Question about ASUS P4P800-MX Motherboard
No Video The video output from this motherboard has had an intermittent problem, with no signal to the monitor. No it happens all the time. Is there any suggestion as to whether I could buy a PCI video card to fit in one of the expansion slots ? The motherboard has been discontinued and I'm looking for the cheapest possible solution.
  • Anonymous Oct 29, 2008
    I have the same problem. I've been told to get a new video card but that wont even help because when the video card shuts off....I get the blue screen of death first.
  • 2,794 Answers
If you can find them it's a good solution to try for that board since there is no AGP slot.
You might want to upgrade the video drivers
at this link here
and see if that helps.
Posted on Jul 27, 2008
  • 99 Answers
You could buy a cheap video card and pop it into the video bus. The bus is either AGP or PCI-e, post more info on your motherboard so we can figure out which one it is. You can get a card that would work for under 30 bucks.
Also one thing to consider is that you may have to disable your integrated graphics in the BIOS.
Check these out:
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010380048&bop=And&Order=PRICE
hope this helps
Monitor won't stay on
how is the monitor connected to the computer? what connection type is the monitor is it VGA or HDMI . What format is the computer video output is it VGA or HDMI. Also you may have two video outputs on the computer. Sometimes the motherboard vga output is disabled so that a much better video plug in card can be used which has its own video output port.
Apr 16, 2013 | Acer America Acer Aspire AX1800-U9002...
I HAVE A MSI RX480 NEO2 MOTHERBOARD IN MY COMPUTER NOT VERY OLD AND IM GETTING NO SIGNAL GHANGED GRAPICS CARD STILL NO SIGNAL
Check the monitor input, it must match the video card output Eg. VGA or DVI,
Try a different video cable.
If the video input is correct then try a different monitor to see if the monitor is faulty
Mar 02, 2012 | MSI Computers & Internet
Hi I recently bought a Biostar A880G+ motherboard which supports VGA, HDMI and DVI video outputs. I cannot get a second monitor to run on this board. The only output wich seems active is the VGA?
The manual says
  • NOTE: The HDMI and DVI-D ports both can provide digital video signals output function, but these two interfaces cannot work at the same time. The chipset uses the same channel to control HDMI and DVI-D, so these ports cannot transmit video signal to different display panels simultaneously.
so you should be able to use one of them as well as the VGA. Maybe you need to change something in the BIOS settings? I don't have this motherboard myself, just found the manual online at
http://www.biostar.com.tw/upload/Manual/A88PC-M3S%20&%20A88GC-M3S_100519_B.zip
Apr 20, 2011 | Biostar A880G+ AMD 880G Socket AM3 mATX...
I switch on my system and nothing happens The cpu
So practically the pc starts but you don't have any image. Try using another monitor and another video card - one of them is dead.
Jul 03, 2010 | Gigabyte GA-8I915P Duo Pro Motherboard
My tower wont turn off and monitor says no input signal and keyboard doesnt work
Do you have two video outputs on your PC ie. one on the motherboard adn a separately installed card maybe? If you do you need to set the BIOS so that it uses the AGP/PCIE video card and not the 'onboard'. Try the onbopard vodeo card first to see if you get a signal there.
If you do NOT have two video outputs, and you can not see a signal then you may have a prblem wiht your monitor itself. Is this a known working monitor to start with?
May 12, 2009 | HP Pavilion a1610n PC Desktop
Dell dimension monitor output broke away from motherboard and now i get no output to monitor to "wake it up", nevermind being able to see anything on it. As soon as i unplug the monitor cable from the pin...
Depending on how much it has broke away, you may be able to resolder it back on, or find someone who can. Other than that it will be a new board, I suspect.
It seems at least a few connections are OK, so probably worth a try, before scrapping it.
Jan 16, 2008 | Dell (W2562) Motherboard
No Video Output - HP 6635 Desktop minitower - CPU Intel CELEROM 533Mhz
if you have changed the monitor and the same no signal have you noticed a beep sound? or can you see the green and red light in front of cpu? if both of this doesn't light it's power supply and if there are led lights (green&red) lighting but there is a continous beep sound the problem is the on board video card. if a sound short beep, beep the problem is your memory card.
Nov 27, 2007 | HP (5064-6630) Motherboard
No video output - Desktop HP minitower Pavilion 6635 - cpu Intel Celerom 533Mhz
Try either a pci or AGP card. On most boards, it will recognize the card without changing anything on the board. Does the hard drive and other components power up? Just the video not working ? If so it is probably the chip on the video, if not it could be a board failure.
ASUS P4P800-MX Motherboard Logo
87 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
