Question about Maytag M7Y15F2A Air Conditioner
Not cooling - M7Y15F2A-B
We have a 14,500 BTU, M7Y15F2A-B, it runs but does not cool, the compressor doesn't seem to turn on, it just blows air, even on the cool setting. Is there anything we can do or check?
    Brigadier General:
  • 3,614 Answers
Have you done adjusting the thermostat settings & changing the mode settings..?
Posted on Jul 27, 2008
My frigidaire AC starts cooling fine but stops blowing cold air after few minutes and it does not cool at all. I haved turned it off and re-started it and it does the same thing
The compressor is being prematurely turned off. That explains why the cooling stops after a few moments. Either the thermostat is responsible or the electronics working with the therm are responsible for the anomaly.
Freon level is fine because it does cool when compressor is running. U might also want to check the start/run capacitor. That sucker starts the motor and keeps it running after the start. If the run section goes bad the motor will usually stop after it starts.
Aug 17, 2016 | Frigidaire FAS256R2A 25,000 BTU Window Air...
The compressor in my whirlpool stand up air conditioner is running fine but will only cool for a few mins then the cooling stops and the fan just blows. Any ideas?
If it is a capacitor start and run type, suspect the run capacitor. If not, suspect the start relay stuck or compressor on it's way out
Aug 07, 2012 | Whirlpool Heating & Cooling
Ive owned the 10x6c for 2 years never used it because of my wiring doesn't have a ground,,let my neighbor borrow it and it doesn't blow cool air I hear the compressor turn on but no cool air?
If the compressor is coming on and the air is not cold, it could be that the freon has leaked out. Easiest way to check for no freon is to take the cover off the unit and run it in cool. The high side which is the smaller line coming into the top of the compressor should be hot, and the low side which is the large line coming off the side of the compressor should be cold when the compressor is running. If there is no temperature difference between the high side and low side tubing, you have no freon. Also check for oil residue once you have the cover off. If you spot oil, you had a leak and have no freon.
Aug 14, 2011 | Haier hwr10xc6 Air Conditioner
Just bought a 2 yr. old Danby DAC5209M window a/c unit that doesn't cool the air before it blows it into a room. The wiring looks brand new, it was barely dirty on the inside, anyway, I've...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 24, 2011 | Danby DAC5020 Air Conditioner
Not cooling - M7Y15F2A-B unit compressor not on
Here is a tip that will help you to troubleshoot your A/C unit..
Air Conditioner2_bing.gif Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Apr 13, 2010 | Maytag M7Y15F2A Air Conditioner
Sunpentown wa1200e. Feels like blowing cool.
is it possible you cannot hear the compressor running?
Modern A/C do not run all the time even while calling for cool. They do cycle on and off to prevent iceing.
Oct 12, 2009 | Heating & Cooling
Kenmore 76081 cycling rapidly
check voltage when it shuts down possible motor overheating
Mar 09, 2017 | Kenmore 76081 Wall/Window Air Conditioner
I have a maytag room air conditioner that needs compresser
the cost of a compressor is significant. you will be money ahead to buy a new air conditioner that will use less power and cool better.
Jun 19, 2009 | Fedders 14,500 BTU Electronic Control Room...
Maytag M7Y15F2A Air Conditioner Logo
135 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
