Panasonic PT56WXF95 16:9 Rear Projection HDTV Red, Green and Blue will not line up. Red color looks very dim and blue color is mor pronounced to the right. Try to fix it by the convergence system and the color is off differently from right, center, left, top and bottom. the TV is 8 years old. What do you think is wrong and a estimated cost to repair it. Thanks Todd
  • ToddBeach Jul 27, 2008
    The resistor is working properly
  • 10,594 Answers
Convergence Output Amp ICs got defective and needs to be replaced. Estimate can be prepared after physical check-up because on website, I assume and understand, what you wrote here.
Posted on Jul 27, 2008
    Brigadier General:
  • 3,614 Answers
Well check the output module, try to check and test the 120k resistor.
  • micromaster
    micromaster Jul 27, 2008
    have you done testing, or have you check the video output module...? try to do so... this may help you...
    thank you for using fiXya...
    micro
I have a Panasonic Multimedia Projection HDTV when tv is turned on it has red & blue color spots & red verticle lines showing on the screen what could be causing this to be happening
Tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignments,have shadows colors pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all it resistors are dead too.These parts on the convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 20, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Is the red lamp the same size for a 53 as it is for thepanasonic
is not the same..but u can try, and then try put red convergence in others colors (blue and green) in service mode..some times works...good look.
Apr 26, 2010 | Panasonic PT-47WX53 47" Rear Projection...
The color on my Phillips 60 rear projection big
that means that the phone needs to be unlock by the network provider
Mar 13, 2010 | Philips 60PP9202 60" Rear Projection...
Panasonic 50": lamp blew, replaced it and ever since the screen looks really dim, even through different outputs (cable, HDMI, Component) and with the brightness jacked up, and it still looks really...
you probably need to clean lens and optics in the light engine.Also if it is a lcd projector inside of the light engine in front of the lcd is a glass color filter one for red ,green,blue they can darken and lose or even change color.I would clean optics and check and clean filters.Or you could replace light engine.
Feb 14, 2010 | Panasonic PT-50DL54 50" Rear Projection...
Panasonic pt-47wx53g red is out of convergence range
Have you moved the TV recently?, if so the red can(Red source) in the back bottom of the TV may have physically shifted in its holder, this is common when a rear projection tv is moved, jostled. Take the back off, look at the three cans,Red, Blue, Green, see if they all look like they are nested the same, bet the red is shifted a little.Good Luck with it!
kskip69
Aug 22, 2009 | Panasonic PT-47WX53 47" Rear Projection...
The color looks off
most likely one of your component cables is loose or unplugged. this will stop one of the colors from coming through, thus throwning off your color. you need to check your red, blue, and green cables.
Jan 02, 2009 | Panasonic PT-56WX53 53" Rear Projection...
Red green and blue lines rca 52' rear proj.
your convergence powert supply is not working-
replace the supply or repair it
Dec 25, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
JVC Model AV-48P575 Green/Yellow Screen
i would check the red color first it sounds like your loosing red
Feb 22, 2008 | JVC AV-48P575 48" Rear Projection...
Most projection TVs have an option to refocus. For example, my Sony rear projection TV has a button on the front for focusing the lamps. Try finding this button or option in the menus with your remote. Projection TVs actually use three lamps, one red, one green and one blue. These need to line up exactly in order to form a good picture, and when they come out of focus, you see the edges which sometimes has the effect of a 3D image when you aren't wearing 3D glasses. Hope this helps!
Sep 07, 2007 | Panasonic PT-53WX54 53" Rear Projection...
How to adjust picture on projection tv
i have a 52" rca projection , and the screen looks like this ") (" on the sides can i do something to straiten it back out?
Aug 28, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
Electro Med Services...
