Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Setup Hi, I cannot get into my ADSL model / router for me to setup. When I connect the network cable to the laptop, I should be able to access the following IP address 192.168.2.1 according to the setup manual. If I do that, I only get limited connection and the IP that's assigned to my laptop is 169.254.18.217. I have tried to reset the modem but also no luck. Can anyone help? Many thanks
  • 2 more comments
  • Chattie Jul 27, 2008
    did try to reset the router/modem by presing the reset button for longer than 10 seconds but stil gets the same problem.
    yes it was
    yes it was
    I have tried but still no luck. At least I dont get a limmeted connectivity after changed the ip. I only have 1 reset button. my model is n Belkin F5D 7633-4.
    Genius:
  • 1,056 Answers
If that is the report that the laptop gives for an IP address, then you have to change the IP address settings.
Go into your network settings, and tell it to automatically aquire an address, and DNS.
Once you click OK, it should sense the DCHP from the router.
If the IP is already set to automatically aquire, then the router needs to be reset to factory defaults. That should put you back to the 192.168.2.xxx settings.
Posted on Jul 27, 2008
  • Coss Jul 27, 2008
    Did you look at the IP settings in the laptop? Was it set for "Automatically aquire?"
  • Coss Jul 27, 2008
    THere are 2 buttons on the back of the router, one that says reset, which is next to the wired jack outlets, the other push button is a reset for wireless.
    Did you see it go through the LED flash sequence after you pushed and held the reset? If it did, and it still will not do a correct DHCP grab, there is one other thing to try.
    Go into your network settings on the laptop and set the IP address to 192.168.2.5 Subnet to 255.255.255.0 and the gateway to 192.168.2.1 DNS doesn't matter (if you want, set it to 4.2.2.2 & 4.2.2.5) Click OK, and OK to exit the network setup.
    Click on START>RUN and type in CMD and hit enter.
    In the DOS box, type in " ping 192.168.2.1 " (without the quotes) and hit enter. If you get a response line of information,
    open your browser and go to 192.168.2.1 and go through your configuration.
    If you get a "Request Timed out" I would return it to the point of purchase, and ask for a replacement.
NEED CD INSTALLATION
You don't need an installation CD to setup the wireless but you do need the ADSL settings from your Internet provider to configure the ADSL modem.
Connect a LAN cable from the D-Link to your laptop/computer's LAN port, open the browser on your laptop/computer and enter the D-Link's configuration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter) You can now change the default admin password.
You can now configure the wireless settings. (WPA or WPA2 encryption to protect your wireless network and Internet from unauthorized access). Now configure the wireless card in your computer/laptop with the router's wireless settings. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security .
Jan 02, 2013 | D-Link ADSL2/2+ Modem/Wireless Router...
I've had a new laptop but require my security key, model WBMR-G54 to access the security enabled network, from my old laptop.
If you've forgotten the wireless security key you entered when you set up the router you can reset it by connecting to the router directly with an ethernet cable instead of the wi-fi. Plug a cable into the router and then laptop and access the setup page for the router. See the manual (or download one from the buffalo site) for setup instructions.
Dec 27, 2010 | Buffalo Technology Buffalo AirStation...
I need to complet my router setup
Have you secured your Linksys from unauthorized access?
The encryption code protects your wireless router from unauthorized access. The wireless card in your computer/laptop needs to be configured with the router's encryption settings before the computer/laptop can access the router.
For details on configuring the wireless router and the wireless card, please click on this link and follow my instructions :-
Jan 06, 2010 | Linksys Wireless-G WRT54G Router
Just bought PB Ixtreme x5620. i am trying to connect my virgin broadband to the pc. i have netgear router which has the yellow cable in the moden and router and the blue cable in the PC and router. i can...
Can you supply more detail of your network setup? You have a broadband modem, a seperate router and the PC.
For this setup cabling should be ....
