Question about Lexmark X1240 All-In-One InkJet Printer
Scanner DPI issues
I am trying to scan a section of a photo using the max scan dpi of 19200, but it comes up with 'scan file size is too large for the available virtual memory'
I can't see how this is possible as I have a 3.2G quad core, with 4G ram and 2Tb disk space with 200G dedicated to virtual.
I also get the message 'file size is too large for the available drive space' when I try the entire photo. The photo only comes out to 36Gb, that's pennies compared to 2000Gb space!!
Is this a glitch in the driver software? any help would be appreciated.
  • 48 Answers
Well..that's fine, but the virtual memory dance, is not just about size(which we all know is not the only issue, right)?..smiling.
at any rate, you'll need to allocate the VM to this function through your admin panel. You familiar with that?
Also, more printer resources are here
Posted on Aug 21, 2008
How do I reduce scan file size when the resolution is already 200 dpi?
An 8.5 inch wide document scanned at 200 dpi gives you an image that is 1700 pixels wide. This is almost enough to fill a fullHD TV screen at native resolution (1920 pixels wide) which is unnecessary detail. I would use any picture editing programme (many free ones available) to reduce the overall pixel width of your already scanned images by 50 percent. This will automatically reduce the 1MB image to 250k. If you can scan again, use 100 dpi to scan - the result is same; image will be half as wide (and long), and picture file size one quarter of the 200 dpi scan.
Sep 12, 2017 | Samsung CLX6220FX AllInOne Laser Printer
LPI, PPI,DPI conversions
Here is a conversion chart for DPI (Dots per inch) to LPI (Lines per inch) or PPI (Pixels per inch)
180 DPI................31 lines/inch or 68 PPI
360 DPI................63 lines/inch or 138 PPI
720 DPI................127 lines/inch or 280 PPI
1440 DPI..............255 lines/inch or 561 PPI
2880 DPI..................510 lines/inch or 1122 PPI
If you plan to enlarge your image, it is better to enlarge it when you're scanning rather than in your application. Each time you modify
an image, you lose some quality. Keep in mind when you enlarge a small photo, such as a 35 mm slide or wallet-size photo, you'll need
to scan at a high enough resolution to retain your image quality, but not so high that your file size is too large to be efficient. You must
manually adjust the resolution (dpi) to maintain the same image quality when you resize your image. For example, if you have a 300
dpi 2 x 2-inch image that you want to enlarge to 4 x 4 (a factor of 200%), increase the Scale setting to 200% or change the resolution to 600 dpi.
on Jul 19, 2008 | Epson Perfection V200 Flatbed Scanner
Slow save on pdf file with capture perfect3
Change the scan resolution to 200 dots per inch (200 dpi). If 300 it tajes a few seconds. If 1200 dpi, it may take really long.
Jul 29, 2014 | Canon DR-9080C Path-Through Scanner
How do I scan 35 mm slides on my C3180 all in one printer/scanner?
Scan specifications
? Image editor included
? Integrated OCR software automatically converts scanned text to editable text (if installed)
? Twain-compliant interface
? Resolution: up to 1200 x 2400 dpi optical (varies by model); 19200 dpi enhanced (software)
? Color: 48-bit color, 8-bit grayscale (256 levels of gray)
? Maximum scan size from glass: 21.6 x 29.7 cm (8.5 x 11.7 inches)
Aug 10, 2010 | HP Photosmart C3180 All-In-One InkJet...
Brother MFC9440CN scan resolution
Yes you do this from the application that yu are using to do the scan. Chooese the setup or preferences tab for the scanner in the app and you should get a list of available optical resolutions from 75dpi, 100 dpi, 200dpi, 300dpi, 600dpi, 1200dpi upwards.
The optical resolution is 1200 x 2400dpi max and interpolated (from software) is 19200 x 19200 dpi.
Nov 11, 2009 | Apple ~:~ BROTHER INTERNATIONAL CORP ~:~...
Scanning files to large
It's the resolution you are using to scan. Try a lower setting. for documents, 150-200 dpi is fine. That will produce smaller files.
Aug 25, 2009 | Dell 922 All-In-One InkJet Printer
Need to get scanned photos to between 300 and 600 dpi
What I saw first off is that although the resolution indicates 96 DPI, the file size itself between the 2 examples are drastically different. You are putting raster images into MS Word for publication work, and that is a NO NO. Word was not created for any kind of high resolution printing. It's a glorified text editor that people seem to think is an option for printing. YOU WILL NEVER GET 300 or 600 DPI images out of Word. Ever.
To create your project for printing, you need to use software more suited for the task. InDesign and Quark are examples, but they are very expensive. In my opinion, Publisher would be better for this kind of project and I hate myself for saying that.
Talk to your Printer, find out his specifications for Applications and Linescreen for Printing. The minimum requirement is 280 DPI, but if the image is placed at 100%, 600 DPI is overkill.
Oh, and try to never scan a scan... you are looking for trouble... a little thing called a Moiré pattern comes into play, and it will make you images print NASTY!
I could go on about your post all day long, but if there is anything else I didn't explain, please post again.
Jan 21, 2009 | MGI Software PhotoSuite SE V4.0
How to change to a higher resolution on a mfc-240c
Hi tammy, you can either use the Windows printer driver which will allow you to set scanning resolution up to 1200 dpi which you can access through a program like Photoshop (File--Import) or the Brother Scanner Utility to go up to 19200 dpi resolution. If for some reason you don't have the scanner utility on your computer, you may have to install it from the disc that came with MFC-240. If you need further help let me know.
Oct 23, 2008 | Brother Multi-Function Center MFC-240C...
Scanner Creates a Very LARGE PDF file 1.8 meg for one page
I have an old X7170 and have the same problem when using the doc feeder. I scan using the flatbed the size is much much smaller.
May 05, 2008 | Lexmark X83 All-In-One InkJet Printer
Lexmark X1240 All-In-One InkJet Printer Logo
63 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
