Question about Dyna-Glo D-E37 Wall Mounted Panel Heater
Thermocouple how many millivolts should a thermocouple in a pilot flame be?
  • 304 Answers
I am assuming you are talking about a type K ( Chromel, Alumel ) type Thermocouple. A junction of these two alloys ( welded together by capacitance discharge) produces 41 micro volts per degree Celsius. As the flame from a perfect air/gas mix produces a flame around 1900 C (propane), and 2000 C (natural gas) . You can simply multiply.
41uV X 1900 = 779mV For propane
41uV X 2000 = 822mV For natural gas
This should give you a pretty good Idea of what you should be looking for. If you are using a standard volt meter to obtain a reading. Touching the leads of the probe to the leads of the meter in affect creates two more thermocouples unintentionally. This will alter your reading only slightly due to the fact that the temperature will be at relatively negligible at the contact points.
Allowing for this distortion you should expect a reading +/- 50mV either way. I hope you find this information helpful. Please take the time to rate this fixya for me. To compensate me for the 4 years of my life I spent cramming weird stuff like this in my head in college and the 5 minutes I spent typing this out for you for free. LOL If you ever need my help select me as one of your experts and I will help you for free.
George
Posted on Jul 28, 2008
  • George Kohler
    George Kohler Jul 28, 2008
    If you give me the exact type thermocouple you are working with and what gas the heater uses, I will calculate the exact reading you should be reading. I think the above estimates should be accurate enough for your purpose though.
    Thanks Again,
    George
My gas richmond water heater quit working, replaced thermal coupler light pilot good burner lights and goes out
Did you get the thermocouple positioned so the pilot flame just touches the side of the thermocouple sensor? Is the pilot flame blue with a slight orange tip? Did you use an exact replacement part? Not all thermocouples produce the same millivolts needed to keep the gas valve open. If you think all of these items are correct, then the main gas valve is defective.
Jul 28, 2017 | Water Water Heaters
The pilot goes out when the heater cycles
The thermocouple is not working correctly. sometimes you can clean the soot build up from it and it will work again. sometimes they just need replacing. the thermocouple is what the pilot light flame heats up when you turn on the heater. when the thermocouple gets hot it sends a 20 to 60 millivolt signal to the gas valve to activate the gas flow to the main burner.
Feb 18, 2015 | Williams Wall Heaters: 50,000 BTU/Hr...
Change thermocouple burners goes off
Thermocoupling is not set properly. approximately 1/3 to 1/2 of the thermocoupling should be engulfed in the pilot flame. Best to use a meter and set the thermocoupling at approximately 30 millivolts. The pilot assembly and pilot oriface needs to be clean.
Feb 04, 2014 | Goodman GMS90703BXA Heater
Where is a flame sensor located on a laars lg millivolt pool heater
first of all millivolt heaters dont have an actual flame sensor. flame rods are located in the electronic ignition models. The only "flame sensor" millivolt units have are the pilot generator or thermal pile. it also works as a safety, no pilot flame = no dc current, heater wont run
Nov 04, 2013 | Teledyne Laars Laars Lite 2 Pool Heater...
MY pilot is on but no voltage to gas valve
are you using a millivolt meter ,check to see that flame goes around thermocoupler if so replace thermocoupler if flame does not reach thermocoupler then the thermopile need cleaning
Jun 08, 2013 | Heating & Cooling
Will lite but goes out within a min
Make sure the thermocouples not fully engulfed in flame, it needs to be on;y at the tip end as they operate via temperature differential acrosss the thermocouples surface, if the whole thinfs one temp it drops out electrically(makes 30 millivolts) and the electromagnetically operated pilot safety valve closes, thus stopping the main burners operatin as its sensing no pilot exists. try a new thermocouple, about 15 bucks, and set it as described in pilot flame, if that wont do it, the gas valves bad.
Nov 01, 2010 | Blue Rhino ES200209 Open Flame Gas Patio...
I go thru the process of lighting the pilot light following the directions exactly, but as soon as I let the pilot light switch pop out so that I can turn it to the left to light the heater the flame goes...
The system works off of a thermocouple that is heated by the pilot. The thermocouple creates millivolts that magnetize a head behind the control knob. When you push in the knob the magnetized head behind the knob holds the gas valve open. So obviously the head is not being magnetized. First make sure that the pilot is not plugged and the flame is large enough to heat the thermocouple. Also sometimes you may need to hold the knob for several minutes before the pilot will stay on. Also patio heaters have a safety feature that will cut the millivolt circuit if the heater falls over. It is possible that this safety device is tripped or defective causing the pilot to not stay lit. Also check for any loose wires on the millivolt system.
Dec 21, 2009 | Endless Summer UniFlame (GWU501E) Open...
Pilot light won't stay lit when you try to turn control knob to thermastat. Is it the thermocoupler, the control valve or the pilot assembly?
Once your pilot is lit the thermocouple sends millivolts to the gas valve to tell it that the pilot is lit and to allow the gas valve to open. Check to see if your thermocouple is in the pilot flame. I f it is then you will need to replace the thermocouple.
John
Oct 03, 2009 | Heating & Cooling
Pilot light won't stay lit.
most common cause of the described symptom overheating the thermocouple! a thermocouple produces millivolts of electricity based upon a differential of temperature between the tip and the base. If it gets too hot it will not work correctly. If the pilot flame is too large or the main burner flame is contacting the thermocouple or the thermocouple is too cheap or old all can cause this issue.
Dec 18, 2008 | Heating & Cooling
Dyna-Glo D-E37 Wall Mounted Panel Heater Logo
322 people viewed this question
Top Dyna-Glo Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dyna-Glo Heating and Cooling Expert? Answer questions, earn points and help others
