Hdmi hdcp handshake problem between motorola 6416 verizon fios set top box and samsung ln46a750 lcd tv - no signal problem occurs. unplugging motorola box will fix the problem temporarily but it comes back.
SOURCE: Receiver: Pioneer Elite 72TXV Verizon
Called Verizon automated help desk. They rebooted DVR remotely and solved the problem.
Posted on Mar 29, 2008
MJS_1
  • 150 Answers
SOURCE: Toshiba 52hm84 DLP-HDMI Component has been compromised?
This is a wild guess, but I believe that you are being **** by the movie industry. The HDMI protocol includes a form of DRM (Digital Rights Management) for high resolution content called: High Bandwidth Digital Content Protection Basically this means that the media (disk or broadcast) instructs the player (in your case the cable box) to insist that any downstream devices (your TV) is industry and DRM compliant. Specifically this evil protection scheme is designed to plug the analog hole and make it impossible for you to record or copy the movie by using an analog output from your TV. This even restricts the size of the TV you can play the movie on, thus preventing pubs and bars from displaying the content on big screen TVs without paying royalties. The message means that the manufacturer of your TV has refused to toe the industry line. 1984 Anyone ? Martin
Posted on Apr 24, 2008
  • 34 Answers
SOURCE: I am trying to connect
Hello
by befault your dvd recorder is transmiting signals via component video, so what you need to do is this connect both cable HDMI and Component or just a video cable then go into setup and then select video out via HDMI your video will go off on the screen and then with TV remote slect input source HDMI on TV and it should work fine.
Thankyou
Posted on May 10, 2008
Agent Aaron
  • 265 Answers
SOURCE: Samsung lcd hdtv won't receive signal from fios hd receiver
Hey nothingsfree,
You may not necessarily have anything incorrectly set up, but there are a couple of things that I would suggest trying.
First, you'll want to make sure that your TV is set to the correct input source. Some TV's will require that the input source be changed in order to display any signals from an external device, like your HD-DVR. This can typically be done by accessing the main video menu using your remote control.
According to information provided by the manufacturer, you should be able to change the input source for this model TV (Samsung LN46A750) by doing the following:
* Press the "Menu" button on your remote control
* Press the "Up" or "Down" arrow button to select "Input," then press "Enter"
* Press "Enter" to edit the "Source List"
* Highlight the signal source for the HD-DVR, and press "Enter"
Next, you may want to try updating the TV's firmware. In some instances, simply updating a TV's programming can eliminate any potential hardware or software conflicts between two devices. To update the TV's firmware you will need access to a computer and a USB flash drive. Step-by-step instructions and the firmware update itself are available through the following website:
http://www.samsung.com/us/support/download/supportDown.do?group=televisions&type=televisions&subtype=lcdtv&model_nm=LN46A750R1F&language=&cate_type=all&dType=D&mType=FM&vType=L&prd_ia_cd=02010100&disp_nm=LN46A750
Make sure to read all the warnings and disclaimers available though, as your TV may already have a more up-to-date firmware version than the one that can be obtained through Samsung's support page.
Should neither of these address the issue, you may wish to see if connecting your HD-DVR to a different HDMI input solves the problem. Much like computers, TV's have been occasionally known to have faulty inputs or loose internal connections.
If all else fails, I’d suggest contacting the manufacturer for further assistance. In many cases manufacturers are able to provide over-the-phone troubleshooting support, in addition to having access to a wider variety of possible remedies for hardware problems.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Posted on Jun 23, 2008
SOURCE: My Samsung LN40A530 only produces
firmware update available at samsung web site
Posted on Sep 26, 2008
My tv model magnavox26mf231d/37 shows hdmi is disabled and the hdcp authorization failure.
This could be a problem with the cable box or other set top box and not the TV. It's known to happen with Samsung cable boxes from Cablevision.
First try resetting the TV and set top box by unplugging both. Remove the HDMI cable from the TV and the set top box. Reconnect the HDMI cable. If you are using a Redmere or similar HDMI cable, make sure that the end labeled TV is connected to the TV's HDMI port. (These cables have additional electronics and are not reversible.) Connect the power cord to the set top box and wait 30 seconds to a minute. Then plug in the TV. To ensure the set top box does the correct handshake with the TV, turn on the TV first and set it to the HDMI input. Then turn on the set top box. See if this fixes the issue. (On some cable boxes, this can be a temporary fix. You may need to have the set top box replaced.)
If the above steps don't help, try a different HDMI cable. If that doesn't solve the problem, then the set top box is faulty.
I hope this helps.
