properties under driver you will have the options to update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
hope this helps
Jan 22, 2011 | MSI K9N6SGM-V (7309-020(K9N6SGM-V))...
I reinstalled xp and one day later the keyboard wasn't working. what would be the problem? i'm now using the on screen keyboard. kindly assist. my mail is mikekabaria@gmail.com. thanks in advance.
remove the cmos battery and keep it in a freezer but on something solid for 15mins the reinstall it back.save the changes in the bios and exit.
Dec 30, 2010 | Computers & Internet
Keyboard is not working
maybe prop open the keyboard and look yourself?
you need to remove the bezel which is located in front of your keyboard. don't think you need to unscrew anything. see if you can pop it open. find a model similar to yours and see if it helps http://repair4laptop.org/disassembly_dell.html
find two screws securing the keyboard and remove it.
remove keyboard see if everything is plugged in. there should be one tape securing it.
remove it and replace it if you want.
HOWEVER
if you uninstalled the keyboard driver by accident then reinstall it. but I don't know anyone would uninstall in the first place.
Aug 31, 2010 | Dell Latitude E4300 Notebook
I can't get my wireless keyboard to work even after trying everything can think go or told by Windows XP. Anything else i could try? Lee
First try changing the batteries, reconnect the dongle or the connection device of your wireless keyboard and mouse, then restart your computer. If the step wont work reinstall the Bluetooth/Infrared software driver the wireless keyboard and mouse then restart the computer. If this fails still look under Ad/Remove programs if you have a Setpoint installed then remove it and restart computer, both or at least one of the devices should work. If one or both wont work then you need to contact the manufacturer and have the defective device/s be replaced. Just a heads up, they may ask you to reinstall your operating system / do a reformat of your computer so you need to back up your data ahead of time using a wired keyboard and mouse. Have a nice day ahead!
Aug 13, 2010 | Logitech Wireless Access Duo Optical...
I wnt reove power on password in hp nx 6310
Remove the battery and to the power cord.
Remove the two screws that secure the keyboard. After removing the keyboard, remove the battery “RTC” to stop providing energy to epprom BIOS. After the upgrade or downgrade, or any repair, leave the Laptop for 5 minutes, without any source of energy.
Then connect only the power cord without battery and without the battery “RTC” of the Bios. then turn on the laptop press f10 change passwords and save changes and exit, put back battery then reconect the rtc battery and done reinstall xp done
Sep 29, 2009 | HP Compaq nx6110 Notebook
Keyboard did not working......plz help me
either u r keyboard is having any dust or go to controll panel and set the keyboard properties or re arrange ur keyboard;
Jun 10, 2009 | Microsoft Windows XP Professional
IBM 300PL Model: 6862-V20 Booting Sequence cleared problem
boot in bios and reset the intrusion to read and clear it out alot of times the bios will use its backup when cleared clear the ir setting as weel and remove any passwords in the security setting in the bios if you are using a pov card you may have to take it and reset the machine then disable the card funtion reinstall then reset the card from there
Dec 19, 2008 | IBM LENOVO VIDEO CARD 3D PRO 4210 00N3439...
Acer aspire 5600 keyboard problem
ok this may sound weird
but this is what works for me
simply remove your battery back while the ac adapter is plugged in
your touch pad and keyboard should work now
when you have all systems go reinsert your battery pack
good luck
Nov 19, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
