Home | Sony | Handycam CCD-TRV318 Hi-8 Analog Camcorder | BEEPING SOUND AND COD...
Sony Handycam CCD-TRV318 Hi-8 Analog Camcorder
Problem for Sony Handycam CCD-TRV318 Hi-8 Analog Camcorder
BEEPING SOUND AND CODE C:31:23
By cantero85 on Jul 27, 2008
MY CAMER SUNDDLELY STOP TO WORK AND MAKING A BEEING SOUND AND DID NOT WORK . I TURN OFF THE CAMER AND SEEMS TO WORK WELL BUT IN A FEW MINUTES STRAT TO BEEPNG AGAING AND SHOWING THE SAME CODE PROBLEM WHAT SHOULD I DO???
THANKS
Comments:
Jul 27, 2008
- OK WHERE THE REEL SECTION IS LOCATED ????? OR CAN YOU DISCRIBE IT? I HAVE NO T MUCH IDEA BUT IF CAN YOU EXPLAINT TO ME CANHELP .
APRRECIETE YOUR HELP THANKS SO MUCH
Same Problem
Aug 24, 2008
-   My Sony Handycam Vision Model CCD-TRV108 NTSC when you have a tape in it and try to record or view the tape it starts beeping a nd will not play or record with a C:31:22 trouble mesage-   Guest
Aug 21, 2008
-   Having exactly the same problem. Put in a brand new tape at disney world and wouldn't work. I was so upset. Anyone have a solution?-   jewelhyppoli
Best Solution
posted on Sep 19, 2008
Very Helpful)
NoviceT
Rank: Apprentice
Rating: 98%, 4 votes
I have a Sony Handycam VideoHi8 XR w/72X digital zoom and I had not used the camera for four years-we moved & I lost it...long story short...I turned it on & began reacquainting myself with it & all of the sudden it flashed the dreaded C:31:23 code. I freaked when I read the $90 fix & wasn't certain about the other fix. I opened the tape deck ejected the tape, put it back in & turned off the camera & back on. Sure enough the same error came up again. So this time I repeated everything the same, but then ejected the battery & put it back in & then went back & recorded my cat. I reversed it & viewed it & it worked! Yay! I don't know if this will work for you, but I hope it does so you won't have to trash your camera.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on May 15, 2009
Not Rated)
townsend1768
Rank: Apprentice
Rating: 0%, 0 votes
I followed these same steps and it seems to have worked. I also changed the tape out. The tape that was in when problem started seems to exacerbate the problem. So check you cam with different tapes. LEE
Was this helpful?
Yes
No
Solution #3
posted on Aug 27, 2008
Not Rated)
penichon
Rank: Apprentice
Rating: 0%, 0 votes
complex solution ,only trained technician can solve
take up reel is part of an assembly unit ,very hard for
disassembly ,you have to change whole assembly
cost 90 dollars sony plus part store
You need the schematic and the right tools
Is better to buy other camcorder.
Was this helpful?
Yes
No
Solution #4
posted on Jul 27, 2008
Not Rated)
welcomejee
Rank: Guru  Sony Expert Cameras & Camcorders  Expert
Rating: 89%, 3007 votes
This problem calls reel sensor defect. If you understand its Tape Mechanism, open it and check Take-up Reel section.
Was this helpful?
Yes
No
Popular Solutions for Sony Handycam CCD-TRV318 Hi-8
Questions and Unsolved Problems for Sony Handycam CCD-TRV318 Hi-8
Do you recommend Sony Handycam CCD-TRV318 Hi-8 Analog Camcorder?
Answer
Answer
how to fix a sonytrv318 ntsc the tape went in half way and jamed after it was closed by me
Answer
I have a Sony Handycam CCD-TRV318 Hi-8 Analog Camcorder and I when I tried to view the tape, I get... (More)
Answer
When trying to play back, tape plays approx 5 seconds, then blue screen and the flashes C30:13 and... (More)
Answer
Have an older model. 80's or early 90's. Can't figure out how to hook it up to the tv and playback... (More)
Answer
I am trying to output a movie to my dvd recorder using an S-video cord (I do not have an av cord for... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sony Handycam CCD-TRV318 Hi-8...:
Top Camcorder Experts
Rank: Guru Guru
Solutions: 632
Experience: im jack of all trades but a master of none! and being an old f*rt you get to learn a fair old bit
Ask Me
Find more Camcorder Experts
Top Camera & Camcorder Repair
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