Jan 10, 2015 | Televison & Video
Tv turns on picture shows for 3 seconds then screen turns solid green. Sound is present even when screen is green.
I had the same problem on my Sharp LC-32SB24U Liquid Crystal TV. When I couldn't find any solutions on this site, I looked elsewhere on the internet. I found two credible leads.
First, supposedly, this is caused by a known problem with Verizon FIOS. Apparently, there's a problem that Verizon knows about that has to do with the signal between the Set Top Box (STB) and the TV, via the HDMI cable. Other posters on other sites said that the problem is more common with the 7100 series STB's and that the problem is not as rampant on the 6400 series STB's. (Mine is a 7200 series STB.) I have not called Verizon yet, but other posters said that Verizon just says that you'll have to use a set of basic red, yellow, and white cables, versus and HDMI cable, until Verizon gets the bugs out of the system.
The other credible lead revolves around unplugging the TV for two minutes and then plugging it back in. Simple.
Here's what I did, and it worked!
I unplugged the STB and let it sit for 5 minutes. Then, when I plugged the STB back in and powered itself back up, my problem was solved! (Before I did this, I tried just unplugging my HDMI cable to rely solely on my basic connector cables, but that didn't do anything for me.)
Good luck all!
Jul 04, 2010 | Samsung LN40B530 40 in. LCD HDTV
Samsung lcd 720 ln32b360 doesn't fill screen in 16:9 mode. Went through tv setup, connected it to hd box (verizon Fios) plays all HD channels but does not fill screen as it should. TV is connected to set...
If by regular cables you are talking about the standard red/yellow/white composite cables, then, yes, it will affect HD as composite cannot send an HD signal. Only HDMI and component (red/blue/green video only) cables.
Change to HDMI and let us know if it works for you.
Jan 07, 2010 | Samsung LN32B360 32 in. LCD HDTV
I have a Motorola QIP6200/64xx DVR set-top box thru Verizon
The best code I could find was "007"
"210" kind of works, but can't compete with Mr. Bond.
After programming "007", if there are any features of you FiOS remote that do not work on the HK AVR 354 remote, simply follow the HK AVR 354 manual instructions to "learn" additional commands. See the last paragraph on page 31 through letter "e" on page 32.
Cheers,
Jeremiah Pattison
Keywords: Harman Kardon AVR 354 remote code to control FiOS DVR PVR STB cable box QIP 6416
Oct 28, 2009 | Motorola Televison & Video
Tv goes off, then comes on, and volume goes to max
OMG! Verizon Fios at it again with changing boxes! Well let me tell you if you do not loose signal on a DVD using these same inputs ITS NOT YOUR TV!
Whats going on is further into Verizon system you loosing the signal from the VDSL slam outside in the pill box. This thing will need to be replaced and they are going to blame your TV until you just give up and buy a new TV only to figure out its not your TV.
1. Call them back
2. tell them to check there network
3. if that dont work tell them to check it again
4. if you have HDMI use that instead of the scart connections.
I hope you have luck with Verizon Fios there internet rules but there TV service is sub par!
Thanks
rulds2008
Jul 17, 2009 | Mitsubishi WD-52525 52" Rear Projection...
I have hd picture but no sound, tv says hdmi audio unavailable
I called Verizon and exchanged my STB from a QIP 6416 to a QIP 7216 and it solved the HDMI audio problem. This looks like the fix.
Apr 05, 2009 | HP PL4260N 42 in. Plasma HDTV
Philips TV HDMI CEC EasyLink tries to control Cable set top box
I finally found a fix to this! YAY. I thought I might have to return the TV. I have the Phillips 42PFL5603D, but should work for other models.
On the TV press menu picture settings---picture---dynamic contrast (turn off) AND active control, turn off
If you have Comcast Moto box: on the Cable box go menu--->setup--->cablebox set up---RF BYbass set to ON
If you have a non-Comcast Moto Box, I'm sure there is an RF bypass setting in the menu. You'll just have to look for it. Another fix was close saying to only turn of the active control, but it took all 3 of these for it to work consistently. The latter let it work for all of 30 seconds.
Dec 29, 2008 | Philips 42PFL7403D/27 42 in. LCD TV
Hey nothingsfree,
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 22, 2008 | Televison & Video
Mar 28, 2008 | Pioneer Audio Players & Recorders
HDMI crap out
I got the solution. Contact Customer Service, ask for LEVEL II Tech, and ask them for the old firmware. It will take a lot of pressuring, but they will send it to you and then it will work fine!
Feb 02, 2008 | Televison & Video
Televison & Video Logo
725 people viewed this question
Top Televison & Video Experts
