I have a Canon Rebel EOS camera giving me an err99 message. I can fix it long enough to take 2-10 pictures by removing the lens, taking out the battery, messing with the shutter and taking out the memory chip. However, it doesn't solve the problem.
Err 99 is a general error msg. That is, it has to be connected to the service soft that only Canon self or an ASF has, to know more precisely the problem. To narrow the possibilities; -choose Av, shutter priority, -choose the smallest aperture your lens allows, 22 or 29 or so, -while pressing and releasing the depth-of-field preview button, (front, under the lens release) look into the lens from the front. If the diaphragm doesn't move it has to be changed. If you have the 17-55 standard lens; throw it away and buy a better one instead of paying a repair. You'd be better off.
If you have the Err msg with several different lenses the problem is in the body itself, often the shutter. Check also your PINs in the CF-slot. If one PIN is toching another; break off the bent one and normally you can go on, the PINs are almost all doubled.
I am trying to replace date-tie battery in Digital Rebel 330D. I can't find hoie to get the old...
(More)
I am trying to replace date-tie battery in Digital Rebel 330D. I can't find hoie to get the old battery out even though I followed instructions
my daugher was taking pictures with my canon digital camera rebel, EOS 300D taking picture and...
(More)
my daugher was taking pictures with my canon digital camera rebel, EOS 300D taking picture and camera was working fine, she sat it down picked it back up to take another picture then only a slim strip of picture on the top comes out but the rest looks to be blocked and is blacked out. The screen is working fine. any ideas?
Looking for the name of the part behind the mirror but over the ccd that folds away just prior to...
(More)
Looking for the name of the part behind the mirror but over the ccd that folds away just prior to taking a picture. When I hold the camera upside down it folds away because of gravity. I am just looking for the technical name for this part.
My Canon EOS Digital Rebel LCD Screen just shows an all-white display instead of picture preview. ...
(More)
My Canon EOS Digital Rebel LCD Screen just shows an all-white display instead of picture preview. The same when I turn it on. This happened while I was using it. I set it down to use another camera and the display went white when I took another picture.
