When playing back a cd that was burned on my computer I getdistorted sound on some tracks. Usually the last four tracks. I am using an LG burner and the rapsody program and maxell blanks'
  • Carlos44 Jul 28, 2008
    Thank you, I purchased NERO as suggested and will keep you posted. No one was able to tell me that the program can make the difference. Thank you again, I am greatful for your assistance.
    Champion:
  • 258 Answers
Rapsody program has no buffer limit thats y. use Nero
Posted on Jul 27, 2008
Vinpower Digital Vinpower Digital Burner- manual
Please explain what this term means: "copying audio tracks from computer memory". In normal operating you don't copy audio tracks you burn them to the disk using a compatible burning software.
May 15, 2014 | Vinpower Digital Computers & Internet
Windows vista is unable to format DVD+R and with a other burner program I get the following error: 19:17:00, File(cl_DVDData.cpp), Line(193) -> Begin burning process Current drive: <G:...
have had this problem myself and wasted many discs you need a new burner but there is a work around to this problem
just leave the disc open so that more data can be added and no more problems
Jan 05, 2011 | LG GP08NU20 DVD±RW Burner
Cd burner is burning only 1st four tracks of cd's.
are you using a trial program for burning that might allow only a limited number of tracks to be burned?
if its the case you will need the full version or try another program or trial version that doesnt have such restrictions
Oct 22, 2010 | HP (375394-001) DVD±RW Burner
Burner won't work.
please refer to the burning software recommended by product. you can use also nero 6, 7, & 8. for burning cd's & dvd's.
Aug 15, 2009 | LG (GSA4167BB) DVD RW Dual Layer Burner
When playing a burned mp3cd all I get is noise
It is the way it is burned. On the program you are using, it is set for all songs on one track, not sure about the noise. I recommend using windows media player 11. Go to media player, select burn, create list. Then drag all the songs from library to the burn list on right side, and hit burn. That's all there is to it.
Jul 05, 2009 | iLO XM-MP3-CD Car Stereo
DP02 when mastering it says trk too short???????
CDs are formatted like any other format of digital audio.  One of the restrictions of a CD's formatting is a track can be no shorter than 4 seconds.  Usually this happens when there are tracks that were created as part of your project and were not recorded on.  When you try to burn a CD, if one track is shorter than four seconds it will give you that message every time. This is because the standard gap between songs is usually three seconds.  The CD burner's format requires it to check how many tracks there are (another limitation of the CD format is you can only put 99 tracks on a CD) so the burner reads every bit (literally bit) of audio for the gap between tracks.  You must determine the length of every bit of audio on your program and make sure each track is longer than three seconds.    I have been mixing and mastering records on CD for ten years and I still get this problem.  It happens to the best of us.  Don't be frustrated.  Remember a machine will only try to do what you tell it to do.  It wont always tell you what you are doing wrong. It will only do what you tell it to do, or not, if it is impossible.   Go through every track in your project and examine how long each track is.  Read your error message carefully. My burner will say "track 5 is too short". Check and double check. Make sure no track is shorter than four seconds. When you are confident you have corrected the problem. (delete all empty tracks) Then burn baby burn!
Jan 10, 2009 | Tascam DP01 All-In-One Recording Package...
CD Burner Problems
If the source has a blemish so will the one you burn. Check the sample rate. The bigger the number the better the quality
Greg
Nov 29, 2008 | HP Pavilion a1600n (882780776265) PC...
Burning problem
Try burning at a slower speed, like 16x or less. If your burner is a CAV-type, it will burn faster as it moves toward the outside of the disk and can be more prone to errors that way.
Also, have you tried playing the burned disk in another player, and did it show the same symptoms?
Feb 17, 2008 | NEC ND-6500A DVD±RW Dual Layer Burner
Tracking error (LG HL-DT-ST DVDRAM GSA-4081B DVD-RAM RECORDER)
please provide a photo software for samsung sghx620 mobile.
Feb 05, 2008 | Computers & Internet
LG DRIVE 16 HL-DT-ST DVDRRW GSA-4166B
You should have enough memory to burn DVD and it eats a lot of time... Also before burning, close all other applications running as to set the computer for burning your DVD's set it to Maximum priority, which means you should not use the computer when the process starts. Disable also your screen saver and use an appropriate DVD-disc, pay attention to the specification of your DVD drive... If it has a DVD+ then use a DVD-CD that has a "+" sign, Don't burn too much DVD so your burner will last longer or won't easily damage... have it rest for awhile before burning again.
Hope this helps... goodluck..
Jan 23, 2008 | LG (GSA-4166B) (GSA4166BB) DVD RW Dual...
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
