My unit works fine in temperture of high 80s. Anything above that it runs constantly for 5 to 7 hours. I do not remenber it doing this last summer.
  • 80 Answers
SOUNDS LIKE TO MUCH REFRIGERANT NOT LOW YOU SEE AS THE TEMPERATURE RISES SO DOES THE PRESSURE IN YOUR SYSTEM.THE HIGHER THE PRESSURE THE HIGHER THE DISCHARGE AIR TEMPERATURE.HAVE SOMEONE CHECK YOUR SUPER HEAT AND YOUR DELTA T
Posted on Jul 29, 2008
  • 1,420 Answers
Couple or reasons, Unit sized too small, plugged filter or low refrigerant. Have the unit cleaned and inspected by a qualified technician.
Posted on Jul 28, 2008
Nordyne heat pump
It sounds like either the compressor valves have failed or the rev valve has stuck in one position. You don't mention if you looked at the operating pressures of the compressor that information would help.
Jun 12, 2013 | Heating & Cooling
Asus s200e stuck on high performance mode
Go into the settings menu and set it to "Balanced". The thing you have to remember is that they say "Up To 5 hours" not will run for at least 5 hours. It probably will last for 5 hours on idle but not if you are watching movies on it. They take a lot of processor time, therefore use a lot of power.
Apr 03, 2013 | Computers & Internet
Hi , was working fine last year but now is now
There are 5 basic, yet solvable reasons for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
Hope this helps you troubleshoot & solve the problem. Thanks for choosing FixYa.
Aug 05, 2011 | Danby DDR5009EE Dehumidifier
My Sunbeam air conditioner has always flipped the breakers in my house (old wiring), but it worked fine for two summers and then sat last summer. This summer it blows the breaker constantly and in the...
This is a good question to ask. 1. if a unit trippes a breaker its for 2 reasons. A. to protect the wiring from catching fire . B. to protect you from electrical contact with ashort condition. Before you buy a new unit I would recommend you fix the wiring as bad siring is ******* the unit and costly to operate due to load resistance. Also replace any breakers that are unsed to support this unit. Brealers go bad esp if they have been problematic in the past. I am not certain as to the size of the unit you have now but if it cooled the room well then replace it with a match or a bit bigger unit.
As to why it tripps the breaker now? could be a couple thing Bad wiring like you state. weak breakers as I pointed out. or a bad compressor or fans. Or in my view its most like a combo of all the above. Hope this helps let me know.. Jon
Aug 03, 2011 | Kenmore 76129 Air Conditioner
Freezing problwm; very small amount of water was collected.
Here is a tip that I wrote that will help you understand why and what you can do with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
Apr 27, 2011 | Soleus CFM-40 Dehumidifier
I have a Craftsman 1 hp 5 gal air compressor. Worked fine last summer, but now will not get above 20 lbs pressure no matter how long it runs.
Remove the compressor head and examine the valves for any damage. Make sure there are no tank leaks causing the air to flow away. Make sure the intake filter is not plugged. Hope this helps!
Jan 15, 2011 | Garden
MY S-80S MESSAGE CENTER SAYS BULB FAILURE DIPPED BEAM. WHAT DO I DO? FUSES ARE GOOD. ONLY HIGH BEAMS WORK.
sounds like both bulbs have gone,change both bulbs together.most bulb makers recon bulbs last 2000 hours/3 years .
Feb 22, 2010 | 2000 Volvo S80
Just a little question, guys!
The blower has absolutely nothing to do with outdoor air. Having the T-Stat set to auto lets the blower come on only when the A/C-heat comes on. With the switch in the ON position the blower simply runs all of the time. Depending on your living space (high ceilings, multi-level) having the blower on constantly while costing a small amount to run can actually save some money and make you more comfortable in the summer. However most people will leave it in auto in the winter so they don't feel as if they have a draft from the air movement as the blower is in high speed in fan on position and cool modes and low speed in heat mode. Many furnaces today are equipped with a setting that allows the blower to run constantly at a lower speed or simply run for a min. or two after the A/C=Heat have turned off.
Jan 17, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Sony 62' blinking lamp light
you might want to have the thermal fuse checked... seems to be an issue... sony knows about it but doesn't want to share this info with many.
amazing how you can spend big bucks on a tv and the life of the tv isn't all that long.
kim
Jan 16, 2008 | Sony KDF-E60A20 60 in. LCD HDTV
Heating & Cooling Logo
67 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
