Question about Microwave Ovens
PRESTIGE CB130 HI I HAVE A PRESTIGE CB130 MCOMBI MICROWAVE AND I CANT SEEM TO CHANGE THE INTERIOR LIGHT BULB PLZ HELP .CONTACT ..rab_amen@hotmail.com
On Prestige Combi Microwave the bub is on the control panel side. First remove the cover, Philips and torx required to remove screws on the back. *** MAKE SURE MAINS PLUG PULLED OUT ***
Looking at at the magnetron unit, find a black oval shape between it and the control panel with two wires plugged in, there are two bend strips holding the bulb holder in (this is directly behind the vent holes on the right hand side of the microwave oven), straighten them and extract holder with bulb, swap bulb with same rating and reverse the operation and re-assemble.
Posted on Dec 31, 2009
  • Microwave Ovens Master
  • 9,086 Answers
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
The screws you need to remove should be pretty obvious, and a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 28, 2008
How do i change the interior light inside my Panasonic The Genius Prestige model #NN-SD291W
The bulb, which may be replaceable, is accessed by taking the cover off the machine.
God bless your efforts.
Jul 28, 2017 | Panasonic Microwave Ovens
I need to change the interior light bulb in my Frigidaire over the counter microwave. The model # is FMV156DCA.
Good Morning Evelyn, thank you for allowing me to assist you!
Here are some simple troubleshooting tips to help replace the light bulb on your Frigidaire microwave, FMV156DCA.
    ·First, disconnect power to your microwave. This can be done by either unplugging it or at the circuit breaker panel.
    ·To release cover, remove the screw on the light cover (light cover may become very hot, do not touch glass when light is on).
    ·Remove old light bulb and replace only with equivalent watt bulb available from parts distributor or the manufacturer directly. Bulbs are also available at most hardware stores or lighting centers. Bulbs larger than 30 watts are NOT recommended.
    ·Close light cover and secure with screw removed in step 2.
    I hope this information proves to be helpful. If you have further questions, please do not hesitate to reconnect.
Nov 25, 2013 | Frigidaire FMV156DC Microwave Oven
My microwave heats, but the surface light and interior light don't light up and the turn table doesn't rotate. Everything else seems to be working fine. What is the best way to trouble shoot the problem?
follow this steps and fix it. God bless you
  • Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  • Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction
  • Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#6#ixzz2gUUt9D8f
    Sep 30, 2013 | Microwave Ovens
    Microwave light bulb out
    This is simple, and "FixYa" technical staff has clearly not looked at our model.
    Take off the vent across the top (three long screws) to expose a single screw over the keypad.
    Remove the single screw, and the whole keypad consile will lift up and off, likely hanging by a plastic tab/support on the bottom.
    Now you can twist the light bulb plug to remove it from the support structure, change the bulb, and replace all that you've done.
    Simple.
    Feb 07, 2009 | Frigidaire FMV156DC Microwave Oven
    Can not change interior lightbulb
    how do I change the little light bulb on the top to take off the cover what do i need.
    Please, lvinci@gmnew.com
    Feb 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
    JE1590 light bulb replacement
    On this model you need to remove the outer cover.
    The bulb mount will be located on the right side next to the side wall of the cooking cavity.
    It's above the damper door assembly as shown in the attached drawing.
    You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
    The bulb should be available at local grocery stores, hardware stores, and places like Wal-Mart and Lowe's.
    Sep 22, 2008 | GE JE1590 Convection / Microwave Oven
    Delonghi AC930AMQ Microwave, Interior Light Bulb
    The bulb is usually run by one of the door switches, but in some cases they are run by a relay on the board.
    I would suggest you look over our files on safety & door switches here:
    http://www.microwavedisplay.com/safety.txt
    http://www.microwavedisplay.com/doorsw.txt
    Please write back with more details if you need further help.
    We're happy to help and we appreciate your thoughtful rating of our answer.
    Jul 05, 2008 | DeLonghi MW 605 Convection/Microwave Oven
    GE microwave interior light bulb replacement.
    Your post has two distinct model numbers shown, so it's hard to be precise, but I'll try my best.
    You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
    I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. Other models are similar. It's at
    http://207.234.249.73/mwd/ge_lamp_replacement.jpg
    Always unplug a microwave before removing or installing any bulbs!
    There may be a panel on the bottom covering the light(s), too.
    If yours is an Advantium type, the following instructable should help: http://www.instructables.com/id/SZFF4WSF44XYT8X/?comments=all
    Jun 03, 2008 | GE JES1289SK Microwave Oven
    Interior Light
    The interior oven light can be accessed in the following way:
    1.Open door and remove the top grill via the 2 screws along the top edge.
    2. In the interior light will be under metal plate with fasten by single screw. The halogen bulb is rated at 120V 20watt. Looks like a G-8 bulb with 8mm pin spacing with o.a.l. 1-5/8" long
    Get these bulbs cheap at http://www.1000bulbs.com/120-130-Volt-G8-Base-Halogen-Light-Bulbs/
    Jan 01, 2008 | GE JVM1790 1000 Watts Convection /...
    Microwave Ovens Logo
    1,072 people viewed this question
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
