Question about Garmin Nuvi 360 Bilingual GPS Navigator and Personal Travel Assistant GPS Receiver
Nuvi thinks my power lead is conection for computer
  • sushi1234 Sep 02, 2008
    When i plug my car charger to my garmin nuvi 260 the nuvi thinks that it is a usb conncetion to my computer and behaves like its charging and i cant see the maps or use my nuvi
    Hence the only way to use it for me is by plugging it out of the car charger and running it on battery power
  • jowandan Sep 15, 2008
    when I plug my Nuvi 350 into a power source it comes up with a graphic showing the gps connected to the computer and won't do anything else...only way to get it to work is to unplug.....is there any fixes?
Canged the power lead
Posted on Jul 28, 2008
Once I conect my GPS to a usb cable, I get the black screen that says conect to computer, that being connected to the car. I thought that the gps needed to be coneected to the internet to get updates, I...
The screen your describe on your Garmin Nuvi is quite normal. It's the PC communication mode of the Nuvi. When disconnected from the PC it will automatically restart.
To update Nuvi software and maps - connect the Garmin to a PC / Mac using an USB cable. Then start your web browser (Internet Explorer / Firefox or similar) and go to MyGarmin.com.
To update the Garmin - MyGarmin.com will check if your webbrowser has been installed with the Garmin update plugin. If not it will say so and will lead you through the procedure to install the Garmin web browser plug-in.
After the web browser plugin is installed it will ask you for your Username and Password at MyGarmin.com. If not registered, then register yourself with the serial number of the Garmin Nuvi.
From here it's possible to update your Garmin Nuvi with new Nuvi software and maps using your username / password at MyGarmin.com
Jul 09, 2011 | Garmin Nuvi 1300 GPS Receiver
Hi i have a garmin nuvi 200 sat nav am trying to update it but did not get any conections with it can you tell me which connection i will need
You need a mini USB lead. It has a mini plug on one end that goes into the satnav where the charger plugs in. The other end has a USB plug that goes into the USB port of your computer. It's possible that you already have a lead like this as the same type is used to connect many other items to computers e.g. external hard drives, some cameras and camcorders etc.
If you want information on how to update your garmin satnav you'll find it at http://www.fixya.com/support/r5628920-update_garmin_satnav_maps
If you want to back up your favourites folder from your satnav to your computer you'll find information on how to do that at http://www.fixya.com/support/r8422587-backup_restore_favourites_garmin_nuvi
Feb 24, 2011 | GPS
I do not have a lead to conect to computer
You will find these leads in many electrical shops or on ebay.
Have a look at what other electronic devices you have, ie mobile, mp3 player, camera, ebook, a lot of them use the mini usb leads.
The filter is probably blocked.
It is inside the base of the machine.
Take out the filter and clean it and also clean out the filter well as that can also hold quite a bit of debris.
Please dont forget to vote if you liked my answer
thanks
Feb 13, 2011 | Garmin nuvi 1300 Car GPS Receiver
How concect garmin nuvi 205w to laptop
You connect the satnav to your computer with a mini USB lead. It should have come with the satnav. The narrow end goes in the back of the satnav, where the power lead goes in the car, and the USB end goes in a USB socket on your computer.
If you didn't get a mini USB lead with your satnav you may already have one for something else. They come with many digital cameras, camcorders, smart phones, external hard drives etc.
If you don't have one any computer store should be able to sell you one.
Jan 07, 2011 | Garmin nuvi 205W GPS Receiver
I just got in my car, and the GPS usually comes on right away and it didn't. It won't turn on at all. HELP!
check the power feed lead as that may not be working or your cigar lighter the lead has a fuse in the cigar light plug, or try conecting to pc with usb lead
Jan 04, 2010 | Garmin Nuvi 660 GPS Receiver
Nuvi 250 will not turn on when charging.
There are two types of leads that you can buy.
The one supplied with the Garmin expects you to plug the GPS into the PC via the USB and if you use this to try and charge your Garmin in your car it will think it is connected to the PC and show the connection screen. it will charge the unit but you can't see the map.!!!
Make sure that you buy a lead specially for the Garmin for use in the car its the only type of SAT NAV that you will have this problem with.
LOL
Sep 12, 2009 | Garmin nuvi 250W GPS Receiver
Unable to use my Nuvi 200 on external power
My origional car power lead had a broken 5 volt line and the supposed replacement item did not have a pull down resistor from pin 4 tl pin 5 ( ground ) As soon as I rectified this the unit worked as advertised.
Aug 27, 2009 | Garmin nuviĀ® 200 Car GPS Receiver
Conecting to my pc computer with my psp
you can download with the PSP using wifi and don't need a lead to connect to the pc
Jul 31, 2009 | Sony PlayStation Portable (PSP) Console
Power leds and other mother board leads
you dont tell us soo much information but from i understand you have no leads lighting . no power lead no hdd lead etc. you have to conect them properly in your mainboard. open your mainboard manual that's came with and go to the section leads, there is explained where is the place and where to conect each lead.
Apr 05, 2009 | Intel Computers & Internet
Garmin 660 wont operate on power lead
Are you using the Garmin AC adapter or the Garmin car adapter? Using the wrong cable and the Garmin will think that you are trying to connect to a computer. Not all USB cable are alike.
When connected to your computer it thinks that you want to upload or donwload information.
Jan 26, 2008 | Garmin Nuvi 660 GPS Receiver
GPS Logo
37 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
