Question about Hoover U5507900 Elite Rewind Bagless Upright Vacuum
NO POWER WHEN I PLUG UP THE VACCUM
I was using the vaccum and it just quit working. There were no smells or wierd sounds when it happened. This vaccum is only 3 months old. Any ideas what's wrong?
  • lrnaue22 Feb 02, 2009
    Mine just stopped too! I am trying to figure out what the heck happened. I didn't get anything stuck in the brushes and it smelt like burnt something. Then I tried plugging it back in today and it still doesn't work. I am hoping it will magically pop back on.
I had the same problem when I first bought mine. I let it set for a while and did some online research. I can't remember the site I went to, but it said that this sweeper will shut off when overheated to protect it and will start back up later. I went back and turned mine back on and it was fine.
Posted on Aug 14, 2008
Why dewalt dc500 vaccum only works for a few seconds
It sounds like the batteries are at the end of their lifespan.
Jun 14, 2014 | Dewalt DC500 Canister Wet/Dry Vacuum
Turn on the power and nothing happened. I checked the power plug. It was ok. what caused the Vaccum didn't work? Thanks, Peter
Same, I have the same issue with this model. Brush motor is working but not the vaccum motor. Any ideas?
Jul 26, 2010 | Bissell Lift-Off(R) Revolution(R) Turbo...
Was vaccuming and vaccum quit. Tried unplugging and turning back on. Getting absolutely no power. unscrewed screw under handle and tried to make sure connection was being made. Don't really know what to...
ok..If you have a multimeter you can check plug fuse then switch and motor, if you put leads across the plug you will get some reading if its working.could be thermal cut out on the motor.
Apr 18, 2010 | Kenmore Magic Blue 24195 Bagged Canister...
My henry vac switch is dead.
You will need to remove the top cover of the vaccum by removing the 4 screws underneath.The you need to test with a multimeter if you have 240 volt power to the bottom of the switch. If you haven,t power there you will need to check the plug connection or replace the power lead.
Jan 08, 2010 | Henry Numatic "" Canister Vacuum
Eureka vacuum cleaner
That means that the belt2_bing.gif is starting to wear. When the belt starts to stretch it can't turn the roller brush against the resistance of the carpet and therefore doesn't pick up well. You simply need to change the belt. Here is a link to the belt you need and to the manual:
Eureka 2961AVZ Belts
Eureka 2961AVZ Owner's Guide (3.4 KB download)
Aug 29, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
My Bissel Vaccum cleaner is making strange noise!!
call the 1-800 number on the back
Jun 11, 2009 | Vacuums
Vaccum Cleaner
You can download the manual here and it will tell you how to replace your belt. I could tell you, but I won't have diagrams which the manual does. Let me know if you require more assistance.
Dec 10, 2008 | Hoover U5172900 Fold Away Widepath Bagless...
Vaccum Cleaner
you probably broke the belt so check that. if the mains cord is damaged, you should replace it
Sep 18, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Hoover U5507900 Elite  Rewind  Bagless Upright Vacuum Logo
297 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
