Question about Maytag Refrigerators
Gs2728 fidge freezer with water dispenser The water dispenser dispenses water on it's own at any time all over the floor
The ice maker water solenoid is dragging the voltage down on the electronic control board. Disconnect the solenoid and see if you can select the ice, crush and water using the panel buttons. If thats working fine then the water valve needs to be changed.
Posted on Jul 04, 2009
My whirlpool fridge water dispenser won't dispense water but it shoots out a burst of water each time the door is opened even though I have the dispenser in the lock position.
I'd look for a pinched water tube where it enters the freezer door at the hinge. This would happen when you called for water, but got none because the tubing was pinched. Then, when you open the door and the tube flexes the pressure would be relieved and water would shower out of the dispenser (or on the floor if the tube was damaged.)
Oct 27, 2016 | Whirlpool Refrigerators
What can be done to fix this without having to change whole unit?. - "water from nozzle from door dispenser assembly 4200960 of subzero s690 is spewing out on to kitchen floor instead of vertically down...
Remove the dispense and reinstall the waterline back into dispenser housing. Make sure the this is the only source of the water issue you have. The tube can slid back into the dispenser and cause the water to run behind the assembly. this is rare thought for the only way this could happen is the dispenser was replaced and the hose was not reinstalled correctly.
Good Luck
Sep 19, 2013 | APW Wyott SubZero Refrigerator Freezer...
Water dispenser leakage.
I had a customer that had the same problem with is water dispenser on frig . he replaced the water valve / but it didn't help / so he replaced the dispenser control still didn't help . this only hapened during the night . so he set up his cam coder for over night and you know what he found . in the middle of the night his dog would get a drink and dribble all over the floor . . i don't think this is your problem . but you never know . **** . . no easy fix .. ****
Jan 06, 2010 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
My Kenmore side by side unit leaks water onto the floor and the water dispenser has stopped working. When I hit the dispense switch I hear water squirting.
Probably the plastic tube that came from the solenoid is broken somewhere between the solenoid and the dispenser(usually under the refrigerator).
Sep 20, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Jenn-air side-by-side water dispenser leak
Check the fill tube to your icemaker and see if it has ice in it or in the fill cup to the icemaker. Most of the time when this problem happens it is the icemaker spraying the water. It could also be a bad module on the icemaker which can get stuck in the fill position and spray water all over the freezer.
Sep 14, 2009 | Refrigerators
Ice in freezer bottom
2 things:-1)Freezer door does not close completely, leving a gap allowing outside air to come in and te humidity causes water to freeze at the bottom of the freezer. This would explainwhy is forming over 2 days.
2)If your fidge has a ice maker in the freezer and a cold water dispemser, the both these compartments water flow for the ice &for dispenser are controlled by a solenoid valve, which in turn uses a sensor to detect the quantity of water in the ice maker trays and switces off the wster supply appropriately. If the sensor in the icemaker fails to detect the right quantity, overflows very slowly so as to appear to be noticeable..............sdeep
Sep 03, 2009 | Refrigerators
LG Fridge Freezer display has CF error code
Turns out a CF ER is a Compressor Fan problem.
Had a look and the fan was not turning, although it spins freely. Apparently it's a 3 phase 12v fan. I was able to get a resistance measurement across it but didn't know what to expect.
This also explains why it seemed a bit quieter and why the water is a bit warmer sometimes. The valve for the water dispenser is right beside the fan and it's getting pretty hot in there at the moment.
Dec 07, 2008 | LG French Door Cabinet Depth Refrigerator...
Water dispenser starts running when freezer door closed
if you wich to disable the despenser for water in the door just unplug the electrial connector on the water valve it has 2 selenoids on it one is for water in the door it has the largest plastic line under the selenoid
just unplug the connector to that selenoid
you will still have ice and it will despense through the door
Apr 20, 2008 | KitchenAid Superba 21.6 cu. ft. Top...
Refrigerators Logo
129 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
