Question about Fedders Heating & Cooling
FEDDERS WINDOW AIR CONITIONER
MY WINDOW AIR CONITIONER IS LEAKING INSIDE THE WINDOW SILL AND INTO THE HOUSE
LIN139@AOL.COM
  • ggoodall Oct 22, 2008
    My Fedders A6X08F2B-C window unit is also leaking inside. I took the cosmetic cover off the front and see that the inside coils are standing in water and I can see how it is overflowing the case on the inside of the window sill. The unit is about 1 1/2 years old and has had LOTS of use. I've checked with a level to see if it is sloping properly to the outside and it is. How can I clean out/clear the drain line? How do I access it?
    Thanks, Greg
  • 143 Answers
Clean the drain so it leaks outside the house.
Posted on Jul 27, 2008
My window unit is leaking alot of water in my house
clean the filter . make certain its tilted ot the outsid eby about 1 inch. let me know if htis does not solve it or if it does thank you jon
Jul 25, 2011 | Fedders X Chassis A6X05F2B Air Conditioner
Drainage occurs near the front of the unit, resulting in pools of water leaking onto my window sill. Unit is installed properly, there is no drain hole to direct water away from the insides of the walls...
The A/C unit should be tilted slightly to the rear and this will allow the water to leak to the outside of the window, you may have to drill a small hole in the case to drain if there is no pre-existing hole.
Aug 15, 2010 | Frigidaire FAC126P1 wall/window Air...
My air conditioner is leaking water inside. Did I install it improperly?
Use a bubble level and make sure the unit is sloped away from the house. There should be a hole on the underside of the housing near the rear of the unit make sure this is clear.
Jul 12, 2010 | Fedders A3X05F2A Air Conditioner
Sill supports for window air conditioner...no sills
ok do not worry...every unit comes with outside supports that allow you to tilt the uinit to the outside a little so the water discharge can leake outside and not inside your house...one support go in eachside under th eunit one side connect to the wall and the other side connect to the bottom of the unit...
the whole is need on the side you are going to let the water out...the unis discharge lots of water and need a way out and the hole is for that make suer it is on the back close to the corner and far away from any moving part.(I usually find a place under the fan that is if they do not have one pre-driled
Sep 07, 2009 | Heating & Cooling
Water leak
Make sure the unit is tipped to the rear slightly. Do not drill holes in the base!
Aug 21, 2009 | Maytag NMPEB08F2A Air Conditioner
We have a Fedders window unit and we do not have an owners manual. When we plug it in it beaps and then blows air for 2sec and then it goes off with the signal E3 showing in the digital box. We need to...
Without the model number, I can't point you to the exact manual for your particular unit. However, here's a link to a web site that has about 38 manuals for various Fedders models. You can download a manual and/or users guide for free and look at the operation and troubleshooting sections to see what you need to do to get your unit working properly.
Just scroll down the page once you get to the web page to locate your particular model number, then click on it.
http://www.retrevo.com/samples/Fedders-Air-Conditioner-manuals.html
Hope you found this helpful and best regards!
Aug 06, 2009 | Fedders Appliance Air Conditioner Wall
Do i have to install my fedders aeq07f2bg on an angle to let the water drain out
It is a good idea to have the rear just slightly lower than the front edge to prevent water (condensate) from dripping inside.
However, most window a/c's use the heat from the unit along with the fan to dispel the water out the back and/or sides of the a/c outside the house.
If you do have the a/c tilted just back a bit, it should prevent any surprises and puddles on the floor, if you leave the a/c running when you're not home, etc.
Hope this helps and best regards!
Aug 01, 2009 | Fedders AEQ07F2BG Air Conditioner
My window air is leaking on the inside of my house
usually because the drain hole/duct/tube, on the outside is blocked, or the aircon is mounted leaning Into the house, condesate that is supposed to drip into the outer casing and run out the hole is funneled over the lowest point of the casing, the house side.
check and unblock the drain,
and ensure the aircon is mounted tilted back.
Aug 02, 2008 | Haier hwr10xc6 Air Conditioner
Installing room airconditioner
what i did was buy a 2x6 cut them all into about 18 inches in length screwed one piece onto the window sill and the other 3 i screwed into that piece going out the window so the a/c unit sits on the wood pieces and clears the window sill that way i dont have to worry about the a/c unit weight on the window it was all on the wood pieces sticking out
Apr 28, 2008 | Heating & Cooling
Window unit air conditioner leaking water inside home
well it might not be tipped at a angle so the water comes to the front tip it back some
Jul 10, 2007 | Fedders X Chassis A6X08F2A Air Conditioner
Heating & Cooling Logo
155 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
