LG Washer / WM2487H*MA...2 days old. Wash setting...."Bulky/Large QUESTION:::When attempting to select additional "wash options" from the Option Buttons panel, I keep getting a display on the LCD panel "Ecl"
My LG Tromm washing machine just stopped in the middle of the cycle, It started flashing the letters LE, what does that mean. I have had it for 4 years and this has never happened.
Posted on Jul 27, 2008
Maytag centennial washer
Hello there and welcome to fixya
Here is the specifications on this washer
and this should explain why it dosent take much water to get clothes clean
This high-efficiency Centennial Top Load Washer features the IntelliFill automatic water level sensor and 11 automatic wash cycles to give you plenty of options. Low Water Wash with EcoConserve helps you save energy, while its spacious capacity means plenty of room for your largest loads. Inside, the stainless steel wash basket resists chips, scratches, and odors, as well as maintaining a smooth surface so it won't snag or pill fabrics. You get all that and still use 70 percent less water and energy in a model that pays for itself in four years. This no-nonsense machine does what you want.
  • CLICK HERE to learn more about Maytag Appliances
  • 3.6 cu. ft. capacity easily handles large loads and bulky items such as comforters
  • Rear panel controls provide convenient access to all cycle and option selections
  • IntelliClean impeller continuously moves clothes through the water for a thorough cleaning
  • 11 automatic wash cycles including heavy duty, casual, bulky and delicate to provide washing options to handle a variety of fabrics
  • ENERGY STAR qualified with a CEE Tier III rating: this washer is among the most efficient washers in the industry
  • Stainless steel wash basket resists chips and scratches and helps to protect fabrics from snags and pilling
  • Automatic Temperature Control monitors and adjusts incoming water flow to maintain the selected temperature for more consistent cleaning results
  • Low water wash with EcoConserve: use less water and get better cleaning performance through concentrated wash action, Low Water Wash technology enables the detergent to penetrate better and pre-treat soils with a concentrated mix
  • The IntelliFill sensor regulates the amount of water being used, making automatic adjustments based on the size of the load and type of fabric
  • MaxExtract Extended Spin option accelerates the load's final spin to remove moisture and reduce drying time
  • Deep Clean option uses a additional cleaning action and a deep rinse to ensure load is clean the first time
  • Click Here for details on the services included with Delivery & Basic Hook-up and Installation options for Major Appliances
  • MFG Model # : MVWC400XW
  • MFG Part # : MVWC400XW
May 25, 2013 | Maytag Centennial 7.0 Cu. Ft. Super...
LE error on LG 2277HW
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
Has a large load size been used with a gentle wash setting?
Gentle wash cycles such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for smaller loads. Because the cycles are more gentle while tumbling and spinning, too many items in the drum can register as an issue with the motor. In this instance reset the unit and run a test rinse and spin cycle.
Has the washer been overloaded?
Single bulky items or large loads can add extra weight to the drum and place stress on the motor. Remove some of the clothing and restart. If the issue is still present after a few items have been removed, unplug the washer for 30 minutes to allow the motor to cool and then restart the cycle.
Oct 15, 2012 | LG WM-2277HW Front Load Washer
I have the LG wm2487h*ma front load washer.My washer is filling up with water when not in use. When I wash a load, the water does not go in the washer. Have opened the door thinking the wash cycle is done...
The problem would appear to be the water inlet solenoid valve.
The valve is not operating correctly for some reason allowing water into the machine even when switched off
Sep 02, 2017 | LG WM2487H Front Load Washer
I have an LG WM2487h*ma model. It trys to spin during all cycles but turns a few times then stops, then trys again. Never gets to full spin capacity. Tried small load, and big load. Watched during a...
Hi!
I think there is nothing wrong with your washer. The UE error means Unballanced Error. This error comes up in two cases: 1. the load is distributed unevenly in the drum or 2. the machine is not properly set on an even surface (floor).
Of course, it could be a third case possible, but very unlikely, when the ballance sensor itself is malfunctioning and have to be replaced, or the spring and dampers are worn out and also have to be replaced.
Hope it helped!
Best regards
Aug 09, 2011 | LG WM-2277HW Front Load Washer
Our washer smells musty and makes the clothes smell musty
This is a common problem with front load washers, there are a few things you can do.
1. Use a washer cleaning product such as Afresh. It is available in most large supermarkets and all appliance stores where I am.
2. Make sure you are using the proper amount of additives, some detergents or fabric softeners have processed animal products in them that can cause bacterial growth in the residue left if too much is used.
3. If you do not already, start doing a hot wash occasionally, this will help rinse out any build up of additive residue.
4. Leave the door open to allow the interior of the washer to dry completely.
Let me know if this helps or if you have any more questions.
May 11, 2011 | LG WM2487H Front Load Washer
My washer is 2 days old. I selected the bulky level to clean a load of towels. The time showed 1 hour and 15 minutes . After 15 minutes, the bell rang and the code f08 and E01 appeared. This also happened...
Pull out the reciept. Read the info that came with it. Call for warranty service OR if possible, return it to store fro exchange or refund. Some appliances cannot be returned to store, therefore read blurb first.
Jan 17, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I put a fairly large load in washer. As the washing started I needed to add an item. I was surprised that the machine had very little water in it. Is there a way to add more water. Also when soaking I had...
The Series 10 and 11 machines have three level fill points the Series 12 and above have two level fill points.
I know Bulky Items wash selection will give you a High water fill which is only 7 inches or so of water in the wash basket. 3.5 inches of water for a medium fill.
You can turn on/open the water inlet valves in Service Mode but I would not recommend that. A manual fill as you did is the only safe way to set the additional water level IMOP.
FAV6800A/FAV9800A Service Manual for reference.
Rich
Jul 05, 2010 | Maytag Neptune FAV6800AW Top Load Washer
LG error code is 0E...what would be the problem
Washing machine has an LE error code --> Is this a new installation?
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
wmoverloaded.jpg NOTE: Make sure the drum is not overloaded
Are there soap suds visible in the drum?
May 18, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG Tromm wm1814cw LE flashing on digital display,
Here are few troubleshooting tips that i have found. If you acquire further assistance please let me know...
Apr 13, 2010 | LG WM1814CW Front Load Washer
LG Wash WM2487H*MA- how to turn the tub clean feature on?
I have had this problem since I bought my washer. Some days the tub clean cycle will work....most days it won't. They have replaced the main board twice and it's still broken. I've had nothing but bad luck with LG appliances. Also bought a lemon fridge that took 4 repairman visits to fix. I will not buy another LG anything!!
Jan 17, 2010 | LG WM2487H Front Load Washer
Washing Machines Logo
219 people viewed this question
Top Washing Machines Experts
