Hi, my Zanussi F1365 washing machine is beeping and flashing everytime I select a program and won't do anything else. The beeping is continuous as is the flashing. The beeping and flashing only stops when I select program 0. Can you help please?
Try this reset procedure, but it sounds like an alarm situation.
How do I reset my Gorenje washing machine?
Upon start-up or during pause, the button backlight will flash; when the programme is started and in progress, it will be lit continuously. Use this button to turn the washing machine on and off, and to reset the washing programme. lighting Press the positions 7+10 and hold them for 3 seconds.
Try this.. Reading Error Codes 1. Wake the washer by pressing any button. 2. Wait 5 seconds. 3. Press and hold the START/PAUSE and CANCEL buttons simultaneously. As long as the buttons are held, the failure code will appear in the display as an "E" followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash. let me know what code come up.
I've had the same problem. I removed the top lit and found some pressure
transmitter and a pressure switch. I suspect that the pressure
transmitter is use for measuring the waterlevel in the machine. I think
the membrane loses its flexibility over the years.
I pulled of the hose from the transmitter and blowed and sucked a few
times on the transmitter. After doing this the machine washes without a
problem since then.
No-childlock isn't on but thanks
