Question about Magellan Roadmate 760 GPS Receiver
Turns off when i move the gps slightly.....
This roadmate 760 has become more of a nusiance than any help! It turns itself off even on the slightest pretext. Just move it, turn it ever so slightly and it powers off...I cant seem to figure what is wrong with it,
  • hods Oct 10, 2008
    it shuts off then it comes on it might stay on for a short time then it goes off
I'm going to guess you need a new cradle. The pin inside mine broke off in the female end of the car adapter, resulting in no power. If it's loose & periodically making contact, it would power on & off before finally going off for good. Cradles can be had on ebay for around $20.
Posted on Feb 20, 2009
What size fuse goes into the cig lighter adapter for the magellan roadmate 760
size or value?
4 amp is what are placed in them at the tip.
Please rate my help++++Thanks for using FIXYA
Dec 06, 2009 | Magellan Roadmate 760 GPS Receiver
Magellan RoadMate
The map software has become corrupted..
Oct 09, 2009 | Magellan Roadmate 760 GPS Receiver
How can I get the code to unlock the European map Magellan Roadmate 760
You will need to pay Magellan for the authorization code, they are the only one that can provide you with an EU code for your Magellan 760 RoadMate. Sometimes Auto Nav 2000 Plus, Inc can also assist. They have direct connection with Magellan to assist issues with Magellan products. Good Luck
Aug 04, 2009 | Magellan Roadmate 760 GPS Receiver
Roadmate 760 Touchscreen
There should be a calibration option in settings.
Jul 07, 2009 | Magellan Roadmate 760 GPS Receiver
Stopped connecting to satellite
check battery condition also go into set up and see that the baud rate and port are set correctlyb in accordance with the manual.
May 20, 2009 | Magellan Roadmate 760 GPS Receiver
My Magellan Roadmate 760 turns on and brings up the Magellan screen and then it locks. Can anyone help.
Sep 02, 2008 | Magellan Roadmate 760 GPS Receiver
Magellan 760 no satellite signal
I got a Roadmate 760 from my employer to use. It won't pick up my current location and is not working right. Help!
Jun 14, 2008 | Magellan Roadmate 760 GPS Receiver
Roadmate 760 is stuck in current location
enter diagnostic mode. initialize gps. stay in place for 1 half hour. if the location still does not change find a highway -- the signal sometimes only kicks in on the highway
May 21, 2008 | Magellan Roadmate 760 GPS Receiver
Turns off when I move it slightly
it must be in the wire...............
get a new cable(power) and try that!
May 12, 2008 | Magellan Roadmate 760 GPS Receiver
Magellan Roadmate 760 won't stay on
U6 is what I think it's called. those cases weren't exactly built around the insides.. (the circuit board).. there's a small IC chip on the backside of that same card with the cradle connect. . more then likely your case has shoved off a tiny little black IC chip. if you open the case and you see a little black peice.. save it. you might have to take apart your unit though. . careful when your opening it as the RF cable will be a hazard as soon as you crack the case.. so open the case just a little bit.. then find that cable I'm talking about.. and just pull it off.. then you can open it without any further restrictions.. If: this small IC chip is the problem, then you either need to solder it back on yourself.. or have someone else do it. So.. if you open the case u pand this isn't the problem let me know.. don't put the unit back together yet. and let me know. _+Daniel
Apr 15, 2007 | Magellan Roadmate 760 GPS Receiver
Magellan Roadmate 760 GPS Receiver Logo
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
