Question about Star Logic 17" LCD Monitor
Star logic 19inch computer monitor power adapter STD-1205
Can't find the power adapter for my Star Logic 19in computer monitor AC Adapter STD-1205
  • ilonag Aug 14, 2008
    screen good, adapter faulty (tried with an other cord.).
    Can not find replacement.
You can use a power supply for a CCTV system. Here is a website that has one, it is for a DVR4220, code STD-1205
Posted on Sep 28, 2008
  • linedanceman Sep 28, 2008
    Sorry, forgot the website, here it is -http://www.cctvfactory.com/Merchant2/mer...
Hi there, My Viewsonic failed about a year ago and I'm hoping to bring it back to life Problem: It won't turn on. Observations (thus far): Green light visible on AC Adapter, as well as on Logic Board Caps...
Buy a new monitor!! Seriously, unless you're the techie type that likes to tear open electronic equipment to see how it works and/or fix it, you're better off buying a new monitor especially if this old monitor of your's is a LCD.
Mar 11, 2010 | ViewSonic VA550 15" Flat Panel LCD Monitor
Power supply- the monitor will short out and I have to adjust the power adapter going into the monitor. The monitor will not stay on but the green light remains on.
It sounds like there is a connection problem between the monitor and the adapter, make sure there is no problems with the two connection devices. Also, you may need to purchase another cord, IF there is something blocking the adapter from receiving full connection to the monitor.
Jan 24, 2010 | Star Logic Computers & Internet
Macbook will not power on. It's not the battery according to the Genius bar technicians
I assume it doesn't power on from the AC adapter either?
If not, perform the following steps:
  1. Disconnect the AC adapter and remove the computer's battery.
  2. Press and hold the power button for 5 seconds and then release the button.
  3. Reconnect the battery and AC Adapter.
  4. Press the power button to restart the computer.
If it doesn't restart, you have logic board issues, and need to bring the machine in to a service tech.
Sep 06, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Installed windows vista and now I have resolution problems
Get an application called Unknown Devices and find out what your Video Adapter is and get the appropriate drivers.
Dec 17, 2008 | Star Logic 17" LCD Monitor
17" starlogic monitor model M19BNK serial M9B49CKVoo4584
blown capacitors on the vga board or the resolution for the display adapter is set too high for the monitor reduce the resolution in safe mode and you should be ok, if not then the bad capacitors are in need of being repalced
Sep 17, 2008 | Star Logic 17" LCD Monitor
Star logic monitor settings
I typically do capacitor replacement on lcds all the time insde, the board for power will most likely have 1 - 4 blown capacitors, replace these and the monitor should be good as new, btw 1 is a 10 v smallish size you can replace it with a 16 volt same MF.
Sep 10, 2008 | Star Logic 17" LCD Monitor
Star logic 19" lcd monitor
This is most often caused by a serious failure and the power supply is protecting itself and you from fire by cycling the AC off and on.
Aug 08, 2008 | Star Logic 17" LCD Monitor
Info on Star Logic manufacturer
HI ,
IM HAVING APROBLEM WITH MY STARLOGIC MONITOR ALSO.....
I HAVE LOCATED THE BOOKLET THAT CAME WITH MY MONITOR AND HERE IS THE FOLLOWING ADDRESS....
SERVICE FACILITY NUMBER..508-435-4830 OR
800-639-3803
FOUR STAR GROUP
26840 FARGO AVE.
SUITE C
BEDFORD HEIGHTS, OHIO 44146
EMAIL SUPPORT: techsupport@fourstari.com
hope this helps you
sandie
Jun 03, 2008 | Star Logic 17" LCD Monitor
Need a driver and users manual for mag innovisionLT576s
42905439-177x150-0-0_.jpg ViewSonic (HASU05F) Information: Product details Price Range: $25.00 - $40.00 at 3 stores This AC Adapter is ideal for use with your Flat Panel Monitor or LCD Display. The High performance AC Power Adapter pictured here provides consistent and continuous power at the specified Voltage and more
this is what else u need to power the monitor it is plug and play compatible
make sure your video card has the right software to run monitor
Where can I get drivers for my video cards?
Answer ATI – http://www.atitech.com/
Nvidia - http://www.nvidia.com/
Matrox – http://www.matrox.com/
Pinnacle – http://www.tridentmicro.com/
Trident - http://www.tridentmicro.com/
Diamond Multimedia – http://www.diamondmm.com/
Cirrus Logic - http://www.cirrus.com/en/
http://www.opendrivers.com/driver/214283/mag-lcd-monitor-drivers-windows-95-98-2000-xp-me-nt-free-download.html
heres the driver that you needed for your monitor
I can’t find where the AC power cord plugs in on the back of the monitor. Answer There are two places where the AC connector could be found.
1. Look at the back of the monitor right next to the signal cable connection.
2. If the signal cable does not detach from the monitor, follow the signal cable to the end, and you will see the 15 pin D-Sub connector (blue connector). There you will find a small hole with a pin inside (in between the two notches).
May 26, 2008 | Mag Innovision LT576s 15" Flat Panel LCD...
Star Logic 17" LCD Monitor Logo
856 people viewed this question
Top Star Logic Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
Jerry Umali
ray gallant
Are you a Star Logic Computer and Internet Expert? Answer questions, earn points and help others
