Question about Sewing Machines
Europro x top thread has no tension no matter what i put it on
  • Anonymous Sep 07, 2008
    hello - i have a sears kenmore "model 385. 1764180" bought in 1992(?), but unused for ages; appears to be in good shape except for the following problem: both upper and lower threads lie flat on the fabric and appear loose. i've tried adjusting tension from 5 up to 9, then from 5 down to 0 just to compare. not much difference across from 0 through 9.
  • Anonymous Dec 07, 2008
    Where are the tension discs in the memory craft 4000? I can't get any top tension, either with auto or manual settings.
  • 323 Answers
There is probably a thread broken off inside the tension discs.To remove it ,adjust the tension knob to 0 tension, and raise the presser foot. Spread the tension discs a part with a small screwdriver and blow some canned or compressed air through the discs.You should see some thread or lint come out of it.
Rethread the machine,adjust the tension back to 5 and test the tension by pulling on the thread near the take up lever. When the foot is up there should be almost no tension. When the foot is down you should have tension.
sewman7
Posted on Jul 29, 2008
Tension on brother se1800 sewing machine isn't working right. Top thread appears on back of fabric, So far I've checked threading top and bobbin, cleaned race.
When threading the top thread, ALWAYS RAISE the presser foot so the thread will seat properly in the tensioner.
Then adjust the top tension so the top and bobbin threads meet in the middle of the fabric.
Sep 08, 2017 | Brother Sewing Machines
My top thread keeps picking by the bottom thread is fine doesn't seem to matter what the tension is set on
check that you have the top thread between the tension plates
it is common that when threading the machine the top thread will fall behind the tensioner and run around the mounting thread
Sep 23, 2015 | Singer Sewing Machines
Why does the bottom thread on my 185k Singer sewing machine keep tangling.
Your bottom thread looks like the top tension is too loose or not being fed through the tension disc.
1. While you thread do it with the pressure foot up. Make small pulls while threading to make sure there are no snags.
2. When you finish threading put the foot down. Check for resistance on the thread. There should be some; not excessive though.
3. Always start at four on tension and adjust as you need to.
Feb 26, 2015 | Singer Sewing Machines
I recently replaced the tension assembly on my Kenmore 15516000 and now I either don't have any tension and the top thread balls up in the bobbin or I have too much tension and breaks the thread. Wha
YOUR TENSION CONTROL HAS TO BE PLACED BACK TOGETHER SO THE THREAD CAN GO BETWEEN THE TWO SAUCER SHAPED METAL BRACKETS. WHEN THE PRESSER FOOT IS DOWN THE TENSION SHOULD BE APPLIED TO THE THREAD. IF THE PRESSER FOOT IS UP THE TENSION SHOULD ALLOW THE THREAD TO FLOW WITHOUT DIFFICULTY WHEN YOU PULL ON IT. THAT IS WHY THE MACHINE SHOULD BE THREADED WHILE THE PRESSER FOOT IS UP. THEN YOU CAN BE MORE ABLE TO PICK UP WHEN THERE ARE HANG UPS. TAKE YOUR TIME. IT IS AN ITEM THAT CAN BE VERY FRUSTRATING!
Jan 28, 2015 | Kenmore Sewing Machines
I tried the free style quilting on my Q10 and now it wont sew properly on the regular side. When I set it on a 4, or any number for that matter,the underneath is in tiny stitches. is there a proper se
make sure the thread is coming off the thread spool easily,, also make sure the top thread is pulling easy thru the tension disc,,
take the bobbin out of the bobbin case and put it back in the bobbin case--make sure the bobbin is turned counter clock-wise
keep working with the top thread tension,, also try some unwaxed dental floss on the tension disc if possible,, and the try setting the tension to 4 or 5 and see if that helps,,, but if you go thru all the top thread tension numbers and still the stitches don't change then you may have to have the machine checked
Dec 19, 2014 | Sewing Machines
The bottom stitching looks like a line and not stitches the top stitching is fine
whether its bias or straight does not matter to machine. loosen the bobbin tension and put more tension on take up spring by inserting a screwdriver in the slot of the top thread tensioner. turn to right.
Dec 13, 2012 | Juki DDL8300N Sewing Machine
How do you adjust the tension on a Bernina 180
There are two tension adjustments, which should be done with a proper set of weight gauges - top and bottom thread tension should be carefully balanced to get the best stitch formation. It is best that you assume the top tension is correct and adjust the bobbin tension to match. Load the bobbin with thread of one colour and put a spool of the same thread but a different colour on the top. Thread-up the machine, load the bobbin and sew-off a satin-stitch on max width zig-zag. In this configuration, there should be a very small 'bead' of the top thread showing along each side of the satin-stitch on the underside of the material. If there's excessive top showing, the bobbin tension is too high and if none, the bobbin tension is too low. To adjust the tension, remove the bobbin case and you will see a spring around the edge with two screws through it. One of the screws holds the spring in place and the other adjusts the tension - this is furthest from the edge of the spring and is in a small 'cup' in the spring itself. To reduce tension, turn the screw VERY SLIGHTLY anticlockwise and to increase it turn it clockwise. Make very slight adjustments and re-check sewing-off the satin-stitch every time until you get the required thin line of top showing down each side of the stitch on the underside. Ideally this should be done with Mettler Metrosene thread, but as we're just balancing against the top tension, it shouldn't matter too much provided you use a good thread top and bottom.
Jan 27, 2012 | Bernina Artista 180
My machine will sew fine for a few minutes and then the tension will go loose and the bobbin thread will leave long threads for a while and then the threads knots up in a big bunch. It doesn't matter how...
It could be your top threading, your thread tangled, or your thread is old. Try different thread and do this test, with the presser foot up, pull the top thread, it should move smoothly, now put the presser foot down, pull the thread and it should barely move. This usually seats the thread in the tension discs. If, that doesn't do it, insert a new needle.
Dec 23, 2010 | Brother CS-6000
Threading machine
The machine is relatively simple to thread. This is what I do and I've had no threading problems. 1. Put thread spool on the spool pin and put spool guard over spool pin to hold spool onto pin. 2. Take thread and put it under the bent tab by the circle tensioner. bring the thread around the right side of the circle tensioner and bring around the front of the circle tensioner thing back to the top hook on the far left side of the machine. 3. Take the thread around the backside of the top hook think until it threads through the flat piece on the left side of it. 4. Bring the thread down through the first (right side) channel and under the plastic piece to the second (left side) channel. 5. Bring the thread up the second channel and around the moving thread holder and past it's flat metal piece to hold it. 6. Tuck the thread around the small wire thread holder below the needle screw. This may take a few passes to catch it. 7. Thread the needle from the front and run the thread between the teeth of the presser foot. 8. Put a bobbin in the bobbin case so that the thread pulls off the bobbin from the left side of the bobbin if you look at it from above. 9. There is a small channel in the bobbin case that is covered by the bobbin tension flat piece. Pull the bobbin thread through this channel and into the empty space where the needle thread will catch. 10. Place the bobbin case into the machine with the little set bobbin arm pointed to the sky so that it fits into the machine without wiggling to the right or the left. 11. Turn the, uhhh brain fart, the hand wheel until the needle comes back up with the bobbin thread hooked over the needle thread. Take a narrow thing, like scissors or a seam ripper and pull both threads until the bobbin thread comes up. Now your machine is threaded. Use these directions with the pictures in the book to get this machine threaded.
Dec 11, 2006 | Euro-Pro Fast and Easy 420 Mechanical...
Sewing Machines Logo
340 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
