Question about Lexmark Wheelwriter 1000 Typewriter
Wheelwriter 1000 Thank you for your help. When you said to push down on the plate, do you mean the area that is under the ribbon? Sorry, it's been a few years since I've worked with a typewriter, I'm trying to get back in to the swing of things.
  • Lexmark Master
  • 3,594 Answers
I believe Jim ment the platen (black rubber roller).
DickyO
Posted on Jul 29, 2008
Why does my wheelwriter 1000 lexmark typewriter makes this hummin sound as though its stuke.
Lube the round chrome rod that goes throught the carrier, Carier is what hold the ribbons and daisy wheel.
Lube pulleys on the belt. You may need to lube the carriage return motor too.
Aug 21, 2014 | Lexmark Wheelwriter 1000 Typewriter
How do I install Ko Rec Type corrector ribbon on a Wheelwriter 1000?
The correction cassette snaps on to the bottom of the ribbon cartridge and they both go in together. You can go to (best to copy and paste this)
http://support.lexmark.com/index?page=content&id=SO4998&actp=search&viewlocale=en_US&userlocale=EN_US&segment=SUPPORT&productCode=&searchid=1258479940253
DickyO
Dec 11, 2010 | Lexmark Wheelwriter 1000 Typewriter
How do you replace the wheelwriter ribbon?
There is a blue lever that locks the ribbon in. Release it and lift the ribbon out.
Dec 03, 2010 | Lexmark Wheelwriter 1000 Typewriter
Our Lexmark 1000 typewriter is not printing in the usual bold,black print we're used to just recently. We have installed a brand new plastic tape - #1380999 and see no improvement. It appears the...
Make sure the platen (roller) is pushed down all the way. It must lock.
Also, see if the ribbon is feeding properly, characters should be evenly spaced on the ribbon. Other possible causes ..solenoid pad or selection plate, neither of which you can do yourself.
Nov 24, 2010 | Lexmark Wheelwriter 1000 Typewriter
The correction tape is not working properly. Wheelwriter 1000
If everything was working befor the ribbon & L/O change Either the L/o is not properly attached to the ribbon or the ribbon and or L/O are old. Make some corrections then remove and look at the L/o, if the letters are near the center of the L/O the problem is the ribbon or L/o is old, if the print is on the top of the tape it is not properly attached to the ribbon or not coming out or the cassette properly.
If you have a fresh set or another T/W that works swap the ribbons and look at how they are attached.
For a picture ngo to lexmark.com and click your way to publications you will find a downloadable manual there.
DickyO
Jan 23, 2010 | Lexmark Wheelwriter 1000 Typewriter
How to change the Correction Tape For The Wheelwriter 1000.
Remove the ribbon there is a small latch on the ribbon that holds the ribbon and L/O together unlatch remove and reverse the process to replace.
DickyO
Apr 10, 2009 | Lexmark Wheelwriter 1000 Typewriter
Wheelwriter 1000
Try snapping the plate down, by lightly pushing down on each end the have a habit of working loose.
Jul 23, 2008 | Lexmark Wheelwriter 1000 Typewriter
IBM Wheelwriter 6 prints only top portion of characters
The platen is probably not all the way in. Be sure the black latches are lined up with the side frames and press firmly down on the platen.
hope this helps
DickyO
Feb 25, 2008 | Lexmark Wheelwriter 3 Typewriter
Lexmark Wheelwriter 1000 Typewriter Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
