Question about Logitech G25 Wheel And Pedals Set
G25 causing weird audio
When i plug steering wheel in the audio becomes distorted. it wil return to normal only after restart.
  • 1 more comment
  • graham 2008 Dec 05, 2008
    when i plug the logitech g25 into the usb port and after it does its little spinning act the sound goes distorded i have tried unpluging it but still it is distorted untill u restart the computer and leave it unpluged.
  • Anonymous Dec 16, 2008
    I have same problem. I tried play without drivers and it worked, but it didn't regonized gears, so i had to install divers. After i installed them, my whole audiosystem went really bad.
  • Anonymous Mar 19, 2009
    well same here when i istall software sound goes crazy. i am working with tech support on this issue. grrrrrrr
I found out it was my mouse and keyboard ( both wireless ) that made my sound distorted, i am using old style cable mouse and keyboard now and sound is fine.
Posted on Feb 14, 2009
I have Logitech G25 Racing Wheel ,pedals,gear and buttons working ok but steering does nothing!It is recognized by usb connection but not works. I read all the solutions here but nothing helps.
The best way to tell is to do a calibration test and if it is not recognizing your wheel than you may want to send it in to logitech. The g25 is a gear driven wheel and maybe something went wrong with them on the inside.
Jun 02, 2011 | Logitech G25 Wheel And Pedals Set
Wheel keeps turning round by itself
Hi, If this happen when you plug the G25 into a usb and power supply this is normal behavior, it recalibrate itself.
This should happen for maximum 15/20 seconds. If the G25 keeps turning round itself after, then you should contact Logitech support for a replacement, this is an hardware failure that is covered by the warranty. http://www.logitech.com/en-us/contact Thanks and have a nice day
Julien
Mar 29, 2010 | Logitech G25 Wheel And Pedals Set
Logitech g25 steering axis not working wheel returns to center
to chk the sensor on the calibration unplug the wheel from the usb port and plug back in if the wheel turns left then right and centers the sensor is fine. go to the control panel>game controller>properties and test the wheel if everything is working there it is a problem with the game. look for a profiler or calibration utility in the game itself to bring back to center.
Jul 17, 2009 | Logitech G25 Wheel And Pedals Set
Logitech G25 steering wheel Resets from time to time
These wheels I have no experience with, but my gues is if it uses batteries or plugs in, the batteries are dead or the plug is losing connection.
Feb 17, 2009 | Logitech Video Game Consoles & Games
Logitech Driving Force GT wheel won't work at all
Ive had this problem yesterday. Confirmed.
Call them to have words. Have respect and they refund you full.
Towards the G25.
I did that. Cause if I broke 1 DFGT then I will break more.
I think that the G25 withstands even drifters technique.
See you on PS3 Tag: DriftMagnet
Logitech Tech Support. Call 1-646-454-3200
Jan 10, 2009 | Logitech DRIVING FORCE FEEDBACK STEERING...
Using 2Logitech G25 steering wheels on Playstation 3
play gran turismo 5 prologue it has 2 player and is compatiable with the G25
Dec 12, 2008 | Logitech G25 Wheel And Pedals Set
G25 and NFS Undercover
I had the same problem with my steering wheel and my gamepad. I fixed the problem by installing the new patch available here: http://needforspeed.com/portal/site/nfs/news/details/?contentId=196a93dca5c5f110VgnVCM100000100d2c0aRCRD Just download the patch, double click the file, let it install, and start up the game. This worked for me. I hope it helps. Good Luck!
Nov 17, 2008 | Logitech G25 Wheel And Pedals Set
G25 wheel not responding
Hey! I had a similar problem! Only the weel tried to calibrate itself, but itjust "twitched"
So I tried replacing the power cord with a similar one from an older wheel. Didn't work for me.
I opened it up and voilá, same problem as "epicname"! I tightened the screws on the optical sensor and put it back together. Now it works like a treat! So i guess if it's the power cord it won't react, If it's the optical sensor it will twitch, notice it doesn't get a signal and give up from there.
I don't know if this will really help anyone, as they would just send it back to the shop and get it fixed for free. But couldn't find the reciept, and often find it's better to fix things myself than to let the local shop send it to their usual place.
THIS IS JUST A LAST RESORT!! ALWAYS TRY TO GET THE WHEEL REPLACED OR FIXED PROFESSIONALLY!!!
Remove all the screws underneath, even the larger black ones. Remove the steering wheel by unscrewing the bolts on the front panel and the three larger screws under the little circuit board in the wheelhub.
Remove the bonnet. theres a black box on the left engine wich contain the sensor. If it's loose you're able to rattle it. If you're not, the sensor is most likely not the problem.
Unscrew the mainboard and remove the bracket it sits on.
Now the Force Feedback rig should be loose.
Flip it over and pop off the little black cap on the sensor(it's just pushed on)
Put some locktite on and fasten the two screws that hold the sensor mount (unscrew and remove the sensor board so you can get to the last screw)
Put everything back together.
Sep 15, 2007 | Logitech G25 Wheel And Pedals Set
G25 ps2/ps3 no steering..buttons & pedals ok
Hi Guys, I have found your solution. If all the buttons work, but the steering does not, it's because the buttons are powered by the USB bus. The electric engine of the wheel need really juice from the power supply. I have just bought a G25 and all the buttons worked fine, but turning the wheel was completely undetected. The power supply was cold as a supermodel heart. I have just put a new power supply and now all the things work perfectly. By the way, my thanks to all the other guys that posted the G25 issues, it really helped me out.
Enjoy your driving !
Petro
Sep 02, 2007 | Logitech G25 Wheel And Pedals Set
Logitech G25 Wheel And Pedals Set Logo
146 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Rob boss
Level 1 Expert
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
