Question about Epson Stylus Photo 1280 InkJet Printer
Epson 1280 red lines on photo
My E1280 puts red lines all over my great photos. Any ideas? I have horizontal red parallel lines spaced about 1/8" apart and have tried everything!  I called Epson about service in my area and they were of no real help.  I only use Epson printer inks and would like to repair or replace this 1280 as it has been good over the years. Or find a similar Epson product. I would rather not go for the multiple in cartridges.  Any suggestions?
  • 5 more comments
  • Anonymous Aug 12, 2008
    I tried this myself and it did not help the problem at all. Good thought, though, as the photo paper is sometimes thicker than normal.
  • babeofcandle Aug 27, 2008
    I have the same problem with red lines all over my prints.
  • hoodagh Sep 16, 2008
    I have the same problem but it is intermittent. It does it for photos but not for other printing. It also comes and goes. It isn't a cleaning issue as a test page or a nozzle check are both fine. I feel its a software issue. I was even wondering if it was linked to Vista which we recently installed and the problem has come since then. Cheers.
  • neight Oct 06, 2008
    My 1280 has a similar problem, great looking prints with intermittent blue lines printed over the photos. Even when printing black and white the blue lines appear
  • MinPrint Oct 08, 2008
    I have the same problem - red lines all over the page, from 1/32 to 1 inch apart. I tried all suggestions and nothing works. Have also removed a half used color cartridge and replaced it with a new one - same problem. The printer is about 7 years old and has worked well until a week ago. Is this the point of planned obsolescence?
  • Anonymous Oct 28, 2008
    I have the "blue line" problem. The color is right, the print looks good but the small blue lines are all over the print. Doesn't show up on regular paper only photo paper. I've cleaned, checked new printer profiles and made sure that only photoshop Adobe RGB is controling the print colors. I don't see that anyone has posted a solution.
  • Anonymous Nov 12, 2008
    i just bought this printer off a photog friend of mine and even after cleaning and re-aligning the ink cartridges a few times i'm still getting these damn lines across my entire 11x17in prints!!! this is definitely a problem considering i bought this printer to print out my portfolio... hmm...
    Problem Solver:
I tried FixitDan's solution prior to reading his post and it seemed to minimize the problem, in that it does not happen as often, but still happens. Looks like there is something "dragging" on the printhead itself, or perhaps the firmware is firing the nozzle at the wrong time. In any event, can the print head be replaced easily on the 1280? As others have mentioned, this has been a really great printer for the past seven years.
Posted on Nov 01, 2008
Suggestion:   Open up the "hood". All the way on the right side of the top of the plastic case, you'll see a large switch.   Switch it up from "0" to "1".  This will give the paper a little more room and might help.
Posted on Jul 31, 2008
Black banding 1280
Do nozzle check. Is it perfect? If only one or two nozzle missing, it must be "good result" in photo quality mode printing. But if, there is too much nozzle missing, result is no good. If nozzle check is perfect, but the result is not satisfied, check the PF scale and PF scale sensor.
Jan 26, 2013 | Epson Stylus Photo 1280 InkJet Printer
Getting blue horizontal lines through all docs and photos. Just replaced both black and color cartridges.
Blue or red lines that go across the page and outside the printed area usually depict a Main board fault.
Feb 07, 2010 | Epson Stylus Photo 1280 InkJet Printer
Horizontal lines (red) on first 1 - 2 pages of initial print-out
Do you refill ink tank? Print blank pages. Is there horizontal lines appear? It might be caused bay ink leakage. Check respiratory hole at ink tank and rubber seal at bottom of ink tank. Print blank pages until no horizontal lines and try to use new ink tank.
Aug 17, 2009 | Epson Stylus Photo 1270 InkJet Printer
Try to do a deep cleaning on the printer. You may use the printer maintenance wizard to perform this.
Apr 12, 2009 | Epson Stylus Photo 1280 InkJet Printer
Horizontal Lines Only being printed?
Sounds like your printer nozzle could use some maintenance.
Dec 16, 2008 | Epson RX620 All-In-One InkJet Photo...
Epson Stylus Photo 1280 dead
that's most likely a system board failure...that's what controls the function of startup positioning
Jun 16, 2008 | Epson Stylus Photo 1280 InkJet Printer
Epson 1280 Stylus Photo
There is a possibility that issue can be caused by corrupted printer driver. Please uninstall the printer driver. Download updated driver at and install it.
Jun 10, 2008 | Epson Stylus Photo 1280 InkJet Printer
Printing issues
I would get it repaired. you could get one off ebay. they are a lot of money new.
Mar 21, 2008 | Epson Stylus Photo 1280 InkJet Printer
One of the best possible solution that we can suggest is to run a cleaning cycle for three times. Just to make sure that cleaning is effective please try the step below:
1. Using your computer go to printer utility.
2. Click on Maintenance then select Head Cleaning. Head cleaning usually took 1 minute.
3. Once the Head Cleaning is done Print a nozzle pattern to check whether the head cleaning is effective or not.
Repeat those steps for 3 times. If the nozzle pattern after 3 cleaning cycles still bad. Reseat ink cartridge if possible replace the ink cartridges.
After all those steps and issue still present printer needs to be in service.
Aug 05, 2006 | Epson Stylus Photo 1280 InkJet Printer
Epson Stylus Photo 1280 InkJet Printer Logo
415 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
