Question about Xerox DocuColor 12 Color Copier
CMYK spots on print
Xerox DC12 prints have cmyk spots
  • Anonymous Aug 11, 2008
    i'm facing the same problem
  • 79 Answers
Each dots comes .5mm gape in one by one at different places pls check and replace a new drum.
Posted on Jul 28, 2008
Do the colour prints when printing RGB look all right?
If so, the printer is working.
What sort of CMYK are you trying to print? CMYK EPS prints, maybe?
If so, the the fault is one of not using the correct software; the printer is working, it is just not interpreting the encapsulated PostScript to reproduce a CMYK image. Use different software capable of reading CMYK EPS files. Photoshop is one such piece of software.
Dec 12, 2013 | Office Equipment & Supplies
Problem with color alignment on DocuColor 1632
Below is a link to the user manual, the aligment procedure should be in there. Xerox DocuColor 1632 User Manual
Jun 16, 2017 | Xerox DocuColor 1632 Laser Printer
Instead of Bule print DC12 prints Violet
Hi there! The blue color is becoming violet because the Cyan and the Magenta toners are not getting mixed in the proper 100:100 ratio (100% Magenta and 100% Cyan make CMYK Blue). Since the print is violet, the culprit is the Cyan toner. Now, first, get the Cyan Developer Assy checked if there is enough developer in it. If no, get it refilled by a proper tech and manually mix about 50 grams of the Cyan Toner with the developer. Also get the tech to check the trimmer gap on the Developer Assy with a metering gauge. If yes, next check the Cyan dispenser motor located on the backside of the Toner Housing Assy. It is probably broken and not dispensing any toner to the Cyan Developer Assy . Additionally, check for the Cyan Dispenser Auger blockage or jam. It is located under the Cyan Toner Cartridge in the Toner Housing Assy and also check the auger under the Cyan Developer Assy. After sorting these out, you should get proper CMYK blue from the 10th or 12th page once you resume printing.Let me know. Regards
May 26, 2011 | Xerox DocuColor 12 Color Copier
CMYK dot problem
can be solves by changing whole drum unit because problem with bias grid (black strip on chager)
Jul 02, 2009 | Xerox DocuColor 12 Color Copier
Why Recieve Bad quality for picture CMYK mode in umax 2100 XL?
What makes you think the scan is bad quality? How are you proofing it. Did you print in on a printing press or other CMYK device? The CMYK colorspace cannot be displayed on monitors without the program you are using converting it to RGB for display. Are you reading the actual CMYK values with the densitometer?
In my experience, with cheap scanners (under $75,000) it's best to scan to RGB and let Photoshop do the CMYK conversion. Just be sure to use the correct profile for your output intent.
Feb 05, 2009 | Umax BINUSCAN - PhotoPerfect CMYK & RGB...
Xerox Docucolor 12 : Four colors ( CMYK) dots printed each time on paper on 3 separate area
Your Problem is the cartridge printer Mx, In spanish algun balero de las developers units esta dañado pudiera estar golpeando el cilindro de imagen
Nov 03, 2008 | Xerox DocuColor 12 Printer
CMYK spots on print
- Please check properly if they have Leek?
- Try to clean the Glass inside and out-side the machine
Sep 20, 2008 | Xerox DocuColor 12 Color Copier
Xerox docu color 12
u check drum,ibt belt,2nt btr roller and fuser life... then do full service, then calibrate ur fiery also.. first u check developer bios plate.. if its have more dust print comes like that.. all the best..
Aug 14, 2008 | Xerox DocuColor 12 Color Copier
Cmyk dots on the print
There are several causes of those.
So go to
Click "support and drives"
then in the product name box, Type DC12
Then any line click support
IN the search box type "spots" and read the relevant solution.
May 05, 2008 | Xerox DocuColor 12 Printer
Xerox DocuColor 12 Color Copier Logo
211 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
