Question about Dryers
Kenmore series 90 gas dryer won't get hot - Dryers
  • 1 more comment
  • kevinstat Dec 03, 2008
    10 yr old Kenmore gas dryer won't get hot (but tumbles the clothes).
  • ernesto33 Feb 23, 2009
    my kenmoore is not getting hot, replace the ignitor still the same , i dont see any glow when i start the dryer
  • campbells2 May 14, 2009
    Kenmore 90 series dryer won't get hot what should i try first
  • 3 Answers
Thermal Fuse mounted on blower housing. Test for continuity. Sears Parts Store... $17.71
if found good then test Operating thermostat. Near fuse.
Posted on Feb 26, 2009
  • 14 Answers
SOURCE: dryer not getting hot
fist make sure the fuses are good.. unit will run on 110 but not heat.. check connectores and cables or pigtail. it not.. then check heater coils and or thermostat...
Posted on Jun 13, 2008
Sea Breeze
  • 4655 Answers
SOURCE: how to remove front panel from kenmore 90 series gas dryer
Gently pry top of dryer in front corner area. Disconnect door switch inside front. Remove 2 sheet metal screws from inside front. Let me know, Thanks, Sea Breeze
Posted on Mar 21, 2009
  • 2669 Answers
SOURCE: 9 yr old Kenmore 90 series dryer wont heat
is it gas ? next time open dryer door and send full model number if it heats for a while you have bad gas coils,when you change them out watch out for the coil with three prongs on it,there is a metal piece that sometime gets stuck in old coil when you remove it,if it happens just poke it out of old coil and slide it back on post where new coil will be installed
Posted on Nov 07, 2009
bestdarngood
  • 3037 Answers
SOURCE: the dryer runs but only blows cold air. It's a gas
Have you checked the igniter yet or tried replacing it?
It is generally the first thing to go when this happens.
Benjamin
Posted on May 24, 2010
marka19
  • 1430 Answers
SOURCE: Kenmore 90 Plus Series Gas Dryer that will not heat
It could be several other things thermal fuse, thermal cut out, hi limit thermostat, dryer coils, heat sensor,or igniter. All of these parts are inexpensive and easy to test and replace.There is a video at t http://appliancehelponline.com/gdryertroublevideo.html his will walk you thru the troubleshooting of these components. It may be a different model but the troubleshooting will be the same.You can also enter your model # for diagrams and illustrations. All parts come with installation instructions. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
Posted on Jul 13, 2010
Kenmore 90 series dryer won't heat
Take the back off and look at the heater is what I would do If your filter comes out the top the dryer breaks down like this:
If your dryer has the filter down in front then your dryer comes apart like this:
Oct 03, 2012 | Kenmore 73952 Gas Dryer
Kenmore 90 Series dryer will not heat up.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 02, 2011 | Kenmore Dryers
Jul 01, 2010 | Dryers
Need help with gas dryer Kenmore 90 series serial
Check the lint caught in the exhaust vents. If it is clear replace the spark ignitor if no click is hear upon starting up
May 14, 2010 | Kenmore 73952 Gas Dryer
Kenmore dryer Ultra Fabric Care 90 series. No
If you have a gas dryer check out this tip...
If you have electric check out the tip for electric at the bottom of the gas tip...
http://www.fixya.com/support/r3866744-dryer_not_working_dryer_not_drying
heatman101
Mar 25, 2010 | Kenmore Dryers
Nov 07, 2009 | Kenmore 63942 Dryer
I have a Kenmore Series 90 gas dryer. Works fine.
The only source of a gas leak from inside the dryer itself is the gas valve. They can sometimes leak a little gas when you first turn the gas on after hooking it up. If your gas pressure is normal (and I'm guessing the plumber checked it) and your other gas appliances are working properly, the dryer gas valve is faulty and should be checked by a qualified appliance servicer.
Apr 14, 2009 | Kenmore Dryers
Kenmore 90 Series Dryer will not DRY
first check the vent outside to see if it is blowing air out strong, then check for heat.
Dec 24, 2008 | Kenmore 62602 Electric Dryer
How to light the pilot for gas dryer, 90 plus series
Dryers haven't used pilot lights in over 30 years. You have an electronic igniter
Jan 16, 2018 | Kenmore 74602 Gas Dryer
Dryer not getting hot
Jun 13, 2008 | Kenmore Dryers
Dryers Logo
1,295 people viewed this question
Top Dryers Experts
