Question about Gateway GT4022 PC Desktop
Gt4022 boot problem
My gt4022 won't boot up. I already try it with a different power supply but I don't want to go further with changing the mother board . If there is a better approach to a solution.
  • rxrosendo Jul 27, 2008
    How do I change the booting sequence? Do I unplug the the drives and and all other connected devices from the power supply?
  • 39 Answers
If your motherboard is getting power .try changing the boot sequence
Posted on Jul 27, 2008
I have a gateway gt4022 at first i had the power issue but after sometime it solved itself out i guess......but after that i started getting another problem which after the PC boots into windows.....the ...
The screen goes fuzzy because the video chip has failed. Since this is an onboard one you will have to replace either the motherboard or the entire pc if you don't know how to do that .
Jun 06, 2011 | Gateway GT4022 PC Desktop
I have a gateway gt4022 running windows xp. When
Probably hardware failure. To test that remove all disks and extra components and try again to boot into BIOS. If you can't then you will know for sure. If you can then take the opportunity to change the boot order and put the cd first and the hd second. Now connect an optical unit and try to boot in a bootable disk, preferably a Linux Live-CD. If you can then the hard disk is dead, replace it.
Jul 13, 2010 | Gateway GT4022 PC Desktop
Gateway Gt4022 PC Desktop
Try a different monitor (borrow one). If that doesn't work, you need to take it to the shop.
May 13, 2010 | Gateway GT4022 PC Desktop
I have a Gateway GT4022 that recently stopped working. When the power button is depressed, the fans will kick over for less than a second and then the system shuts down. It never gets to the BIOS and no...
Power supplies shut off automatically when one of the voltage wires is shorted to ground somewhere. This is why you see the fan kick over for a second and quit. This is probably a bad motherboard.
Jul 29, 2009 | Gateway GT4022 PC Desktop
Gateway GT4022 Motherboard failed
Well, I think gateway is just a computer manufacturer, so if you are still under warranty, you could possibly get a replacement. But before doing anything, and if you are comfortable with doing so, open up the side of the casing, and take a look around, see if any cables seem unconnected.
Jul 08, 2009 | Gateway GT4022 PC Desktop
Power went out the other night while my Gateway GT4022 was on. It won't turn back on now, no lights, no fans...replaced power supply, still same problem...thanks
If the power went out while it was on it may have been given a surge. If that is the case the motherboard is going to need to be replaced. Check the power supply connection on the motherboard if it is discolored then that is the problem.
Jun 25, 2009 | Gateway GT4022 PC Desktop
MOTHER BOARD
You might be able to find something that can use all your hardware on www.newegg.com. As for that exact same motherboard, you probably will have to call gateway.
Sep 14, 2008 | Gateway GT4022 PC Desktop
My gateway gt4022 won't boot. I don't think even at bios. My monitor says that it does receives any signal. I try changing the power supply but I don't think its a power supply issue since the fan kicks in...
Here are different things you can try:
Make sure there are no loose cables
Press F8 when the computer turns on.
Check to see if the lights on the keyboard turn on: this means its posting.
Jul 27, 2008 | Gateway (4000474) Motherboard
My gateway model gt4022 won't start up
The Gateway GT4022 is known for having a loose North and Southbridge. Simply open the case, press down on the heatsinks covering the north and southbridges and it'll boot up the next time. Enjoy!
Feb 21, 2008 | Gateway (4000474) Motherboard
Gateway GT4022
Google motherboards. XD
Looks like your motherboard is actually pretty good. What do you need to replace it for?
Here's a good website: http://www.tigerdirect.com/
Click motherboards or motherboards with cpu included.
Another website, http://reviews.cnet.com/4566-3049_7-0.html?tag=dir gives you a list of motherboards and where to buy them.
Usually, motherboards under $100 are old or cheap.
If you need an exact copy of the one in your GT4022
this is your motherboard on gateway.com: http://support.gateway.com/s/MOTHERBD/FIC/4006105R/4006105Rnv.shtml
just google that motherboard and you should be able to find an exact copy to buy.
Jan 05, 2008 | Gateway GT4022 PC Desktop
Gateway GT4022 PC Desktop Logo
127 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
