Question about Maytag M7Y15F2A Air Conditioner
Tried changed settings
Yes, we tried, changing the number setting and the mode and fans settings it, does not change anything, it doesn't, "kick in" if you know what I mean.
    Brigadier General:
  • 3,614 Answers
Yes... how old is the unit now..? have you experience a powersurge or a flactuatiating of power on your area...?
thanks
Posted on Jul 27, 2008
My computer with vista version ,it when to sleep mode( which the screen when black when leave it on for twenty minutes).Can this setting can be fix and how? Many thanks.
Click on the start orb, then click on "control panel". In control panel, double click "power options". Under "prefered plans" the "balanced" plan should be selected (doesn't matter if it isn't.) Click on "change plan settings" then set the sleep time in the drop down box. If you want to drill down a little deeper, click on "change advance power settings".
For future reference here is how to install God mode: http://www.techspot.com/guides/236-windows-god-mode/
God mode tells you how to do just about anything on a Vista or W7 computer.
Dec 10, 2011 | Microsoft Windows Vista Ultimate Edition
We have just bought a home that 3 of the living room/dining room fans are on 1 remote and that remote has quit. We've put in a new battery but it still doesn't work. Can they just go bad ??? Where...
Yes, they can. Another possibility, however, is the jumper settings could have been accidently changed when the battery was changed. Inside the remote is usally four little switches in a row, each can be on or off (zero or one). These need to be set to the same values as the receivers in the fans.
Sep 18, 2011 | Hunter Ceiling Fan Remote Transmitter...
My usb ports are not set too charge anything eg ipod ... in sleep mode.. it just stops charging it. How do i enable them......on a toshiba satellite M300
You have enabled all correct changes required for keeping the USB on while your computer is in sleep mode , if it still doesn't work I would suggest you to contact the manufacturer for any changes in BIOS settings...
BIOS Disclaimer:
Modifying BIOS/ complementary metal oxide semiconductor (CMOS) settings incorrectly can cause serious problems that may prevent your computer from booting properly. Microsoft cannot guarantee that any problems resulting from the configuring of BIOS/CMOS settings can be solved. Modifications of the settings are at your own risk...
thanks & regards
Anas K A
May 28, 2011 | Computers & Internet
My Trane PTAC unit has a problem with the compressor kicking on, fan runs, clicking noise like it is trying to kick on, but takes a good 15 minutes set at a low temp. setting for it to finally engage.
The compressor start capacitor is bad...it is not giving enough "kick" to get the motor running...
at least it is a good idea to change this first because if this does not work then the compressor needs to be changed out...
heatman101
Apr 01, 2011 | Heating & Cooling
Can't switch N70 to online mode. when I switch set off then on again it bypasses PIN requirement and goes straight to active screen which shows 'OFFLINE' mode
change setting in phone settings or call setting. you will get change flight mode, send my no, caller id. you just have change yes to no. or no to yes.
Tenzin
May 02, 2010 | Nokia N70 Cellular Phone
Locked out of the menue ,Need to reset command mode
Indeed, I did the same thing.... I did find the answer in the manual!
Here's a copy of it (pg 23):
Set the command mode for the remote so it matches
the command mode for the recorder you set above.
1 Hold down ENTER
2 While holding down ENTER, enter the
command mode code number using the
number buttons.
Command Mode Code number
DVD1 number button 1
DVD2 number button 2
DVD3 number button 3
3 Hold down both the number buttons and
ENTER at the same time for more than 3
seconds.
4 Let up, press RETURN, all done!
Jul 28, 2009 | Sony Televison & Video
Acer aspire 5010 bugged fan
as for aspire products, that would be part of the aspire 5000 series.
if your processor is getting that hot often its probably overheating. theres probably some dust bunnies in the fan or the fan pipes. try dusting it out and see if that solves the problems. you generally shouldnt have to alter the fan speeds at all because they are temperature controlled.
try resetting the bios to defaults if some how the fan settings were changed to funny values. it should definately be kicking in sooner than that.
Apr 26, 2009 | Acer Aspire 5000 Notebook
I changed some video imput and now i cant see anything, only audio
1. Press FUNCTION repetedly until "DVD" appears in the front panel display.
2. While holding down rewind botton, press FUNCTION.
The output signal is changed to interlace format.
Apr 23, 2009 | Sony DAV-FR10W System
I changed Desktop resolution setting to higher, Monitor went black with "Out of Range" message
please try this:
To resolve this behavior, either change the refresh rate, or change the video adapter settings.
To change the refresh rate:
1. Restart the computer, and while it is restarting, press F8 until the Startup menu appears. Press 3, and then press ENTER to start the computer in Safe mode.
2. Right-click the desktop, click Properties, and then click Settings.
3. Click Advanced, click Adapter, and then click Adapter Default from the Refresh Rate list.
4. Click OK, click OK again, and then click Yes to restart the computer in Normal mode.
You can set the colors and screen area to your preferences under Display Properties.
To change the video adapter settings:
3. Click Advanced, click Adapter, and then click Change.
4. Click Next, and then click Display a list of all the drivers in a specific location, so you can select the driver you want.
5. Click Next, click Show all hardware, and then click Standard display types under Manufacturers.
6. Click Standard Display Adapter (VGA), and then click Next.
7. Click Yes, click Next, click Finish, and then click Yes to restart the computer.
8. After the computer starts, right-click the desktop, click Properties, and then click Settings.
9. Click 256 colors, click Apply, and then restart the computer.
10. After the computer starts, click Start, point to Settings, click Control Panel, and then double-click System.
11. Click Device Manager, click View devices by type, and then click Display adapters.
12. Click Standard Display Adapter (VGA), click Remove, and then click OK.
13. Install all updated monitor drivers.
hope it helps!
Nov 02, 2008 | Planar PL1910M (Black) 19 in. Flat Panel...
Maytag M7Y15F2A Air Conditioner Logo
52 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
