Question about Olympus FE-230 Digital Camera
Olympus FE-230 Digital problem
Same problem as listed by another "Turn on camera, makes grinding-type noise, then lens goes in and out several times... nothing focuses... when trying to zoom, camera turns itself off." When it's little in and out dance finishes the focusing screen is blurry. I tried to re-set the default setting and nothing helps.
JWH
  • 3 more comments
  • Anonymous Aug 03, 2008
    I am having the same problem of the camera making a strange noise as it is turned on. The lens seems to move in and out several times and the camera beeps a couple of times when this is taking place. It will finally stop but the camera never focuses properly.
  • Anonymous Aug 10, 2008
  • serenamyers Aug 29, 2008
    I have the same problem as well. What the duece???
  • bornlate Sep 20, 2008
    Same as others. When you turn it on, the lens moves in and out and then the camera works, but it will not focus. This behavior began about a month after the one year warranty expired.
  • bobparsons Oct 01, 2008
    1. I have the same problem
    Unit will not focus .. makes noises .. will not open up on shoot mode
    blank screen .. open picture mode then back to shoot OK but still no focus
Someone on here with the same problem mentioned that they shook the camera violently and it fixed the problem of it not focusing. I tried the same thing and actually gave it some light slaps on the tabletop. Well, now it works! I'm somewhat concerned that this fix won't last long.
Like many others' FE-230s, this camera began not focusing shortly after the one year warranty expired. I found my receipt and it turns out that I purchased the 2 year service plan at Best Buy and could get the camera replaced. But, now it works. Will it fail again after the 2 year plan expires? Jeez....
Posted on Sep 21, 2008
My Olympus FE-230 makes buzzing noise when switched on and lens goes in and out and won't switch off and won't focus
Check for specks and chips on the lens first, if there are spots in the images. Take the lens off the camera and look through it at a low-level light source. If there is dust or lint, clean the external elements according to Olympus recommendations. Look through the lens again. If there still are spots, there may be dust on the internal elements. You will need to take the lens apart to clean each lens element. Taking the lens apart is a delicate procedure. Use Phillips-head screwdrivers or the Japanese crosshatch type. Lay out the lens and screwdrivers on a soft, lint-free cloth, and place each part of the lens in the correct order so that you can remember how to replace them. Clean each element with soft lens tissue or cloth or use a manufacturer-specific kit.
Aug 28, 2009 | Olympus FE-230 Digital Camera
Problem with my Olympus FE-230
When I turn my camera on, the lens goes in and out a few times. Once it's finally on and I look at the screen, everything is blurry. When I take the picture, it's blurry too. If I try to use the zoom to adjust, the lens starts going in and out all crazy and won't adjust right.
Jun 20, 2009 | Olympus FE-230 Digital Camera
Olympus FE 230 Problem
I had the same problem. I hit it a long time ago when it did it for the first time. It has been a year since then and it is doing it again. I tried the book solution again and it will not work. I tried holding the lens, no luck, and I tried applying pressure when the lens went back in, again, no luck. Honestly, I don't think I will buy another Olympus fe series camera again. The solutions provided do help the first few times your camera does it, but you might want to start checking the market for a new camera.
Jun 04, 2009 | Olympus FE-230 Digital Camera
When I power on, the lens keeps going in and out repeatedly
Turn on camera, makes grinding-type noise, then lens goes in and out several times...try to put your camera in a table lcd side down and turn it on...while lightly tapping on the sides of the lens. also try to check out this link
http://www.olympusamerica.com/cpg_section/cpg_servicerepair_warrantyinfo.asp
Nov 26, 2008 | Olympus FE-230 Digital Camera
Olympus FE-230 Digital Camera Jammed
Nov 22, 2008 | Olympus FE-230 Digital Camera
Olympus fe-230
lens appears to be off track and needs repair
Oct 06, 2008 | Olympus FE-230 Digital Camera
Grinding sound when camera is turned on
send to repair center...lens is off track
Aug 12, 2008 | Olympus FE-230 Digital Camera
I need help with my FE-230's focusing
in any case where the lens makes a grinding noise, something is in the channel and causing the lens to not extend all the way... you will need to send to a repair shop
Jul 31, 2008 | Olympus FE-230 Digital Camera
Cant take picture
The lens assembly and or microprocessor has failed.
Contact Olympus
Good luck, Paul
Jun 06, 2008 | Olympus FE-230 Digital Camera
Olympus FE-230 Digital Camera Logo
200 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
