Question about Microsoft LifeCam VX-3000 Web Camera
Computer freezes recently reloaded computer with increased ram, a new minitor and a I click on the camera icon new graphic card - now every time I click on the icon & get the camera picture on screen the computer freezes...
  • Microsoft Master
  • 10,322 Answers
1st You download Webcam Driver.
Computer freezes
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Posted on Jul 16, 2013
  • 781 Answers
Remove 1 your new ram and see if computer ok
check system/control panel/device driver check for any yellow marks on them if so right click/properties drivers and either uninstall them or up grade them
I think you have a driver conflict
Posted on Jul 28, 2008
Black screen card
Make sure that you have the latest display (Graphic) driver installed on the comuter. If you are still facing this problem then it might be that your computer graphic card is old and does not support the required graphic resolution which is required to play this game.
You can try--
Most of the time DPI (Dot per inch) setting also fix this type of issue.
You can change the DPI settings in windows Xp by following these steps:
1. Click on Start then Control Panel.
2. If control panel is set at Classic View, then double-click on the Display icon
3. A box will pop up. Click on the Settings tab.
4. Click on Advanced.
Change the DPI setting to Normal size (96 DPI). You can also change the DPI size to any other value. Click OK and your computer will ask you to reboot your computer. Click Yes
Nov 16, 2013 | NovaLogic Delta Force 2
Graphis card problem
You have it - time to replace the video card.
Mar 24, 2010 | Dell ATI Radon, (16 MB) Graphic Card
When playing graphics related PC games, such as SIMS 2,Fable or online games, such as Wizard 101; the games freeze as soon as any key is hit or the mouse is moved.
try downloading the most recent driver software for your video card keyboard mouse usb and all your other drivers to do this the easy way just right click on my computer and go to properties then go to hardware then device manager and go through your devices network card display adapters sound and video and game controllers and hit update one by one
Nov 02, 2009 | Dell Computers & Internet
XFX GeForce 6200 LE 256mb ddr2 agp8x problem
Your card/ram/mainboard probably can't handle high temperature anymore or has weakened due to overclocking the agp/ram voltage.
Increasing processor's fsb might have an impact on the mainboard and so it has weakened.
You can try to remove the vga and test with onboard vga, if it's still has problems switch the ram (you can borrow your friend's), and finally if it's still has problems switch the mainboard.
Mar 17, 2009 | Pine Technology XFX GeForce 6200, (256 MB)...
Increase graphics card memory
go to your bios setting > chipset feature > onchip AGP.
you can increase your Graphic card from ther if it is on bourd.
Jan 28, 2009 | Asrock P4I45GV R5 Motherboard
Increase the RAM with out fixing any ram cards
In Vista, just connect a flash drive and it will ask it should open it or start ReadyBoost. Choose the latter one and choose how much part of it should be used as memory. But to enjoy it full-time, you need to have it connected always. It is generally used when the PC is freezing a lot and you are running a number of things.
XP is not built to do this, but it can still work. See this video. If it doesn't work, try this international site. But this may take a longer time to load on a slow connection.
Dec 13, 2008 | Lenovo 256MB ATI X1600 Pro VGA DVI-I...
Computer freezes up
Ok so i'm going to probably get flamed for my suggestion here, but bear with me.
  1. Take out the new fx5200 video graphics card and reboot the computer. If the freezing stops, then the card itself is most likely faulty or incompatable with your particular PC, or may also simply have a fault in it.
  2. Computers that ran fine before a new piece of hardware/software was installed, can nearly always be blamed on the new device or program. Simple solution is to remove the last thing you added and work backwards from there.
  3. If the freezing still happens, i suggest that you could also have a faulty ram stick, and you can test these with a RAM testing program, but they don't always show errors the first time you run them, so it may take several test runs to show the problem.
  4. An easy solution ( if you think you may have a faulty ram stick or Dimm slot, you can try removing the stick/s from the Dimm slots 1 by 1 until the problem stops, this can mean you have either a bad slot or bad ram stick, either way you should be able to work out what the problem is fairly easily.
  5. The only other problem i know of that causes long freezes or pauses, is not enough ram - or what is called missmatched ram.
Feb 04, 2008 | Nvidia GeForce FX 5200 Video Card Graphic
Computer freezes during game
first of all you should know that even though pentium 4 isn't that old there are still some problems, for example the d processor uses sd-ram or ddr1 ram which are much slower that ddr2 and ddr3 "ddr1 isn't that slow" but if u're using SD-ram then u might wanna upgrade your rams a bit.
Dec 23, 2007 | Biostar P4M800-M7A Motherboard
Microsoft LifeCam VX-3000 Web Camera Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
