Question about Dometic Rooftop RV Air Conditioner
Compresser will not kick in and there a electrical smell
The AC (Duo-Therm Model 57915.622) in my RV has been working great until today. All of a sudden, the compressor would sound like it was kicking on, but then just hum for a few seconds, and then kick off. When this occurred, I can smell a slight electrical smell coming out of the AC vents in the ceiling. About 10 seconds after the compressor kicks off, it tries to kick on again and repeat the same cycle.
  • Anonymous Jul 28, 2008
    have just experianced the same issue with same unit. Took it to a dealer refered to on their home page and was told that a relay or conductor of some type is the cause of it and the factory is aware of the problem and is providing the part free of charge. Am still waiting for the part to come in to see if that really is the issue. Hope this helps.
Sounds like your start capacitor may have gone bad. If you remove the shroud, there should be an access panel for the electronics. In there, you'll see one (or two) cylindrical parts with wires coming out the top. If one of them shows signs of something coming out of it, it's probably your start capacitor and it needs to be replaced.
You can view the installation/service manual for DuoTherms here at Bryant RV.com (it's a 3MB PDF file, so download with care). Look on page 28 for info on the capacitors.
Posted on Oct 13, 2008
  • 143 Answers
Stop it!
Something has gone wrong and needs to be repaired. It's an electrical problem. The more you smell it, the more stuff is getting burnt. Take it apart and look inside it. Then restart it. The burning stuff will lead you to the bad part.
Posted on Jul 27, 2008
Replacement Fan Motor
Try Johnstonesupply.com. Use the information you provided above.
May 06, 2010 | Dometic Rooftop RV Air Conditioner
Duo-therm brisk air AC unit leaks water into my RV when it rains
take the cover off and make sure the drain line is clear on top off RV.
Nov 15, 2009 | Ovens
9/20/09 I just had the same problem with the same model
With rooftop air-conditioning units two issues are commons and that not clean unit that slow the fan and that effect the compressor, check the fan and see if the housing clean and no debris and as far as the compressor it is don and you need to replace it, I am sorry to tell you the news but on the other hand you can get used one now very cheep and they do work good. See if you contact local dealer that serves them and ask for used one or call campaign world and ask them to look for one for you…let me know how that work for you and please do not forget to rate my service so we can improve on it with your help. God bless
Sep 20, 2009 | Dometic Rooftop RV Air Conditioner
My Duo Therm Runs good until the outside Temp. Reaches about 75 dregees Then starts kicking off the braker. What would cause this?
Too many things on the same circuit. Try turning everything electrical off but the ac and see if it stops tripping the breaker.
Jun 08, 2009 | Dometic Rooftop RV Air Conditioner
Duo therm AC/ furnace in Puma not kicking on
there is a "control unit" inside the bottom cover of the A/C on your cealing ... inside there is the control box that controls itself. Has a silver peice bout 2'' thick and the size of a quarter this is your freeze control, if your A/C gets TOO cold and might damage itself it kicks on and shuts down your unit(yes even your furnace) need to have a tech come out and fix/replace it, RV Tech, most A/C repair companies know NOTHING about RV's
Nov 17, 2008 | Dometic Rooftop RV Air Conditioner
AC does not cool. Compressor kicks on and off (Humms when trying to start, electrical smell)
There are a couple possibilities:
1. If this is the first time you've started them for the season, one of the compressors might be seized up from sitting over the winter. In which case, new compressor required.
2. If you've just had the compressor serviced including recharging the system, it's possible that the system is simply overcharged. This will stop the compressor from working and giving you the same symptoms as above. If this is the case, you should have the service people come back with some guages and recover some of the refrigerant and the compressor should be fine.
3. If the unit has been sitting and there is a slow leak then there is not enough pressure in the system to allow it to run. The compressor will shut down if there is not enough pressure, but since you say there is a smell, i really doubt this is the case.
Most likely it's #1 or #2 above. If you haven't had it serviced recently, then yeah, it sounds like you're in need of a new compressor.
Good luck.
Apr 16, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
662 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
