Question about Sylvania SRT2232S 32" TV
SRT2232S 32" will not respond to any remote control
Tv will not respond to any remote control..i believe the sensor has went out. Do you know if that's the problem and if it is, should i fix it or toss it.
  • rgosselin509 Aug 25, 2008
    I have the same problem remote does not respond to any input.
    Remote unit does work with different model Sylvania.
    There is no dust on the input sensor.
    I removed the circuit board and resoldered sensor connections.
    Initially remote unit worked ramdomly and then finally stopped completely
  • 10,594 Answers
There are 2 reasons of this problem, check TV remote control, is it working or not?
2nd reason, there can be dust in your TV, aspeacially in front of remote sensor, this can be the cause of No Remote Signal Receive.
Posted on Jul 27, 2008
The sensor is not working right on my Sylvania SRT2232S 32
Remote sensor can be tested with set powered up--usually three leads where it is soldered in---with a meter one is voltage, one ground, one signal----check for the voltage with a meter but a scope is needed to test the signal.
Oct 29, 2012 | Sylvania SRT2232S 32" TV
What is rca remote code for sylvania model srt2232s
Hello
Four digit codes for Sylvania TV with RCA RCR 311W remote control are:
1003, 1004, 1014, 1046, 1051, 1060, 1061, 1062, 1066, 1067, 1072, 1073, 1074, 1075, 1076, 1077, 1078, 1082, 1150, 1151, 1165, 1192, 1199, 1206
Five digit codes for Sylvania TV with RCA RCR4373N remote control are:
11864, 10054, 10030, 10171, 10096, 11271, 11314, 11394, 11963
OK.
Sep 29, 2011 | Sylvania SRT2232S 32" TV
My 32" won't turn on
Hello
Without its remote control, you can't unlock this TV. Get into this link from where you can buy it.
www.emtcompany.com/sylvania-srt2232s-remote/rc64.html
The price quoted is $19.95 [Shipping free]
OK.
Sep 28, 2011 | Sylvania SRT2232S 32" TV
My LG TV does not respond to the remote control. I have two of the same TV and the remote controls works fine for the other TV, so I know its not the remote control. I believe the problem is with the tv....
Try using a small miniphone plug such as headphone and plug it into the remote sensor jack on the back, do that a couple of times to clean the contact switch inside, see if that will work first, if not, then you may have IR receiver board problem. Please post back.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Sep 22, 2010 | LG 32LG30 32 in. LCD HDTV
Sylvania tv srt2232s picture is dark. i have used the remote gone to pictureand still unable to adjust brightness. need your help to adjust brightness. What do i need to do to change the brightness
Hi
Remove back fron tv locate line flyback transformer
on this transformer there should be two adjustment controls very carfully adjust the bottom one, do not adjust to far as picture will have fine white lines on it
May 17, 2010 | Sylvania SRT2232S 32" TV
Philips universal remote control code
Without knowing the model number of your Philips universal remote control I can't be exact with the code but generic four digit Philips codes for Sylvania tv's are:
Try these different codes
0807 0002 0502 0115 0520 0919 0324 0247 0402 0408 0109 0715 0717
Hope this helps, James
Apr 23, 2010 | Sylvania SRT2232S 32" TV
The television has stopped responding to its remote and a cable remote.
Hello SKrokau:
Have the IR sensor (Infared Sensor) replaced in this model. It is a common failue for Sylvania televisions. The IR sensor is the device used to receive commands from the remote and relay the commands to the microprocessor for processing. The sensor is very inexpensive and the total to repair should not cost you more then (FYI) $80.00 for parts and labor.
Have a Happy Holiday!
Nov 22, 2009 | Sylvania SRT2232S 32" TV
Infrared on tv not working or sporadically with any remote that is working with all other equipment (i.e. dvd...). Where is sensor, how to clean
to see the infrared i would recommend you to read the article at http://www.unique-stuff.co.cc/fixing_remote_control_check_infrared.html
this way you can ensure if the infrared is emited normally from your remote control, afterwhat you can decide what to do.
Nov 15, 2009 | Sylvania SRT2232S 32" TV
Innovage jumbo remote locked up my sylvania tv
I suspect you have simply switched to an unused input. If you use the original remote you can probably switch the input readily back to what you want.
Dave
Jul 04, 2017 | Sylvania SRT2232S 32" TV
Sylvania model# SRT2232S no manual
Did you get an answer to this. My daughter bought a used TV w/o remote and wants to view DVD only.
Apr 29, 2008 | Sylvania SRT2232S 32" TV
Sylvania SRT2232S 32" TV Logo
267 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
