Question about Nikon D40 Digital Camera with G-II 18-55mm Lens
LCD display issues
I've had my camera for a year now and all of a sudden I can't take a picture through my LCD display screen however it works when I use the menu and to view other pictures. Any ideas what setting got messed with and how to fix this??? Thank you!
  • 2 more comments
  • mzjackson002 Jul 27, 2008
    That's odd because for the last year I've been able to take pictures through the LCD screen and the other day it just stopped working. I guess I'll have to bring the camera in and have it looked at somewhere.
  • Anonymous Aug 18, 2008
    I also used the LCD to take pictures and it has just suddenly quit working!
  • honestprof Mar 19, 2009
    Sorry folks - I have the same problem. Up until two days ago, Liveview worked on my D40 - no question about it. Suddenly - no more live view on the LCD display. - Can't figure it out. I've tried everything to restore this - reset, locking mirror, etc.
    No - I'm not dreaming - yes - liveview used to work - and now it doesn't.
  • ahmjt May 11, 2010
    I would like to have a Nikon D40 with Liveview!! How did you take picture from the LCD in NIkon D40? As far as I know, NIkon D40 does not support this - user has to to use the viewfinder to take pictures. The new Nikon D90 has a liveview.
  • 667 Answers
According to Nikon, that was not possible. The D40 doesn't have 'Liveview' like the smaller compact cameras. You would always have to use the viewfinder for taking pictures. Even in the TV ads, everyone used the viewfinder as they took turns using the camera.
Here is a link to Nikon's web site: NikonUSA
Posted on Jul 27, 2008
  • Kevin Pettit
    Kevin Pettit Jul 27, 2008
  • Kevin Pettit
    sorry, I didn't make that a hyperlink, you'll have to cut and paste
    I just don't see how you were using the LCD display as the viewfinder to take pictures, it is not possible.
Nikon D90, I take the pictures but blank screen comes on to display screen on quick review and same on the Play mode as well. It is a new camera
Don't try to fix it yourself. If it is new, it is still under Nikon's one year warranty. Contact Nikon at 1-800-NIKON-US (1-800-645-6687) 9AM-8PM EST, Monday to Friday.
Jan 03, 2012 | Nikon D90 Body Only Digital Camera
My screen has gone white?
The display being white can be due to failure of the LCD or the CCD which is the optical sensor of the camera. So to confirm check the older picture to be seen on the display. Confirm this by checking the card on your PC. If the images/picture is seen to be of good quality, then the LCD can be faulty, fault on the linking cable or the control board.
However if the older images are seen well then the LCD is working correctly and the fault can be failure of the CCD- charge coupled device in the camera. If you have accidently exposed the camera directly to high intensity light / sunlight, then it is possible that it is damaged. Remove the battery and keep the camera aside to reset and try as a last resort. Get estimate before you decide. It will be good to have it checked at the authorised service as you do not have to run around for spares.
Please click on the link for tips to replace a LCD
Dec 14, 2011 | Nikon COOLPIX L20 Digital Camera
I have Panasonic Lumix DMC TZ3 camera and it suddenly stoped working when i switch on the lcd is black first i thought my lcd has problem but i can see images from my memory card very well only when i go...
First, if the camera turns on and the lens extends properly, toggle your "display" button until the screen image returns. (you can turn the display off via this button and is most likely the issue).
Otherwise, it would indicate a greater issue that would require the camera to be sent in for service.
Mar 10, 2011 | Cameras
Shooting mode shows nothing.
I just had this issue with my camera (my 15 year old son solved it for me ;-) ).
The viewfinder was active in "record" mode and the LCD was "active" because you could see a little back light but no image. The "playback" mode would let me review pictures in the LCD though so I know it is capable of showing information.
If you push the display key/button a couple of times you can see the picture move from the viewfinder to the LCD and have just a picture and or a picture and information.
So try setting the camera to "record" mode (lens comes out) and then push the "display button" which is on the back of the camera just to the right of the LCD on the lower right side several times and see if the LCD starts to work.
It could be that somehow the display button was pushed by mistake.
Dec 07, 2008 | Canon PowerShot S3 IS Digital Camera
Digital Zoom not working and screen is blurry
Your zoom probably does not come out all the way and therefore you get some blurry shots. Had the same problem on a Panasonic camera. Solution: replace zoom motor and gears. Results=expensive. Goes beyond the value of the camera. You might want to buy another used A85 or newer digital camera.
Oct 21, 2008 | Canon PowerShot A85 Digital Camera
Canon A75 No startup sound & display on LCD, rest of things works fine
Think it might be your batteries. 700mah batteries are pretty weak by today's standards (most are at least 2,500 mah these days). I'm guessing your batteries are several years old? If so, they're really only meant to have a usable shelf life of a few years, whether they are used or not. Recommend trying a new set of rechargeable batteries.
Mar 20, 2008 | Canon PowerShot A75 Digital Camera
Nothing displays in LCD screen, canon powershot S400 digital ELPH
Sounds like your LCD might have gone bad. The LCD might cost more than the camera costs, but there are a few places on eBay that you can buy a repair and replacement service from for pretty cheap.
Nov 01, 2007 | Canon PowerShot S400 / IXUS 400 Digital...
Black screen
First check your camera option press display button if not solved it is a hardware problem with your camera LCD, maybe move it wrong way please concern your cannon department.43a5872.jpg
Oct 17, 2007 | Canon PowerShot S1 IS Digital Camera
Black LCD screen on camera
Just had the same problem (black display). I moved my hand in front of it and took pictures of things but nothing happened. Then my girlfriend tried to point it to a lamp, and all-of-a-sudden it kinda woke up from a screensaver or something. So weird, but it worked. Perhaps it needs enough light in order to start using the display and lens. I couldn't take any pictures when the LCD was black. So, try pointing it towards a strong light source before you break your camera.
Aug 30, 2005 | Pentax Optio 330GS Digital Camera
Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
198 people viewed this question
Top Nikon Cameras Experts
Are you a Nikon Camera Expert? Answer questions, earn points and help others
