Audi concert sound system volume control faulty
Problem is due to the microprocessor that runs the whole show, or more precisly a part of it that
remembers the volume level you had set when you removed the key, this memory is call EEPROM,
(electrically erasable programable read only ymemor), it can remember its data without power being applied,
this type of memory had a limited number of write cycles( number of times it can be re -written lets say between 20-50,000)
the early concert radios would only write to this memory when the radio was switched off, so that equates to 2-3 times a day in normal use, later radios have a software bug that writes(updates) this memory EVERY time you alter the volume level, you will quickly use up the 50,000 write cycles and the memory becomes defective, the symptoms are full volume that cannot be controlled, and it will be temperature sensitive often improving when it warms up.
Shame on you AUDI, this product was defective from manufacture but you dont honour any player out of warrenty, EEPROM has limited write cycles any engineer knows this, your software is defective.
the fix is to replace the microprocessor that has 1. new EEPROM onboard & 2. new software that doesnt weat it out!...the bad news is this fix is way more that the cost of a used radio off EBAY
Posted on Apr 25, 2009
  • SKYamw May 25, 2011
    I bought my car in 2004 my Audi Concert system gave out on me in 2008 and I was inform to buy another from dealer. So I did so which cost me $215.00 for the brand new system. installation of course cost me more. In 2010 my new system conked out on me. I took my car to a mechanic thinking maybe its an electrical problem and he stated nope its the systems volume thats not working and that it would cost me way more to fix the system if I have it repaired than to buy a new radio. So I am out of two car stereo systems and have to find something to replace and pray to god that whatever I buy does not mess up my electrical system. Ugh. Oh by the way another defective problem that I had was with the power windows in 2008. The windows began to go up and down very reluctantly then eventually they did not work. I was told they need new motors which cost over $500.00 for both to be replaced. Come to find out I went to another Audi dealer who informed me that its not the motors I just need to replace the clips that holds the window in place. The original clips where defective and they had broke and that this is common. I replaced the clips with new ones that where not the same and so far no problems.
Audi Concert problem
you must check wiring cable of left speaker-reconnect antenna cable and check if it is firmly connected and apply contact cleaner over faders.
May 18, 2008 | 1999 Audi A4
I have a 1998 audi a4 with a bose audi concert system. i need to put in the security code and from what i have found you can do this by holding scan and rds at the same time then you can enter the code but...
IMPORTANT NOTE: You must have the security anti-theft code for your Audi Concert radio from the car manufacturer, or from an Audi dealer!
The sequence of programming for 1998 Audi A4 Concert radio is:
1. Push simultaneous "SCAN" and "RDS" keys until on the screen will appear "1000" displayed.
2. Release keys. No more push on "SCAN" and "RDS" keys because otherwise number "1000" will be considered as first safe code attempt.
3. By the #1 key you will set up the first safe code digit.
4. By the #2 key you will set up the second safe code digit.
5. By the #3 key you will set up the third safe code digit.
6. By the #4 key you will set up the four-th safe code digit.
7. Then push again simultaneous "SCAN" and "RDS" keys for confirm this safe code. On the screen will be displayed "SAFE" notice. Release keys! For few seconds a radio frequence will be displayed. The radio is now ready for use!
Please do rate my response. Thanks!
Jan 04, 2011 | 1998 Audi A4
I have a 2002 TT ALMS with the Bose Audi Concert radio system. After filling up I began driving away and the radio went dead - no "safe" announcement just a black screen... I checked the 15 amp fuse in the...
Yes, there is a second fuse on the back of the radio, (10A - red colour), but you have to pull the unit to check & change it. This is only course of action. You need special Audi Concert radio extracting tools, (two radio keys).
Aug 22, 2010 | 2002 Audi TT
Turning volume nob on my audi a4, concert cassette unit/cd changer makes volume go bannanas???
try reseting the switch on auto volume control.that should sort it out.
Apr 25, 2010 | 1998 Audi A4
My car stereo has gone to the SAFE mod and i tryed wrong cod now
IMPORTANT NOTE: You must have the security anti-theft code for yours Audi Concert radio from the car manufacturer! For Audi Concert the sequence of programming is:
Apr 08, 2010 | 2000 Audi A6
What are the instructions for entering radio codes for a 1998 Audi A8?
Audi Bose Radio g_tri90.gifAudi Gamma CC Radio g_tri90.gifAudi Delta CC Radio g_tri90.gifAudi Concert Radio g_tri90.gifAudi Symphony Radio which one of the above is your system?
Mar 26, 2010 | 1998 Audi A8
I need a part # for the volume controle on an Aiwa
The "volume control" on your Aiwa is in fact what is called an "encoder". These can fail. They work in concert with the microprocessor to control the electronic volume control IC. Yes this part can be replaced. Try calling Sony with your model number and request the part number for the volume encoder. They should be able to help.
Dan
Aug 24, 2009 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
2001 audi tt audi concert bose stereo system
follow intstructions at this link http://www.ibiblio.org/tkan/audi/radios/radios.html
good luck
Apr 07, 2009 | 2001 Audi TT
2,578 people viewed this question
 Grubhead
Grubhead
