Question about HP REFURB LASERJET 4250TN PRINTER
Error code 49.ff01, hp laserjet 4250tn - HP REFURB LASERJET 4250TN PRINTER
    Sergeant:
  • 194 Answers
This error is usually caused by a bad formatter board
SOLUTIONS
1. Press CANCEL JOB to clear the print job from the printer memory. 2. Turn the printer off, and then turn the printer on. 3. Try printing a job from a different software application. If the job prints, go back to the first application and try printing a different file. (If the message only appears with a certain software application or print job, contact the software vendor for assistance.) 4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or printer. 5. Turn the printer off. 6. Remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM in the lowest DIMM slot.) 7. Remove all EIO devices from the printer. 8. Turn the printer on. 9. If the error no longer exists, install each DIMM and EIO device one at a time, making sure to turn the printer off and back on as you install each device. 10. Replace a DIMM or EIO device if you determine that it causes the error. 11. Remember to reconnect all cables that connect the printer to the network or computer. 12. If the error persists, replace the firmware DIMM. 13. Replace the formatter.
Posted on Feb 22, 2011
Service error 494co6
check your print Que to see if you have a corrupt print job. cancel any and all prints in there, if any. if that doesn't solve it check/upgrade firmware or replace formatter board.
Nov 09, 2015 | HP LaserJet 4250n Printer
HP LaserJet 3055 All-In-One Printer "49 error turn off"
The 49 code is related to one of three things on this unit.
1. You accidentally used a refurbished toner instead of one directly from the manufacturer which tends to cost a bit more. The certified one from the dealer is known to clear this error code instantly.
2. Your internal memory cash will need to be reset
3.You have internal hardware failure which can not be repaired by the user and must be sent to the manufacturer.
Mar 22, 2013 | HP LaserJet 3055 All-In-One Printer
49 error on HP laserjet 3050
Internal Embedded Software Error. Manual says to power off for 30 seconds. Power it on and let it initialize. If the error persists you will need a tech.
Aug 15, 2011 | HP LaserJet 3050 All-In-One Printer
Error code 49.FF01 can't turn on or off
A firmware error occurred ( This error is usually caused by a bad formatter board)
SOLUTION
Feb 22, 2011 | HP LaserJet 4250tn Printer
HP LaserJet M1522 with error 49
on hp.com you can update the firmware and that should take care of it. its a free download
Jan 07, 2010 | HP LaserJet M1522n MultiFunction Printer
Hp laserjet 4250tn printer 49FF95 Service error
Hello
Thank you for using FixYa for your problem
It should be taken to an authorized repair centre for a repair estimate. Very few printers have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Dec 18, 2009 | HP LaserJet 4250tn Printer
49.c02 service error message on HP laserjet 4100
General printer error. Unplug the power cord for 10 seconds.
Jan 21, 2009 | HP LaserJet 4350 Printer
HP REFURB LASERJET 4250TN PRINTER Logo
3,078 people viewed this question
Clive
Clive
