You can clean Cmos By Using the Motherboard Jumper method Almost all motherboards contain a jumper that
can clear all CMOS settings along with the BIOS password. The location of this
jumper varies depending upon the motherboard brand. You should read your
motherboard manual to check its location. If you don't have the manual then
look for the jumpers near the CMOS battery. Most of the manufacturer label the
jumper as CLR, CLEAR, CLEAR CMOS, etc. When you find the jumper, look
carefully. There will be 3 pins and the jumper will be joining the center
pin to either left or right pin. What you need to do, is remove the jumper and
join the center pin to the opposite pin. e.g. if the jumper joins center pin to
left pin, then remove it and join center pin to right pin. Now wait for a few
seconds and then again remove the jumper and join the center pin to left pin. Make sure to turn the PC off before opening
the cabinet and resetting the jumper. if you think this was helpful?then pls.rate and if further question about it,i'm always open to help..goodluck and godbless
Hi. This is the support page for your motherboard..http://www.biostar.com.tw/app/en/mb/content.php?S_ID=363. At the top of the page there is a download link for the manual, it's in PDF format so you will need a PDF reader installed on your computer to view the manual. Look on page 6 and page 17 of file IG31C-M7S_080425 for instructions. Alternativly to save you some time, the Cmos reset jumper is located between the SATA-1 socket and the J-Panel connector on the motherboard. Hope this helps you out. Post back results and good luck.
Error loading operation system
Ig31c-m7s mother board drivers
SOURCE: what shud we do?please clear CMOS? OVERCLOCKING?
On your motherboard there is a small watch battery looking thing.
Unplug your computer and remove this battery.
Replace the battery and plug the computer back in.
This will reset the CMOS settings back to mfg. settings.
SOURCE: please clear cmos if system
Click the following picture to enlarge:
CPU Overheated
If the system shutdown automatically after power on system for seconds, that means the CPU protection function has been activated. When the CPU is over heated, the motherboard will shutdown automatically to avoid a damage of the CPU, and the system may not power on again.
In this case, please double check:
1. The CPU cooler surface is placed evenly with the CPU surface.
2. CPU fan is rotated normally.
3. CPU fan speed is fulfilling with the CPU speed.
After confirmed, please follow steps below to relief the CPU protection function.
1. Remove the power cord from power supply for seconds.
2. Wait for seconds.
3. Plug in the power cord and boot up the system.
Or you can:
1. Clear the CMOS data.
3. Power on the system again.
If after clearing the CMOS you still have no display, you may have damaged your motherboard, CPU, or RAM. If you need further assistance with this Motherboard, let me know.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
SOURCE: System fail due to cpu overclocking, voice message
Disconnect the power cable, press and hold the power button. Open the case, remove the cmos battery and short the cmos battery connectors (just touch both the metal tabs center and edge at the same time) with a screwdriver. Replace cmos battery, reconnect the power and power on. This should reset the BIOS to default settings.
SOURCE: Please clear CMOS if system
There are a few software which can also reset/clear CMOS settings or BIOS password or both within a few clicks. But you should have access to a system which is turned on and should have access to
MS DOS or MS Windows:try this software or download it if you don't have... KillCMOS CmosPwd then follow instructions on how to,,from the link site goodluck..
Take out the battery for 15 minutes with the pc unplugged from the mains - it's the upright round one next to the video slot
KillCMOS
CmosPwd
goodluck..