1. Phone Socket (Pref. Master socket) to ADSL socket on modem
2. Modem LAN socket to Router WAN socket
3. Router LAN socket to PC Ethernet socket
Usually in this configuration you will have to switch off DHCP on either the modem or the router as they may both be trying to supply IP addresses to your PC. I would suggest disabling DHCP on the router and leaving the ADSL modem to supply IP addresses. If you do this you will have to setup the Router with a valid fixed IP.
Have fun!
Cheers,
Ripface.
Oct 25, 2009 | Computers & Internet
Dlink help!
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. . here are the steps u need to do:
1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet.
b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url:192.168.1.1 and u can setup the wireless settings, u need to create a ssid or wireless name and a security..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe
6. If ur isp gives u a static ip address settings, u need to set the router to isp setup.
a. how to check the isp of the isp given to u..
1. click on start
2. run
3. type cmd
4. it will show a dos prompt
5. from the dos prompt type ipconfig/all
6. it will list the ip address, subnet, default gateway, dns server
this settings should be type in to the settings on the router for static ip addressing..
7. Once your done on the internet setting, go to your wireless connection settings and you can create a wireless network name or ssid, set a security by selecting wep, wpa, wpa2.
8. once all is set. save the settings and to check if your laptop can access the wireless network that you did, turn on the wireless switch of your laptop, once its on, it will show the wireless network icon on the lower right of the taskbar, right click it and select on view available network, the network name that u did should list, just select it and connect and it will ask for the password, just type the password and connect, you should be connected to the wireless network and have internet access..
9. If you are going to hook up your desktop to the wireless connection, you need to install a wireless network adapter, install the driver and do the same thing as u did to the laptop, for the desktop no need of turning on the wireless switch, once you install the driver correctly, it will show a network icon..
if you have any query pls feel free to get in touch.. good luck
Oct 20, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
I have a toshiba laptop, already have existing computer all set up but having trouple conncted laptop to wireless. Have adsl modem and tp link router. tp link is asking or network key to be able to...
Your wireless network is secured and thats why its asking for the network key. If you dont remember the same, contact your router manufacturer or ISP and get the router reconfigured
Jul 03, 2009 | Computers & Internet
We've just moved house and have aquired to belking routers a belkin wireless pre n and a belkin ADSL G Plus MIMO I want to use the latter as a bridge how can I?
You need to access the setup page of your Belking router and go to the wireless setup, look fro Use as Access Point, now just a reminder this will defeat the NAT IP sharing feature of the router. Configure the IP address of the router to the same subnet as the network your tying to bridge here's the more detailed procedure:
1. Enable the AP mode by selecting "Enable" in the Use Access Point only page. When you select this option you can now change the IP Settings.
2. Set your IP settings to match your network. Click "Apply Changes"
3. Connect a cable from the LAN port of the router to your existing network.
Sep 18, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Several Router problems
It sounds like an ADSL signal strength issue. Test that it is not a problem with the ADSL phone cable setup, using the shortest ADSL/Phone cable you can find (under 1Meter is best)unplug all other phone line using devices and filters from the wall jack points and test the routers connection again as the only device plugged in(this is Isolation testing) If the issue replicates itself under isolation testing conditions then ring your ISP providor and request that the "ADSL signal voltage" needs to be increased slightly as your router is not hearing the ADSL signal properly. If the issue doesn't replicate itself under isolation test conditions, you are either using an old or bad ADSL/Phone cable or your cable is too long (should not be longer than 5meters)or if you are using a wall socket/splitter for direct adsl access (without filters)then test the socket with a filter to verify the socket/splitter is not the cause of the problem, if you do use phone filters, during isolation testing, test each of the filters individualy with the router and see if the disconnection issue is replicated if so replace the bad filter the disconnection issue was being caused by phone signal interferance. Your third request requires you to setup the LAN info on the windows side of your connection not the wireless card, this can be verified by searching for websites via thier IP address which will work, when searching via their website name wont, DNS resolution issue, it is probably best practice to use MAC Addressing for your wireless setup though.
May 15, 2007 | Trendware TEW-452BRP Wireless Router...
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
117 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
