Question about Sony Cyber-Shot DSC-P32 Digital Camera
Sony DSC-P3 Zoom stopped working
My Sony DSC-P3 Zoom stopped working- built in zoom. I can nolonger zoom in for picture taking.
  • 2 more comments
  • bb33 Jul 27, 2008
    any idea of cost and availabilty?
  • bb33 Jul 27, 2008
  • onlyheisable Aug 10, 2008
    Haven't used my Sony Cyber-Shot-P32 for more than a year. Went to use it and the smart zoom does not work. Any simple suggestions?
  • Anonymous Aug 22, 2008
    I haven't used my Sony camera DSC-P32 in over a year and I can no longer zoom when taking pictures. However, I am able to zoom while previewing my
    pictures. Is there a specific setting that the camera needs to be set to
    in order to zoom. I misplaced my owners manual...as always. Any suggestions?
I had that same problem. check your image size, the camera cant zoom if the image size is set to 3.1M or 2.8M(3:2)
how to change image size:
turn on camera and leave it in camera mode (picture taking mode)
press the delete/image button
change image size until camera zooms again
VGA gives the biggest zoom range
i hope this helps
it worked on my camera
Posted on Oct 16, 2008
  • 10,594 Answers
Loading Motor unit in your DSC-P32 is worn out, needs replacement.
Posted on Jul 27, 2008
  • Shahid Electronics
    Shahid Electronics Jul 27, 2008
    well, cost of this part is approx $25.00
Won't take pictures when zoom
Most common problem in al the digital camera's. Slide motor start malfunction and the massage appears"Turn off the power and on again". In this situation you have to replace slide motor or lens block assembly, And your camera work fine again.
Thanks for using fixya.
Jun 27, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Manual zoom does not work when I try and use it
Most likely the motor mecanisim was damaged when you dropped it. was unable to locate a sony dealer in nepal, You could try Sears if there is one in nepal.
Hope that was helpful.
Nov 14, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Sony dsc t300 e 61:10
   The detail of fault is given below,
Self-diagnosis Code   Symptom/State
E 61:10         Zoom operations fault
               (Cannot initialize zoom lens.)
Correction :
Retry turn the power on by the power switch. Check the zoom
reset sensor of lens block (pin 9 of CN402 on the SY-191
board), if zooming is performed when the zoom button is
operated. If it is OK, check the zoom motor drive IC (IC401 on
the SY-191 board).
According to the symptom the possible fault is described above, You have to contact any nearest SONY SERVICE CENTRE to rectify the problem.
May 30, 2009 | Sony Cyber-shot DSC-T20 Digital Camera
Wont zoom in or out message reads turn the power off and on again can access stored pics but wont take new ones sony cybershot dsc w35
Is this camera only have a digital zoom? If it has an optical zoom as well, you could have a setting that is set to ignore digital zoom and because your lighting conditions, zooming in and out is not currently possible because the aperture can not be opened enough to light you take a picture without being blurry. The auto focus would be taking priority in stopping you from taking a picture.
Just a hunch.
Jul 20, 2008 | Sony Cameras
Internal Zoom Malfunction
Hi
Do you mean the 'digital zoom' when you zoom in as far as possible on something or do you mean even with the camera zoomed all the way OUT it still does it?
Yes you should always avoid the 'digital zoom', but if it still doesn't work when zoomed all the way out you need to have the lens cleaned, repaired, or replaced.
We are a digital camera repair business with AFFORDABLE prices. If we can help with your repair then please let us know. Google: darntoothysam
Good luck from Darntoothysam com
Thomas
May 23, 2008 | Sony Cyber-Shot DSC-W7 Digital Camera
ZOOM problem
Most likely there is a problem with servo drive for the lens and camera functions. The fix is to replace the complete processor board including the servo drive electronics. After replacement the board must be tested and calibrated.
Call Sony to see if the camera is worth to have serviced.
Jerry G.
Apr 06, 2008 | Sony Cyber-Shot DSC-S500 Digital Camera
I can't zoom with my DSC-H1
Check the Sony Support site for this- it may be a free firmware adjustment to down load.
It is not likely an out of warrant camera could be a viable repair option
Feb 10, 2008 | Sony Cyber-Shot DSC-H1 Digital Camera
Sony DSC-w50 zoom not working
switch on when the lense extends take the end of it and gently twist and pull the lense you may hear it click be gentle do not force it then switch off and on again and this will solve the problem 98% of the time.
Jan 25, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Sony DSC-W12 Camera
The W12 must be a European version of the W1 or W5 camera. The W12 is not available in the USA. It sounds like you have the "digital zoom" feature active. Digital zoom lowers the quality of the photo. It (in effect) reduces the megapixels applied to an area of a photo. Digital zoom should not be used if you want quality results.
Sep 08, 2005 | Sony Cyber-Shot DSC-W12 Digital Camera
Digital Camera Zoom
When you change the resolution setting, you are changing the digital zoom. Here take a look. http://www.photoxels.com/article_zoom.html
Sep 08, 2005 | Sony Cyber-Shot DSC-S30 Digital Camera
Sony Cyber-Shot DSC-P32 Digital Camera Logo
234 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
