Question about Brother HL 5250DN Laser Printer
HL 2070 Printer Toner light will not go off
My brothers laser printer is having the same problem as others. I replaced the cartridge but the toner light continues to stay on and the printer will not print. I tried the reset process described by other users but it was not successful. Any suggestions
  • 1 more comment
  • Anonymous Jul 28, 2008
    We have three of these in our offices and two of them began having this same problem within a few weeks of each other. No solution so far.
  • Anonymous Sep 08, 2008
    Same problem. Toner light is on, new toner installed, toner light is still on and it won't print.
  • Anonymous Oct 03, 2008
    i havea the same problem I get a few pages then the light comes on and it stops printing. If I shake the cartridge it goes for a few more pages and stops - a pain in the but really
    Problem Solver:
  • 7 Answers
Ok, I’m going to try and explain this without pictures:
Take out the toner and look at it. One end has 2 silver screws in it. As you are looking at the toner from the front (transfer roller pointing at you) the screws are to the right. Remove these screws and so remove the face-plate. There is a white gear-wheel (without cogs/teeth) that looks a little like a Y. This simply lifts off; behind it is also a metal spring. Remove this gear and the spring. Now replace the face-plate and the 2 screws without the gear and the spring. That’s it. Put the toner back in and print until no longer possible as the light will not show when it really is empty.
Hope this helps.
rigsby
Posted on Dec 23, 2008
I have a HL 2070 Brother printer That that toner light will no go off, I replace with a new toner and after that did not keep working, I tried to reset the toner opening the front door, also holding the go...
Hi there!
You can remove the drum and toner, remove toner from the drum unit then gently rock the toner from side to side for about six times to distribute the toner inside, then on the drum unit slide the green tab on the upper left hand from left to rigth for about six times and then put it back to the home position. Reinstall the toner back to the drum unit and then put the drum and toner back to the printer. closed the front cover. the toner light should turn off,
Hope this helps.
Mar 28, 2011 | Brother HL 5250DN Laser Printer
Brother HL-2070N Laser Printer Will Not Print
First of all, I checked the answers given here, but nothing worked; everytime I turned on the unit, the red light flashed that the printer was out of paper.
From the Brother's HL-2070 manual, in the troubleshooting section: take out the toner cartridge from the front of the machine (be careful, any black toner powder that come off may be very difficult to clean up). I took the toner cartridge to the sink.
There is a blue slide along the top of the unit that will clean the corona wire if you slide it back and forth, from one end to the other (toner/dust can become caked on the wire over time; sliding the slider back and forth simply knocks the caked off 'stuff' off of the wire).
Replace the toner cartridge; it worked fine for me. I was immediately able to print.
Mar 11, 2010 | Brother HL-2070N Laser Printer
Brother HL-5250 printer toner Light on but Cartridge has Toner it
Try this....
1: Turn off power and remove toner/drum
2: Tape the little spring loaded lever just inside the printer on the upper left hand side in the *DOWN* position! Do not replace drum yet and...
3: Turn power on to printer and let it cycle. Status/Toner lights will come on as usual.
4: Turn off printer, remove tape from lever, replace drum and turn back on.
Mar 08, 2010 | Brother HL 5250DN Laser Printer
Low print quality
It depends upon the number of prints you have done since Feb and the toner cartridge capacity. Some toner cartridges have 2500 page capacity others have 5000 pages or more.
If you think you have not exceeded or reached the cartridge capacity, take it out of the printer and give it a shake in a horizontal position to distribute the toner evenly across the drum and place it back in the printer. This also works when the toner is nearly empty.
Sep 09, 2009 | Brother HL 1440 Laser Printer
Brother Laser HL-5240 has a status light and toner light. Fuser was replaced but no help.
that error usually indicates that the toner has reached its end of life
or the drum is not properly installed.
i had one person who put the toner in but threw the drum cartridge away.
Jun 25, 2009 | Brother HL 5040 Laser Printer
Replaced toner cartridge and light stays on the printer will not
how do i set the toner reset lever on a brother hl 5250 printer
Mar 31, 2009 | Brother HL 5250DN Laser Printer
HOW DO I REMOVE SPEND TONER IN HL 2070 N and insert new toner
open front cover, pull out drum/toner unit, press lever to release toner, put in new one,and replace.......ta-daaa
Mar 04, 2009 | Brother HL-2040 Laser Printer
I have a brother HL-2070 laser printer and have just inserted a new toner cartridge. When I turn on the lase printer it is coming up orange light toner & will not print. Its as if its not recognising...
Have you tried shutting down and restarting after the cartridge was in?
Also at Brother there is a new driver download for your model, and other info.
http://www.brother-usa.com/SiteSearch.aspx?sk=hl-2070%20manual
May 01, 2008 | Brother HL-2040 Laser Printer
Brother HL-1440
(blinking every 5 seconds) Toner Low Indicates that the toner cartridge is nearly empty. Purchase a new toner and have it ready for when Toner Empty is indicated. (solid) Toner Empty Replace the toner cartridge with a new one. User's Manual is available at the following location: http://www.brother-usa.com/Data/Documentation/Printer/User/UM_HL1440_1450_1470N.pdf Hope this helps.
Aug 22, 2007 | Brother HL 1440 Laser Printer
Brother HL 5250DN Laser Printer Logo
507 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
